Question about Apple iPhone 3G
Iphone shut off right after using phone and will not turn back on
I was talking on my Iphone last night and right when I hung up the screen shut off in a few seconds like normal, but since then I have been unable to turn the phone back on its like it just shut off by itself and it will not turn back on. a minute after it **** off i called it from another phone and it rang the normal amount of times and then went to voicemail than i called a few minutes later and it went straight to voicemail. Any suggestions on how to fix it?
Iphone s5 passcode removal
You can simply follow the steps below:
1. Connect iPhone to computer.
2. Select iPhone in iTunes "Devices" and click "Summary".
3. Click "Check for Update" to see whether there is a new version for iPhone software.
4. Click "Restore" and follow the instructions to complete the restore process.
5. Choose "Restore from iTunes backup" when iOS Setup Assistant asks to set up your iPhone.
Or refer to the source page: Forgot iPhone Screen Lock Passcode How to Recover Lost Data on iPhone...
Jul 25, 2014 | Apple iPhone 5
Ok i have a problem i bought a iphone from my friend last night so he restarted everything and its been on the same screen for the whole night last night i dont know what to do i tryed restarting and...
. Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously.
Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart.
when you see the silver Apple logo you can let go of the buttons.
and then try the phone and see if it is ok now
good luck
Jul 29, 2010 | Apple iPhone Smartphone
I dropped my phone last night and the screen black
Sounds like you either damaged the back light or display or hopefully just knocked the connector loose. Either way the case would need to be opened so you need to get it to a repair shop.
Mar 22, 2010 | Apple iPhone 3G
Iphone not starting
Hello!I have a problem with my iPhone 3g battery life, it lasts for no more than 5 hours or so and it doesnt matter what I do with the phone, if I listen to music, talking to someone or even if the iPhone on standby, at night I have to put it to charge because the iPhone just wont last the entire night (on standby) and will turn off.does someone have the same problem or know what to do to fix it?I have the iPhone for like a year and a half and the version is 3.0
Mar 05, 2010 | Apple iPhone 3G Black Smartphone
Iphone shuts off by itself
It is the phone power saving mode. You should set it to maximum time if you don't want your phone to shutdown rigthway when idle. Go to phone settings do it.
Nov 03, 2009 | Apple iPhone 3G
My iphone wont charge..
Had the same problem try rebooting your phone hold the home button and the power button on the top right together at the same time till it completly shuts off and till the apple shows up in your screen... Then let go.. Let it power back up then charge & see what happens... Don't reboot it while it's charging tho... If this don't work it just might be your battery which has gone bad.... Battery last up to 400 charges then after that be best to replace it... Good luck hope this works 4 you...
Aug 22, 2009 | Apple iPhone Smartphone
My iphone wont respond to my touch in the bottem halk
Have you tried doing a hard shut down? Hold the silver button down on the upper right corner and also the home button (center,bottom indented button) together for about 10 seconds. the phone will completly shut off. then wait about 10 seconds and hold down the upper right hand button until the apple appears on the phone then release the button and wait (20-30seconds) . Doing this usually solves all my issues with my iphone when it gets locked up like this.
Jul 01, 2009 | Apple iPhone 3G Black Smartphone
Iphone wont turn on
To fix this, you need to hook it up to your computer, run itunes, and let itunes recognize it. Itunes will notice it's not working right (you may need to play with it a bit to get to this point, otherwise just choose restore). When it's all connected, use iTunes to restore your phone to factory and try the jailbreaking all over again.
Good luck, let me know how that goes.
Caid.
Dec 29, 2008 | Apple iPhone Smartphone
Iphone hung on sync screen
connect to itunes and follow the instructions
Aug 31, 2008 | Apple iPhone 3G
Apple iPhone 3G Logo
145 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
