Question about Motorola Mobility RAZR V3a Cellular Phone
How do i reset voice greeting on razer? - Motorola Mobility RAZR V3a Cellular Phone
How to record a new greeting
  1. Go to Google Voice.
  2. Click the gear icon at the top right of the Google Voice window and select Settings.
  3. Click the Voicemail & Text tab.
  4. In the 'Voicemail Greeting' section, click Record New Greeting.
  5. Enter the name for the greeting you're going to record and click Continue.
  6. A "Record Greeting" box will appear. Select one of your forwarding phones from the "Phone to ring" drop-down menu.
  7. Click Connect.
  8. Google Voice will call you on the forwarding phone you selected. Pick up the call and record your voicemail greeting when prompted.
  9. Once you've recorded your voicemail greeting, make sure it's selected in the 'Voicemail Greeting' section of your Settings.
  10. Click Save changes at the bottom of the page.
Mar 17, 2016 | Lands Phones
How can I retrieve a deleted outgoing greeting? My husband passed away and it was his voice on the greeting. Please tell me how I can get it back?!!?
Knowing the importance of this specific case I would highly recommend calling the factory and having the read the chip (s) and retrieve the data aside from that there's no other way for a consumer to retrieve lost greetings unless you might have had it pre-recorded somewheres just in case he wasnt there and you needed to reset up your answering machine. Hopefully this helps. Sorry for your loss by the way .
Dec 21, 2015 | Panasonic KX-TG2356 Cordless Phone
Why did my enter key suddenly no longer function as to enter, when pressed it brings up a toolbar instead of taking to the next line?
your keyboard utilizes keys F1-F10 as re-programmable function keys.to change your current pofile press the razer lycosa logo+functon key(f1-f10) or you can reset your keyboard to factory default settings by pressing the "Razer Logo" button for 15 seconds while the Razer Lycosa is connected to a powered on computer. NB: ALL CONFIGURATION SETTINGS WILL BE LOST WHEN YOU RESET THE RAZER LYCOSA
TO FACTORY DEFAULT SETTINGS. ALL CONFIGURATION SETTINGS WILL NEED TO BE
RE-ENTERED OR LOADED FROM THE CONTROL PANEL AFTER THE RAZER LYCOSA IS RESET.
Jul 21, 2013 | Razer Lycosa Gaming Keyboard
Just got the Samsung Prostar compact IDCS 18D. It was used and I dont have the manual. I tried to record a new greeting which I did, but I can delete the old greeting from the other company which owned it....
When you go into Voice Mail and record you greeting you must delete the old greeting at the same time - the voice prompts will talk you through this. I have uploaded a video concerning Voice Mail admin, failing this please visit www.abbeytelecom.com for written help,
Nov 12, 2010 | Samsung Phone PDCSLCD12B
I'm trying to set up my voice mail and I am getting a message "mailbox locked". Is there a generic password I can enter that will work? Too, can you send me a step-by-step go-by to set up my mailbox?...
If you recieve the message "mailbox locked" then the password was incorrectlyentered too many times.
To reset your password press feature 983
the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
As far as setting up your Mailbox, press your open mailbox key or press feature 981.
When prompted to enter your password enter the password of 0000.
The voice mail will make you change and confirm your password at this point. your password can be between 4 and 8 digits but cannot start with a 0.
after the password is changed the voice mail will make you record your name for the company directory. once the name recording is accepted, the mailbox will be at your main screen.
To record a greeting for your mail box,
"8"for admin
"2" for greetings
"1" for record
"1" for primary greeting
"'1" to record your greeting
at the tone record your greeting
"#" to end recording
after you record press 1 to listen 2 to retry or # to accept
press "rls" key when finished
Dec 22, 2009 | NorStar M7310 Corded Phone
Change voice message on nortel meridian phone system
You need to go in to voice mail admin .
Feature 983 1020000
press AA
press Greeting
press greeting again
enter 1 for greeting 1
this should be your main greeting it could any greeting from 1- 20 , it depends on how it was set up but that should work fine .
Feb 17, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Razer Lachesis moves without touching
Greetings, I had this problem occasionally as well. Except I have the Habu instead of the lachesis. I fixed mine however, when I saw my cordless (yes, i keep it plugged in at the same time) Had been knocked off its charger by someone. When I replaced it (preventing outside interference form it) The problem with my migratory cursor was fixed. I see this was posted a couple months ago, but hopefully this helps some.
Feb 17, 2009 | Razer RZ01050300 Mouse
Can't reset the voice message
press and hold the greeting button then you will here a beep then the machine will say record your message after you have finished push the greeting button and your greeting will play back
Feb 14, 2009 | Uniden DECT 6.0 Cordless Telephone...
Lost phone greeting
If you press the Greeting Check button and only the pre-recorded greeting plays back, The other greeting has been accidentally erased.
Aug 24, 2008 | Panasonic KX-TG5632 Phone
How do I change the voice mail recorded message? How do I get a manual for this existing system?
IF you know the password for the mailbox then log into the voicemail by dialing the Stratagy access code, after Stratagy answers dial * , then your user ID mailbox number plus #, then your security code plus #. The User Main Menu plays, press 2 to change your greeting, the Select Greeting Menu plays, press the greeting number, the Record Menu plays, press 2 to record your greeting, Record greeting, as soon as you finish press #, the Record Greeting Menu plays, press 1 to review or 2 to re-record. Press 9 to save and return to the Select Greeting Menu and 9 again to return to the User Main Menu, hang up at this point.
Jun 08, 2008 | Toshiba DKT-2010 Corded Phone
Motorola Mobility RAZR V3a Cellular Phone Logo
24 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
