Question about Broderbund The National Geographic Magazine: 1940's for Windows, Mac
I go through all installation steps OK but when I click on icon to start program I get message "NGMAG2 has encountered a problem and need to close." Other attempts state that program has been installed.
    President:
  • 1,462 Answers
That is because of your display.
you can:
1. Click Start, and then click Control Panel.
2. Click Appearance and Themes.
3. Click Display.
4. On the Settings tab, click Advanced.
5. On the Troubleshoot tab, move the Hardware acceleration slider control to the third position (from the left), and then click OK.
Note The following message is the description for this position:
Disable all DirectDraw and Direct3D accelerations, as well as all cursor and advanced drawing accelerations. Use this setting to correct severe problems with DirectX accelerated applications.
6. Click OK to close the Display Properties dialog box.
Please click on this link for more info:
http://support.microsoft.com/kb/835262/en-us
Please leave me comments if you need furthur information, Else please RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Sep 24, 2009
Qx3 microscope driver for Windows 8
Here are the instruction for installing the QX3 (or QX3+) Microscope with Windows 8 and Windows 8.1. You must be using a 32-BIT VERSION of Windows 8 or 8.1.
Note: The QX3 is not compatible with 64-bit versions of XP, Vista, Windows 7 or 8.
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Download and run the QX3plus.exe program from:
http://tinyurl.com/QX3-Win8-1
After the program installs, uncheck "I would like to view the README file." Click "Finish".
Step 2. Download and run the qcodinstl.exe program from:
If asked about NTVDM, click "Install this feature" then click "Close"
Step 3. Download IntelQX3driverXP.zip and save (do not open) the file from:
Step 4. Now, plug in the microscope. The driver should load silently.
If the "Found New Hardware" wizard appears and you get a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Right-click START - Select "Device Manager"
b. Right-click on the Intel QX3 Icon and select "Update Driver Software", select "Browse my computer for driver software"
e. Browse to the Download folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
IMPORTANT: Before you run the QX3Plus program for the first time, right click the "Intel Play QX3 Microscope" icon on the desktop, click "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose "Windows 98 / Windows ME" in the drop-down box. You should also check "Run as Administrator" if your account is a "Standard user". Click "Apply" then "Ok".
Step 5. Finally, double-click the "Intel Play QX3 Microscope" icon on the desktop and the program should run.
If you get a message that the microscope is not plugged in, quit and restart the program.
If the program hangs or crashes, reboot the computer, then restart the program.
Comments and suggestions to mmehall [at] yahoo.com
Apr 05, 2014 | Intel Play QX3 Monocular Microscope
Windows 7 driver
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista and Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions.
Step 1. Download and install the QX3PLUS.EXE software from:
http://tinyurl.com/QX3-Win7-Files
Step 2. Download and install the QCODINSTL.EXE software from:
Step 3. Download and extract the QX3 Drivers from:
When the "Found New Hardware" wizard appears you will see a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Click START - Select Devices & Printers
b. Right-click on the Intel QX3 Icon and select Properties
c. Click the Hardware tab - click Properties
d. Click Update Driver - select "Browse my computer for driver software"
e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
Jan 19, 2014 | Intel Play QX3 Monocular Microscope
QX3 microscope
Dec 30, 2013 | Intel Play QX3 Monocular Microscope
Digital blue qx3 drivers
Here are the instruction for installing the Intel QX3 (or Digital Blue QX3+) Microscope with Windows 7 or Windows 8.1. You must be using a 32-BIT VERSION of Windows 7 or 8.1.
Aug 20, 2013 | Intel Play QX3 Monocular Microscope
I can not get the printer to stop printing ...what do i do?
Hi please turn off the printer and restart it after five minutes if you still have the problem please uninstall and reinstall the drivers for your printer.
Jun 13, 2010 | HP Office Equipment & Supplies
3 software packages won't install or run.
TRY,, DRIVER MAX free program i always had problems with driver detevtive
May 22, 2009 | HP Pavilion m7480n (882780389410) PC...
Can't use scanner on computer
Were you able to download the driver from HP?
I would suggest unplugging the scanner, uninstalling the program, reboot, reinstalling the program and then plugging the scanner back in
Dec 11, 2008 | HP Scanjet 3570 Flatbed Scanner
GENERIC HOST PROCESS FOR WIN32 SERVICES HAS ENCOUNTERED A PROBLEM
I guess it is a network virus! Repair your os, or reinstall it if needed , and do not share anymore or buy a Total Security antivirus!
Nov 16, 2008 | Microsoft Windows XP Media Center Edition...
Missing MSIEXEC.EXE
Try this:
To unregister and re-register Windows Installer:
Click Start, and then click Run.
Type in the Open box: msiexec /unregister and then click OK.
Type in the Open box: msiexec /regserver click OK.
Feb 17, 2008 | Microsoft Windows XP Professional
Quickcam
Error 2711
When receiving the 2711 error during Logitech QuickCam/Image Studio software installation, please perform the following steps:
  1. Use Add/Remove programs in the Control Panel to uninstall any current installation of QuickCam/ImageStudio software. For Microsoft Windows 95, 98, ME or NT
    1. Click Start, Settings, then Control Panel.
    2. Double click the icon labeled Add/Remove Programs.
    3. Highlight the desired program in the list provided (QuickCam or ImageStudio).
    4. Click Add/Remove Programs located in the bottom right of the list provided.
    For Microsoft Windows 2000 or XP
    1. Click Start. followed by Control Panel.
    4. Click the button labeled Remove located in the bottom right of the program selected.
  2. Navigate to C:\Program Files\Logitech.
    1. Double click the icon on the desktop labeled My Computer.
    2. Double click the icon labeled C:\(computer name).
    3. Double click the yellow folder labeled Program Files.
    4. Double click the yellow folder labeled Logitech.
  3. Delete any folders for QuickCam/ImageStudio.
    1. Select the yellow folder with the QuickCam or ImageStudio names.
    2. Click the menu options for File, followed by Delete.
    3. Repeat for any other QuickCam/ImageStudio folders.
  4. Delete all files located in the Windows temporary directory C:\Windows\Temp or C:\WinNT\Temp
    3. Double click the yellow folder labeled Windows or WinNT.
    4. Double click the yellow folder labeled Temp.
    5. On the menu across the top of the window, click Edit followed by Select All.
    6. On the menu across the top of the window, click File followed by Delete.
    7. Click OK.
  5. Reinstall QuickCam/ImageStudio
    1. Remove and reinsert the QuickCam/ImageStudio CD and follow the prompts OR
    2. Double click on the downloaded ImagStudio file.
Dec 27, 2007 | Logitech QuickCam Express Web Camera
Broderbund The National Geographic Magazine: 1940's for Windows, Mac Logo
69 people viewed this question
Top Broderbund Video Game Consoles & Games Experts
James Wishart
Are you a Broderbund Video Game Console and Game Expert? Answer questions, earn points and help others
