Question about HP Pavilion dv6810US Notebook
I did a hard disk self test and it said #10008 replace hard disk.
My laptop crashes a lot. the screen goes white with horizontal lines. It does not detect the dvd player.It also crashes sometimes when i put it on sleep mode,the screen turns off but it does not sleep. i did a hard disk self test and it said #10008 replace hard disk.Any suggestions?
  • 136 Answers
There is some problem in your Hard disk.
You can defragment all drives.
if the problem still there, you can try to format your disk.
Posted on Sep 24, 2009
How to fix a missing operating system on acer aspire 4920 series laptop
This might be caused by hard-drive failure. You should run hard drive test from BIOS to make sure hard drive is ok. You can access BIOS by pressing F2 during start up, from there start hard disk self test and wait for it to complete.
May 13, 2014 | Acer Aspire Computers & Internet
My dell laptop has horizontal lines across the screen
Last one I had with this it was the connection from the compute base to the monitor. difficult to chk and hard to fix yr self. hv it tested. cheers
Aug 04, 2012 | Dell Latitude D520 Notebook
I am having HP pav DV6663 laptop . Currently i am facingthe problem #10008 - Replace the hard disk message while i tried dignostic test for harddrive. Is my hard disk is crshed, and now unusable? whats...
This message is generated when the hard disk has failed completely, at a hardware level = it busted.
You must replace the disk, no way around that - a new better/bigger one will cost you about $40
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5013592&CatId=1277
Apr 24, 2011 | Compaq Presario Notebook
Dst short test fail
DST Means: Drive Self Test. What happened here was when your laptop booted the Hard drive does a short self test on itself to make sure its still alright. If your drive is not functioning like it should, the test will fail. So needless to say, your hard drive has crashed. To solve this problem you will need to replace the hard drive with any 2.5" Notebook ATA hard drive of your choosing. Then after you have the drive installed the new hard drive, use the disks that came with your laptop to reinstall Windows. If you do not have the disks, you can use any Windows XP CD that you can get.
Apr 11, 2011 | Dell Inspiron B120 Notebook
My laptop won't boot up when i go into boot up options at the very beginning and do a primary hard disk self test the message comes through that says #10008 replace hard disk
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
don
Feb 13, 2011 | Computers & Internet
Hi!My laptop (HP G7000)can not boot, currently when I diagnose the hard disk using "BIOS Hard Disk Self Long test" I get this message"Failed - replace Hard Disk 1 (warranty ID - error code 10008". What...
Your hard disk has indeed failed, this is not an indication of a spyware problem. Your best bet, if the laptop is under warranty, is to contact HP for a replacement hard drive.
If, however, your are out of warranty or would prefer to do it yourself, it appears your laptop has a 2.5" SATA hard drive. You don't need a huge one, your failed hard drive was probably between 80-160GB. Do not get a hard drive with a PATA/IDE interface, or a 3.5" hard drive, as these will neither work nor fit in your computer.
There are several screws on the bottom of your laptop. You will not likely need to remove the entire laptop case, and many times the bottom of the laptop is labeled with icons or a description of the component beneath the panel in question. When you replace the hard drive, pay attention to the orientation of the old hard drive, as well as where any different size screws were placed.
Finally, you will need to restore your computer with a set of disks. As you will be replacing your hard drive, any restore partition that was previously on your computer will have been lost.
Please let me know if you have any other questions related to this issue. Thanks!
Aug 11, 2010 | Computers & Internet
The message on the screen says primary Hard Disk
Every hard drive has in it a hardware test system - the one from yours has just announced you that your disk has died. Replace it and reinstall Windows.
Jul 22, 2010 | Computers & Internet
HArd drive issue. Self diagnostic desnot recognise the hard drive
Was the replacement hard drive a new one? If not it will have to be formatted first
Jul 18, 2010 | HP Computers & Internet
Asi gave mine laptop compaq c700 pc notebook to hp service centre for check up. they told me that there is a hard disk problem .so the problem was "HDD test fail & check with another HDD.& all...
Only Hp knows what that means in their diags. Get it shipped back and take it to a Locally owned PC shop and have them take a look at it. It is possible that you have just enough file fragmentation and file structure corruption that it is fail diags. Why did you take it in to be looked at anyways?
Sep 11, 2009 | Compaq Presario 700 470024-192 Notebook
Error message: Failed- Replace Hard Disk 1 (Warrany ID error code 10008) what does this mean I have a compaq Presario A900
It means that Hard Disk 1, which is either the first or second harddisk in the laptop, has failed. First open the BIOS on your latop. Before windows startup there should be a Compaq logo on screen. There also is some text saying which key to press to access BIOS. In BIOS, try opening some menus and look for a menu that shows your disk drive. In the same menu should be your harddisk. If it is there, go to A. If not, go to B. A: The disk is not broken, it just made a write error that destroyed WIndows. Insert the disk with your operating system on it into the laptop, and reinstall it. Your data is gone, but the laptop will work. If reinstalling the OS gives errors, and is unable to complete, go to B. B: Your harddisk is broken. There is no way to fix it, and you will need a new one. Contact Compaq if your warranty is still valid, and if not, take it to the nearest computer shop and ask for a new harddisk. If you have any more questions or trouble just post back here. I hope this helps, Yannick
Jun 07, 2009 | Compaq Presario Notebook
HP Pavilion dv6810US Notebook Logo
2,638 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
