Question about Maytag Atlantis MDG7400AW Gas Dryer
My maytag gas dryer timer does not turn, does not get hot, does not shut off unless I shut it, why?
  • 6,784 Answers
HI. This will occur when the timer mechanism(timer motor assembly), becomes fused, or the motor itself has failed. The timer mech is the main initiator of all the selected cycles. If the timer is unable to rotate properly, the unit will not heat or stop as well. Replacing this defective timer module will correct this issue.
Posted on Sep 24, 2009
I have a Maytag dryer MDG6200AWW and at first the machine dried the clothes fine but never shut off. The second load got hot but not long enough to dry whole load. The timer does not advance at all. ...
Remove the front panel to get to the gas valve. To remove the panel remove both screws holding the door hinges and the screws on the opposite side from the hinges across the door opening.
Remove the metal bracket holding gas valve coils.
Replace both gas valve coils, part number 279834.
Good luck,
Vlad
First Choice Appliance
Aug 21, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Trouble with Maytag Legacy gas Dryer
Please provide the model number and I will see if I can figure something out.
It sounds like you have covered the common problems. Usually a motor is the cause for this problem, it gets hot and shuts down until it cools off. I have had some problems with the auto dry controls on the Maytags also.
Are you equiped to do some voltage checks if we need too? This would help in knowing where you have power when it quits.
Thanks/Mike
Dec 12, 2007 | Dryers
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
Maytag DG482 Dryer Won't Heat
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor
a%20igniter.jpg Ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly. So... If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils
part# 279834
The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks. SOURCE
Jul 07, 2009 | Maytag Dryers
Dryer turns on. no heat and timer does not advance?
sounds like glow bar or photo sensor not working properly. should be access panel to veiw ignition system, if glow bar turns white hot when dryer is started, try to clean face of photo senser and re-start. unplug dryer before cleaning sensor. timer will not start until dryer comes up to temp.
May 15, 2009 | Maytag SDG4606A Gas Dryer
Amana dryer timer dial wiil not rotate/temperature stays hot
The elctrical contacts in the timer have welded themselves together or the notch wheel is broke in the timer; either way you need a new timer, and this also explains why it runs until you open the door.
Apr 10, 2009 | Amana NDG7800AW Gas Dryer
Maytag gas dryer wont heat
Since your hot surface ignitor is glowing, that means it is trying to heat, or that all the temp. switches are good and the timer is sending the signal. First check that there is actually gas pressure to the dryer. But the common problem is the coils on the gas valve. There are two, called the booster/holding coil, and the secondary coil. They are purchased as a set (part #279834 / $20.00) if it is the same as my mdg8600aww model. If that doesn't work, then likely the gas valve itself.
Sometimes those coils will open circuit when they warm up, and close when they cool down, giving you an erratic operation symptom.
Mar 28, 2009 | Maytag MDG2706A Gas Dryer
Maytag Dryer
hi thanks for the question i would check the venting on this dryer make sure its clean if you can vacuum the entire dryer this will solve your problem thanks the appliance doc
Aug 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
189 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
