Question about Kicker Car Audio & Video
The kicker 77kick18ab amp is an 8-channel amp-when used in jeep commander in replacing the factory ba amp it should only use 6-channels(dash,frnt doors and rear doors) this should leave 2-channels left over-how can i access these for use with sub or is this even possible
KaeZoo
  • 156 Answers
SOURCE: USING 1 CHANNEL
I can't find any documentation for your amp; it was made when Jensen was owned by Recoton, and they're no longer in business. With any 4-channel amp, you can't bridge all four channels into a single channel. What you can do, if you're connecting it to a single sub, is to bridge two of the channels into one channel and leave the other two channels unused. It doesn't usually matter which two channels you pick, but some 4-channel amps designate channels 3 and 4 (or rear channels) for the subwoofer. Whichever ones you use should have a "LPF" or "LP" crossover setting available.
Posted on Jul 01, 2007
  • 631 Answers
SOURCE: kicker amp troubleshooting
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Posted on Dec 01, 2007
blueextc3221
  • 15935 Answers
SOURCE: need specs and wiring options
  • 105W x 4 Channel Max. Power Output at 2o.gif Stereo
  • 60W x 4 Channel 0.1% THD at 2o.gif Stereo @13.8V (RMS Continuous Power)
  • 40W x 4 Channel 0.1% THD at 4o.gif Stereo @13.8V (RMS Continuous Power)
  • ChannelFlex Crossover
  • Adjustable High-Pass Frequency (50-200Hz, L/R Independent)
  • Low-Pass Frequency (120Hz)
  • Adjustable Bass-Boost Level (45Hz, 0-9dB, F/R Separate)
  • High-Current, High-Speed Output Devices
  • High-Efficiency, High-Energy MOS-FET Power Supply
  • Audiophile Grade Component Selection
  • Intelligent 7-Way Discrete Protection Circuitry
  • Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
  • High-Level Input - Add on Capability
  • Epoxy Composite PCB
  • 2o.gif Stable Design
Each 6 1/2" speaker will see 40 Watts
Each 6"x9" will see 521/2 Watts
Yes your solution is correct. Front wired in stereo, bridge rear.
Posted on Dec 29, 2008
etirbynnor
  • 655 Answers
SOURCE: 2 channel amp to 6-6x9 wiring diagram
Hello magoocsl,
Yes, with the use of 2 high-pass and 1 low-pass crossovers, that Kicker amp will operate in what they call stereo and mono simultaneously (SAMS). You'd run 4 of the 6X9's in mono. Wire them in series-parallel with a low-pass crossover on the positive leg to the amp. The amp would see a 4ω load. The other two 6X9's would be wired as stereo, one to each channel with a high-pass crossover. Again, the amp sees a 4ω load.
Here's a link to the appropriate wiring diagram. The diagram is on page 5. Just substitute your 4 6X9's wired in series-parallel where they show the "mono" speaker.
http://www.kicker.com/sites/default/files/02KX300_400_500_800_2AmpManual.pdf
Hope this helps.
Posted on Apr 01, 2009
  • 3 Answers
SOURCE: my protection light keeps comin on...
your amp is 2 small..
Posted on Apr 11, 2009
Where is the amplifier located on a 2012 jeep sport wrangler 4-door?
The factory Amp in a 2012 JK Wrangler both 2 and 4 door versions and all submodels with premium sound is on the drivers side beneath the steering column. You remove the pop out panel beneath the steering wheel and you will be able to see it. You will need a 7mm and 10mm socket to unscrew the remaining bolts for the other lower panels removal to actually get to the amp to remove it. Kicker makes a factory plug and play replacement unit with Mopar that is really good although the model will vary depending on if you have the premium sound upgrade option on your wrangler or not. Non premium sound models have no factory amp as speakers are powered by the deck however the amp harness is still there for the kicker upgrade. Some people have even managed to fit in some nice 5 channel powerhouses that don't heat up much like the marine grade alpine pdx and some others.
Jun 26, 2017 | Jeep Cars & Trucks
Location of factory amp for 2012 jeep wrangler
The factory Amp in a 2012 JK Wrangler both 2 and 4 door versions and all submodels with premium sound is on the drivers side beneath the steering column. You remove the pop out panel beneath the steering wheel and you will be able to see it. You will need a 7mm and 10mm socket to unscrew the remaining bolts for the other lower panels removal to actually get to the amp to remove it. Kicker makes a factory plug and play replacement unit with Mopar that is really good although the model will vary depending on if you have the premium sound upgrade option on your wrangler or not. Non premium sound models have no factory amp as speakers are powered by the deck however the amp harness is still there for the kicker upgrade. Some people have even managed to fit in some nice 5 channel powerhouses that dont heat up much like the marine grade alpine pdx and some others.
May 20, 2012 | 2005 Jeep Grand Cherokee
I have a power acoustik 0V4-1200 amp and 2-12" kicker cvr dual 2 ohms. My amp keeps getting really hot and turning off. I have two pair of rca jacks from my cd player to the amp. One speaker hooked up...
i have found the specs to your amp. 1. Amplifier connections: Lets make things simple. As we look at the amplifier speaker connections, we will number the outputs 1 2 3 4 from left to right for the top connections and again 5 6 7 8 from left to right for the bottom connections. 1 should be connected to a positive (RED) (+) on sub woofer A on voice coil (a) 4 should be connected to a negative (BLACK) (-) on sub woofer A on voice coil (b) Now using a small piece of cable, connect negative of voice coil (a) to positive of voice coil (b) Follow the same procedure for the other sub woofer using 5 and 8 as 1 and 4 This configuration should make the amp run at 4 OHM BRIDGED x 2. i hope this helps. dreamsystems
Feb 07, 2011 | Car Audio & Video
Have a kicker 350 4 played to loud stuck on protection
contact eric @ Capital Audio & Electronics Repair 850-339-1130 we repair all brands & all models
Mar 12, 2010 | Kicker KX350.4 Reed Multi-Channel Amp -...
Kicker 8 inch 4 ohm subwoofer 200 watts rms?
Max 200 W. You could bridge 2 channels of a 4 channel amp (or get a 2 ch amp and bridge it) and connect the sub. Bridging = connect + of sub to + of one channel, and connect - of sub to - of *other* channel. Check amp manual for instructions.
Don't get a mono - most are 300W or more - might burn the coil during loud passages.
Jun 22, 2009 | Car Audio & Video
Hello magoocsl,
Hope this helps.
Apr 01, 2009 | Kicker KX500.2 Car Audio Amplifier
How do i wire 10' kicker cvr
dual 2 or dual 4
dual 2 wire vc's in series for a 4 ohm load each. Hook each speaker seperate channels on the amp.
dual 4 wire vc in series for an 8 ohm load each. Hook both + to the right + on the amp and both - to the left - on the amp. or
dual 4 wire vc in parallel for a 2 ohm load each and hook each speaker to seperate channels on the amp.
Dec 18, 2008 | Kicker CVR12 Car Subwoofer
Srt 8 factory kicker system
try running the cables trough a crossover & u can run what u want to what speakers u want
Aug 09, 2008 | Kicker 01C8VR4 Car Subwoofer
2006 12" Kicker L7 4 ohm
first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Sub+amp configuration
With a single 4-ohm subwoofer, usually the best choice is a 2-channel amp that can be bridged to a single channel. In your case, the sub is rated for 1000 watts. Not many amps are rated for that kind of continuous power into a 4-ohm load. Kicker doesn't list a minimum power rating, which isn't unusual in subwoofer specs. Depending on your budget, I'd look for an amp rated for 300-500 watts minimum; the higher, the better, up to 1000 watts. Most amps will have several power ratings, based on the load impedance and number of channels driven. A typical 2-channel amp might be rated like this: 150 watts x 2 channels at 4 ohms 300 watts x 2 channels at 2 ohms 500 watts x 1 channel at 4 ohms. The power rating you'll want to look at will be the 1-channel, 4-ohm rating. You can look at mono amps, too, but in the power ranges you're looking for, a 2-channel amp will probably give you the best value. However, if you can find a mono amp with a high enough 4-ohm power rating, it would run cooler and might last longer than a 2-channel amp with comparable power. When looking at mono amps, you'll find their highest power output will be at 2 ohms or 1 ohm; make sure you're checking the 4-ohm rating when making comparisons. Some amplifiers that might work well for you: Kicker SX900.2 Kicker ZX850.2 Alpine PDX-1.1000 Rockford T600-2 Hifonics ZXi 1006 Premier PRS-D2100T Power Acoustik OV2-2200
Jul 05, 2007 | Kicker C12-4 Car Subwoofer
Car Audio & Video Logo
231 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
