Question about Cell Phones
Lg cookie keeps turning off when i try to send files on bluetooth
Everytime i go onto bluetooth and it searches for devices, it turns itself off and then comes back on again how can i stop this so i can send files to another phone?
How do I get my HTC desire to actually connect via Bluetooth to another desire and a LG vn250 aka LG cosmo it paits to the devices but it won't actually connect so I can send pics and things via Bluetooth
go to "wireless & networks > bluetooth setting" on your HTC Desire. Set the "Device Name" & tick "Make Device Discoverable". now scanning for your HTC Desire from the other handset.
Mar 10, 2011 | HTC Desire Cell Phone
How to transfer music contacts videos etc from LG cookie phone into I phone
Hi, there are different ways you can send data on phone, you can use a blue tooth device
Below is a step of how you an send Data like video, music etc from LG to iphone.
How to Send Data to a Phone Via Bluetooth
Bluetooth is a type of technology found in electronics that allows you to send and receive signals and files wirelessly. Most commonly used in cell phone headsets, many people also use Bluetooth to transfer data. There is no set protocol for all devices, so instructions for use vary from one device to another. Check out the following loose guidelines for sending music from one Bluetooth phone to another, or from a Bluetooth-enabled computer to phone.
Instructions
Verify that Bluetooth is turned on or enabled in both your devices. Most cell phones will have a Bluetooth menu in their Settings or Tools. For computers, you may see a Bluetooth icon in your system tray. If unsure, check your product manual for specific instructions.
Follow the instructions to pair (connect) your two devices. If you are asked for a passkey, try entering 0000 which is usually the default for any device.
When prompted on the other device, give permission for the original device to access it.
If transferring from phone to phone
Navigate to the song you want to send and hit the button that takes you to the options menu. Choose the option to send your song; depending on the brand of phone it may say "Send" or "Move."
The next menu should ask if you want to use a text message or Bluetooth to move or send the file. Choose Bluetooth.
When prompted on the phone receiving the file, accept it.
If transferring from computer to phone
Look for an option to browse the contents of the phone. Navigate to the data file or Multimedia folder on your phone.
Navigate to the place on your computer where your Data file is kept in a separate window.
Drag the file from its original location to the correct folder on your phone.
Accept the file when prompted by your phone.
Tips & Warnings
Pairing is usually the most difficult part of the process. Make sure you read your manual on both devices if it isn't working for you. If you don't see the menu to move or send your videos, your phone manufacturer may not allow it. Check your manual or with your carrier's tech support website. This process usually applies to MP3s and not ringtones.
Hope that helped.
Good luck.
Feb 08, 2011 | Apple Cell Phones
I have an L.G. Shine and cant get the blue tooth to work
The bluetooth of the phone is in the settings of the phone. To get it to work, turn on the phone, then you go to the settings, go to bluetooth and turn it on from there, once it is turned on, then you ensure the device you are trying to pair with is turned on, then you try to send or receive a file from other devices, it will require you to pair the devices up to be able to send or receive files using the bluetooth.
Use a simple pairing passkey to pair the devices up, like 1111 or 0000, that should help.
Hope this was helpful. Thanks for using fixya.
Jan 26, 2011 | LG Shine KE970 Cellular Phone
Won,t send or receive pictures lg 290c
To send or receive pictures or any file, you need to be sure that your phones bluetooth is turned on, without it your phone will not be able to send or receive pictures or any files. Also, you can transfer files to a computer using a USB cable, connect it to a computer and other devices that Has a USB hub. Files can also be transferred through the SD memory card, you can transfer pictures to the memory card and remove it from your device, then you turn off your phone, remove the memory card, install it into other devices that allows memory cards, then you copy pictures from the memory card to other devices.
To use your bluetooth in transferring the pictures from your phone to other bluetooth devices, then you turn on youe bluetooth by going to the phones menu, select the settings, then you go to the bluetooth and turn it on, make sure the bluetooth device of other phones and devices are turned on then you select the picture to send and select via bluetooth, it will search for the available bluetooth devices, then you select the one you are willing to send your pictures to then you either pair id the device is not familiar, ensure you use a password that is easy to remember to pair with the other device.
That way your phone will be able to send the pictures. That should solve the problem. Hope this information assisted you!
Jan 10, 2011 | LG Cell Phones
WHEN I WANT TO CONNECT WITH ANOTHER MOBILES BLUETOOTH THEN IT SHOWS NO DEVICE FOUND
First, you ensure that your phones bluetooth is on by doing to the settings and turning it on, then you ensure that the bluetooth device of the other device you are trying to send or receive a file from is also turned on, then, you can transfer files.
If it still does not find your bluetooth, you can try to receive a file from the recipient you were trying to share files with, and pair up the devices so you will be able to find bluetooth devices.
Take care
Oct 14, 2010 | LG GM200 Cell Phone
LG Cookie bluetooth problem
There is a difference between "pairing" and sending files. You normally have to negotiate a security protocol to send files where you enter a passkey on one device and then do the same on the other
Jan 30, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
My LG cookie turns itself off everytime it connects to my car's bluetooth system. Any ideas why?
im preety sure its for safety reasons..you can still go on your phonebook etc on the cars bluetooth..hope it helps
Sep 04, 2009 | Cell Phones
I want to send a ringtone from my husbands razr to my lg
Hi Motorola tends to do Bluetooth sending differently. Make sure your LG is set to discoverable and B/Tooth ON. On the Motorola turn on B/tooth and find file you want to send. With the file highlighted press option and you should find 'move to' and 'copy to'.
If you select move to, it will send file to LG but remove itself from the Motorola! Best to use 'copy to'. If the Motorola cannot find the LG once searching, to send the file you may have to pair the two devices first. To do this it is best to go into Motorola's B/tooth menu and set it to 'discoverable' this will stay active for a few minutes. Then on the LG search for new devices in B/tooth menu. It should find the Motorola and request a four digit pin which default on most phones is '0000' if this fails try '1234' (it will be one of those, more likely first one). Once both paired try sending file again and it should work. Let us know how you get on?
Apr 22, 2009 | Motorola Mobility RAZR V3
Can i save files sent through bluetooth strait to my memory card on the lg ks360
o send a file via Bluetooth:From the Start-up screen select the Main Menu icon
Go to Multi-media (Figure 1)
Select My Stuff (Figure 2)
Go the images/sounds/videos/documents and select the file you wish to send
Select the Menu icon at the bottom left of the screen
Select Send Via (Figure 3)
Then choose Bluetooth (Figure 4)
You will then be presented with a list of devices in your area. (Figure 5)
If you do not see the device you wish to send your file to ensure it’s has Bluetooth switched on and select New
Your handset with then search for all Bluetooth devices in your area (Figure 6)
Select your device and your handset will send the file (Figure 7)
The Bluetooth device you are sending your file to must accept the file (Figure 8)
To receive files via Bluetooth ensure you have Bluetooth switched on – only accept files from devices you recognise.
You will receive a message stating the file name with the option to accept or reject the file
To receive select Accept (Figure 9)
The file will then be transferred to your handset (Figure 10)
It will then be saved in your images folder
Oct 18, 2008 | LG Cell Phones
"check bluetooth status of receiving device"
I heard something about how Verizon only uses bluetooth for headsets. Nothing else
Aug 22, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Cell Phones Logo
78 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
