Question about Dell Dimension 2400 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
Primary Slave Drive 0 Not Found
F1 to reboot, F2 system utility
    Sergeant:
  • 151 Answers
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Posted on Sep 24, 2009
  • mizzb_carter Mar 30, 2011
    Hi byron I need help setting a program for my computer games and dvds to work HELP!! Thanks
No boot device available stike f1 to retry boot and f2 for setup utility diskette drive 0 seek failure a dell dimension 2400 series
Your computer cannot find a boot-able storage device, i.e. hard disk drive, to boot from. Either your hard disk drive is defective or the OS (operating system software) is corrupted and needs to be re-installed.
Jul 27, 2011 | Dell Dimension 2400 PC Desktop
My dell d2400 will not boot up, I get the primary drive 1 not found, strike f1 to continue, f2 to run the setup utility
when the operating systems was setup on your hard drive, the incorrect partition was set. this causes that screen to appear. more often people will choose that way so that you may have full advantage od a smaller hard drive. this will not affect the performance of the system in any way. the fact that you have to hit the f1 key on startup is just an inconvenience.
Jan 22, 2011 | Dell Dimension 2400 PC Desktop
Dell dimensions 3100
sounds like your floppy drive is failing, you could get it replaced or simply turn it off via the BIOS.
to turn it off simply hit the F2 key. On the first screen usually it will list your Hard Drives, CD ROMs', and the Floppy. scroll down to the floppy and hit enter ot the corresponding key form the bios's legend at the bottom or right hand side of the screen untill you see disable.
Next you can navigate to Save & exit or hit F10 to do the same. G/L.
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Dell2 2400 BIOS F2 reads backwords.
It sounds like you may have the IDE cables hooked up backwards on your motherboard.. The IDE cable slot on the motherboard labled IDE1 should be where your Hard drives are if you want them to read as primary. The Optical drives are usually on IDE2, designating them as secondary.
Let me know if you need more help.
Mar 12, 2009 | Dell Dimension 2400 PC Desktop
Problem with Dell Dimension2400PC
Hit F2 to run setup.
At the HDD set up portion leave Primary drive as it is.
Set the Secondry drive to none or automatic.
Nov 05, 2008 | Dell Dimension 2400 PC Desktop
I've installed a new hard drive and put in more RAM on my Desktop. Now i get this message WHAT DO I DO. The amount of system memory has changed. Primary hard disk drive 1 not found Strike the F1 key to...
Strike F2 to go to the bios to run the setup utility
Don't touch anything , save and reboot
If primary hard disk still not found
reboot press F2 to re-enter the bios
Look for Auto Detect Hard Disks
if the computer shows a hard drive is detected
set the drive to LBA if possible
save and reboot
Az.
Sep 15, 2008 | Computers & Internet
Hard Drive hook up
usually on the Dimensions, it's a blue or grey SATA cable that goes from the drives to the motherboard. Dell has those as accessories, amongst others online
Apr 24, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
768 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
