Question about Samsung Jet S8000 Cell Phone
Can i make the incoming call ring for longer doesnt seem to ring long enough to answer it
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Have problem changing auto answer to longer than 3 rings
Press and hold the SET button to enter the change mode. The unit announces the current time and day. Press SET repeatedly until the unit announces the rings to answer. Press and release NEXT or PREVIOUS until the unit announces the correct number of rings for the answerer to pick up. Once the rings to answer is set, press SET to enter the incoming message length menu.
If you need a manual, you can download one here.
Oct 31, 2010 | GE 29868GE1 Digital Answering Machine
I have a Uniden 5.8GHz DSS8955+1 and it's connected to my phone and fax. The problem is: everytime the fax rings, the answer machine works as it works when is a phone call. How do I set up the machine not...
Set your answering machine to pick up after four rings2.gif . This will give the fax machine enough time to take the call if it senses that it's an incoming fax. Setting the answering machine to pick up after four rings would give the fax machine enough time to accept the fax.
hope this was helpful .
Nov 13, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Landline phone does not ring out when there is an incoming call
incoming calls ringer on corded land line phone no longer works
Nov 02, 2009 | Lands Phones
My fax goes off periodicall when a call comes in.
It means that your fax machine is "answering" the incoming call before you pick up the handset. Usually, the factory setting on the fax machine picks up after two incoming rings. There are three ways you can address this issue: 1.) You can either change the number of rings to, say, five incoming rings to give you enough time to answer the phone before the fax machine picks up, or 2,) you can find out if your fax machine has a feature that allows for the voice hook "click over" that will allow you to override the fax when you pick up your handset, or 3.) turn your fax machine off until you need to send a fax.
If you want to investigate number 2.), then you'll need your operator's manual.
Good luck.
Aug 28, 2009 | Office Equipment & Supplies
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 | Cell Phones
CAN'T GET FAX TO WORK
turn off answering mech. count # of rings before fax answers add onemore ring to answering mech. before it answers.
Dec 27, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
WHEN I HAVE AN INCOMING CALL MY FAX MACHINE COMES ON AFTER 2 RINGS HP J5780 HELPPPPPPPPPP
hi,
the issue that you have has something to do with the "Rings to answer", for you to change it follow the steps..
1. press SETUP BUTTON on your printer
2. Scroll down and look for BASIC FAX SETUP, then press OKAY
3. Inside Basic fax setup, scroll down and look for RINGS TO ANSWER, then press okay.
4. It will give you choices there, just look for ANSWER ON RING 6, then press okay,
tadahhhh!! THAT SHOULD WORK.
thank you so much.
adonscott
Jul 16, 2008 | HP Officejet J5780 All-In-One InkJet...
Samsung Jet S8000  Cell Phone Logo
102 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
