Question about Gestetner DSm635 Copier
We have replaced the toner cartaridge but it is loose and the machine is still saying toner is low
  • Gestetner Master
  • 1,294 Answers
If the old toner bottle is good change the toner into new bottle in the old bottle,and perform toner forced supply.
Posted on Sep 26, 2009
I have sharp ar-5316e indicator massage error ink.drum. toner
Toner indicator says that there is low toner in the machine. It is necessary to replace toner cartridge and then continue with other error messages.
Apr 29, 2017 | Sharp Office Equipment & Supplies
Print quality
Sounds like the heat drum is bad, did yhis happen with old cartaridge?
Aug 31, 2013 | HP LaserJet 4 plus Printer
I have e-studio 355, machine is indicate low toner. I replaced new toner cartridge but the machine show "toner not recognize". I try to replace the ic at the back of the old toner cartridge and...
Do not go very far yet, the problem is with the toner so I recommend you do what the machine says before looking somewhere else. replace with correct toner.
If you have a friend with the similar machine which is working properly try and get their toner put in your machine if it works buy similar toner if does not then it is the machine. You can also try your unrecognized tone in another machine see the results. The problem is just toner and the sensors in your machine.
Jul 14, 2011 | Toshiba e-Studio 205 Copier
We have a Brother MFC-8840D It states that we need to clean the drum - how do we go about that? Turning the machine off and then on it now says that the toner is low. Are these two separate problems or...
t probably told you to clean the drum because it can't sense toner. I would deal with the toner issue first.
You have about 150 prints @ 7% coverage before it won't let you do anything.
Feb 07, 2011 | Brother Office Equipment & Supplies
I have a Brother MFC-7440N machine. On 7/22/10
The toner cartridges have a small port on the side that the printer uses to check the toner level. Our 7440N tells us it will soon need a new toner cartridge and will then print another 400 copies. Search YouTube for Brother Toner Cartridge and it will show you how to modify the cartridge by covering up the portholes with tape. Since there is obviously some kind of sensor, you might need to get a can of air and clean out any extra toner. Lastly, the Brother cartridges have "reset gears" which are replaced when the cartridges are refilled. You might have a cartridge which the gears were not replaced on.
Jul 26, 2010 | Brother MFC-7440N Laser Printer
Said low toner cartridge. Replaced cartridge,
what is showing toner life end ? rajcanon007@yahoo.co.in
Sep 14, 2009 | Brother IntelliFax-2820 Laser Fax
Replaced toner, machine continues to say toner
Aug 04, 2009 | Brother IntelliFax-2820 Laser Fax
Replaced toner but continues to say replace toner&power failure 8
Anthony here. Had a similar problem, fax didn't detect the new toner. The photo sensor does not detect the toner en the fax is new. Put a black tape where the toner slots into the sensor en walla it worked. When the copies become faint I know that the toner is low or over.
A.K (Nairobi, Kenya)
Jul 10, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Put in brand new toner machines says toner is low.
plull the drum out...and clean the roller....you will be able to see the ink on the roller where your lines are appearing.
Jan 13, 2009 | Brother IntelliFax-2820 Laser Fax
After replacing the toner cartaridge, the error light comes on. In the little box, it says toner is not set. Insert toner. I have readjusted it several times. It seems to be set solidly. The problem...
You have to:
1. take paper out.
2. remove the toner
3. place the toner back
4. printer will "initialize" itself.
5. put the paper back.
Totally crazy!!!
Jun 30, 2008 | Office Equipment & Supplies
Gestetner DSm635 Copier Logo
180 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
