Question about Acer Aspire 5315 Notebook
Some keys dont work and its not sticky key emmm
  • 822 Answers
Try to clean first your key board.
Posted on Sep 24, 2009
Dell inspiron n4030 keyboard not working
Shapsog,
You may need to turn off the Filter Keys option. Follow the steps below to turn them off.
Go to
1. Control Panel
2. Ease Of Access Center
3. Make the keyboard easier to use
4. Uncheck the "Turn on Filter Keys" option
You also may need to Check to be sure you don't have Sticky Keys enabled.
BY PRESSING THE SHIFT KEY FIVE TIMES
Without pressing other keys, press the SHIFT key five times to enable Sticky Keys. A window will be displayed asking you if you wish to turn on Sticky Keys Clicking Yes will enable Sticky Keys or click No.
If none of these steps work you may need to replace the keyboard or plug in an external USB keyboard.
Thank You,
Dell-Jesse L
Dell Social Media and Coimmunities
Oct 19, 2015 | Dell Inspiron N4030 14 Inch Notebook...
Shift key is not working
You might consider using, at least tempory, a external usb keyboard with a touchpad, you can get get them at Wal-Mart for around $20.00
Otherwise consider taking it to a computer shop and have them test the keyboard and if need be order you a new one. If this computer is still under warranty then I would would talk to the support team that you purchase it from. Good Luck.
Mar 28, 2014 | Computers & Internet
What are sticky keys My shift will not work and I keep getting a message about sticky keys
Hi
Please try to press both the shift keys at the same time
this may disable the sticky keys and return the keyboard to normal
this quite often happens when you hold the shift key down for longer than 8 seconds or more
many thanks
Aug 16, 2011 | Computers & Internet
Thats just it they dont work......i cleaned a sticky / ? key, now these keys wont work
It is near impossible to clean sticky keys, especially when you have spill sticky liquid on the keyboard.
The best solution is to replace the keyboard.
You can get a replacement keyboard from one of these WEB sites.
LAPTOP PARTS
http://www.nylaptopparts.com/ www.laptoprepairco.com/ www.laptopparts.com.au/ www.laptopking.com/ www.lappy.com.au/ www.excelcomputerinc.com/ www.laptoprepairparts.com/ www.lapzone.com/servlet/StoreFront www.laptoppartsexpert.com/ www.sparepartswarehouse.com/
Mar 13, 2011 | Computers & Internet
Shift key not working
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
May 29, 2010 | HP Compaq nc6000 Notebook
Cant figure out how to get it off the little blue symbols
Either the "blue" coloured 'FN' is _stuck_ in the "down" position, or you have accidentally activated the "Sticky Keys" Windows "accessibility" tool.
With "Sticky Keys", you press keys just _one_ at a time, e.g., CTRL then ALT then DELETE instead of pressing multiple keys (SHIFT and '8') at the same time.
Restart, in order to turn-off "Sticky Keys".
Or, "exercise" the 'FN' key, until it "unsticks" itself.
May 07, 2010 | HP Pavilion dv4000/dv4200 Series Keyboard
Sticky keys on keyboard
A good idea is to get a cloth (avoid tissues or paper wipes) and give that a spray with some form of window or screen cleaner and go over the keyboard a few times, for really sticky keys, gently remove them and give the underside and the base of the key a good wipe.
If you are unsure how to remove keys, please don't hesitate to reply (i will need the Model of the machine eg: acer extensa 5620)
Please don't spray the cleaner directly on the keyboard and dont use high grade cleaner as this can damage the keyboard
Dec 01, 2009 | Acer Computers & Internet
Both shift keys not working in my laptop
WEl Bro I Read Your Problem ITs A Very Complicated Isse So I have a Easy Solution For It The Solution is that Put Your Key BOard in Water OR Through From the Window OR Put it Into Your Dusbin :D
Jun 29, 2009 | Compaq Keyboard
Problems with the keyboard
Sticky keys can sometimes be fixed by hitting right shift key 10 times quickly (I'm not lying!!), and or the culprit key (x) the same way. Try that and if it doesn't work, reboot and type. If it continues, please try another keyboard.
Nov 20, 2008 | Computers & Internet
Sticky keys
Dear rwertheim
Try the following guide
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/
There are no guides from Gateway for the keys available for the but this guide will be more than enough to help you through this one in order to remove them. Its should be completely the same principle.
Cleaning the keys should be done without alchohol based cleaners because the lettering might be erased. Use some soap and warm water instead and gently scrab with a soft brush the bottom of the keys.
Please remember to take out your laptop battery/ac adaptor in any case since you will be working at hardware level with your equipment.
Regards, and I wish you no more sticky keys!
Please dont forget to rate this solutin!
Apr 02, 2008 | Gateway MX8711 Notebook
Acer Aspire 5315 Notebook Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
