Question about Kohler K-3444-0 White Serif Two-Piece Elongated Toilet K-3444
Leaves a ring which appears to be rust from bolts
  • 67 Answers
The bolts used in installation may not be stainless steel also if you see rust stains along with moisture you may be in need of a new wax ring seal which will give the opportunity to install stainless bolts and kill 2 birds with one stone so to speak.
Posted on Sep 24, 2009
Best way to remove 4 rusted bolts on inner tub? Vicegrips didn't work.
Vice grips are the worst thing to use as they do not fit all the seven edges like a correctly fitting ring spanner or socket does. Spray is with a penetrating oil like diesel fuel, Liquid Wrench or WD40, wrap in cling film and leave overnight. Spray again and undo.
May 25, 2016 | Washing Machines
Loose toilet
Get a package of toilet shims from a hardware store. Look at the bolts on both sides of the commode that mount to the floor. There may be covered with a cap. Slide shims under the ceramic until the rocking stops. Carefully tighten the bolts until the unit is solid.
If the flange bolts are no good, you can change them (again the hardware store), but you will have to remove the commode and replace the wax ring before resetting it.
Apr 07, 2015 | Home
Car overheating smell antifreeze outside the car
The lower end of the top coolant hose is connected to the water pump with a fitting that has an "O" ring . The fitting rusts away causing a leak. The fitting is secured to the engine block with two small bolts just past the end of hose. Remove the bolts and pull it out You will likely need to replace the fitting and "o" ring. Many head gaskets have been lost due to this. LOL
Mar 19, 2014 | 2003 Chrysler PT Cruiser
Diseases of rose bushes
My rose bushes have what appears to be rust on the leaves.
It is still blooming and putting on new growth. But leaves are
turning yellow and falling off. I planted them this spring. I have three out of eleven effected. Not side by side.
Jan 07, 2014 | Health & Beauty
Fridge washer GLWS1349AS0, have inner tub out, trunion lifted, not off yet due to slight rust. How do I change spin bearing and tub seal? thanks.
To remove the trunion totally reattach the inner tub to it and twist the inner tub,with the tub attached it gives you much more leverage to twist and pull the trunion off. After its off pull the small brass ring with the O seal in it up the transmission shaft and pop the tub seal off. To replace tub bearing remove the bolts on the side of the side of the outer tub off from the tub support and pull tub off of trans. shaft. to remove bearing flip tub upside down and remove the 2 screws from the tabs on bearing and turn tub back right side up and use a screwdriver on the top of bearing and knock it out of outer tub,push new bearing in by hand most of the way,being sure the tabs on bearing is lined up w/notches on tub and use old bearing placed on top of new one and drive it down all the way,reinstall screws into tabs. All the surface rust should be sanded off of trans shaft. Re install outer tub and secure with the bolts into tub support. push main tub seal into flange with normal palm pressure,install new brass ring and MAKE SURE O RING DOESNT POP OUT OF IT ( a little dawn,palmolive joy liquid dishwashing soap around inner part of o ring inside of brass ring will help it slip on easily) I use the old brass ring and press it over new brass ring to assist in o ring not popping out,once new brass ring is inserted ok and oring in place remove and discard old brass ring. Reistall trunion and inner tub ECT ECT ECT
Gene
Aug 12, 2011 | Frigidaire GLWS1349A Top Load Washer
The bolts are super rusted on the exhaust and i cant tell if there just rusted on there or if theyre welded on there from the factory what should i do
try soaking them in a mix of engine oil/diesel and leave for a day or so to soak in and then see what happens
Mar 04, 2011 | 2001 Ford Escort ZX2
Ford escort 2001 van changing brake pads the connection bolt appears to stick when nearly out of the hole
thats because the end of the bolt is rusty,and has expanded slightly with the rust.(did you know that a rusty bolt is heavier the a clean one.....)
May 24, 2010 | 2001 Ford Escort ZX2
Looks like the oil is leaking out right above the
oil filter screws onto an adapter housing which also has the pressure sending unit on it (above oil filter). This adapter housing bolts to the block with 3 bolts. if oil appears to be leaking from where the adapter housing meets the block (especially at the rear side of engine near bottom), then you need to replace the siamese o-rings between the adapter housing and the block ($12 part at dealer). remove lowest 12mm bolt and loosen top 2 12 mm bolts(top 2 bolts won't come out unless you drop the engine down, but loosening 1 inch is all you need), replace o-rings and retighten bolts. be careful not to get dirt/grit between block and adapter. just finished doing this to son's 95 2.7 v6 which was leaving an 8" puddle of oil after idling for only 1 minute-worked perfect
Feb 24, 2010 | 1995 Honda Accord
How difficult is it to cange the front rotors?
depending if you have the tools to do the job and pb blaster lock tite and white and dark grease for a beginer it has a rating of 7-8. if you work on cars and know what your doing, then its easy.. first thing is to remove the calapers then remove the calaper mounting bracket spray around the studs and bolts with pb blaster also around the hub and tap around the whole area around rotor dont hit the studs (with hammer) to break the rust buildup this should break rotor free then you may want to clean the rust off so that the rotors seat properly remove and clean new rotors with brake cleaner to get off the film off them (shipping rust retardent) and wipe. spray bolt holes to clear any rust left while removing old rotor and braket and dry. place a small ring of lock tite on bolts holding caliper brackets and let stand till harden or almost hard. replace new rotors install bracket/s and bolts (torq to ? 80foot lb) while replacing rotors replace brake pads, replacing just rotors will over heat new rotors in spots and warp rotors!!! make sure you pull the pins that retain the calipers to the bracket and add light coat of white grease to pins so calipers slides easy and evenly
Jan 21, 2010 | 2003 GMC Envoy
Do I need to descale or rust treat my Washing Machine?
  • this is a common problem with aging kenmore washers (leaving coins in your pockets speeds it up).
  •  the basket is metal with a porcelain coating. the porcelain coating wears around the edge of the holes in the basket first, leaving bare metal.
  •  when the washer spins the centrifugal force pushes the clothes against the basket and a little into the holes. this leaves little rust rings on your clothes.
  • lumpy816 is correct in saying that your basket should be replaced. it does require a special tool, and the basket is expensive.
  •  in the mean time try to take the clothes out immediately after the washer stops spinning. and if you get desperate you can clean thee inside of the tub with a rust remover like LCR or a strong toilet bowl cleaner that removes rust.
Jun 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kohler K-3444-0 White Serif Two-Piece Elongated Toilet K-3444 Logo
61 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
