Question about SanDisk Cruzer Micro 2GB USB 2.0 Flash Drive
Any time i try to eject a combo comes up with the message that the flash drive has a program running even though all file are closed. how do i get arround the problem.
    President:
  • 1,653 Answers
Cruzer's run a program when they install and should appear on the screen as a red Cruzer icon. If you click on this when you want to remove the you can then select the Eject tab on the bottom of the Cruzer popup. Use this rather than the windows eject which does not work too well.
Posted on Sep 24, 2009
Error 1407 external drive
That's a Mac error stating that the file you are trying to delete is currently being accessed.
First, close all open programs and try to delete the file. If that doesn't work, eject the drive by clicking the eject button in a Finder window. Disconnect the drive. Reboot. Then reattach the drive and immediately delete the file.
Feb 17, 2014 | Verbatim STORE-N-GO (95312) 8 GB Hard...
WD external hard drive mac
Sounds like your external drive might be bad. Try connecting it to another system and see what happens. If you can't get to read data on another system, the drive is bad.
May 29, 2012 | Western Digital My Book Essential Edition...
Windows cannot find rundll32.exe
Are you getting a window that pops up asking you to select which program to open with when you click on anything? If so your program file associations have been changed by a virus or infection.
Try restoring them by running the programs from the link below. Run each one of them. Don't worry, they are safe, tried and tested many times to get things back in order.
http://www.dougknox.com/xp/file_assoc.htm
Apr 18, 2012 | Acer TravelMate 5740-6529 - Core i5 430M...
PNY flash drive will not eject
right click in the bottom toolbar select task manager to see whats runnng in applications also in processes to see whats ticking over
it might be your antivrus or another program thats runing
also
try right clicking on it windows explorer select eject
also you might have to resore it to default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
hope this helps you
Apr 17, 2012 | PNY Electronics - Others
When trying to remove the memory stick this notice appears the device'Generic volume' cannot be stopped right now. try stopping later. what does this mean and how do i fix it
1. this is a message letting you know that the computer is using a file on this drive.
2. You need to release the file in use that is close all programs then eject the flash drive properly using Windows ejection program.
c. You have checked the user manual 1st.
Please give detailed information as to your issue to better assist you in your resolution of the problem you are having.The more information given will help determine the resolution and guide you to the proper fix for your issue.
Thank you.
Jun 14, 2011 | Sony Micro Vault Pro USD-2G (SONYUSD2G) 2...
When trying to eject my usb flash drive, I get a message-- the device "generic volume" cannot be stopped now, try later . This has been locked up for about 2 hrs. now.
This happens when a program is still writing data to the USB when you are trying to unload it from your PC. Dont pull the stick out where possible, as this risks losing data. (Though most times it's fine in my opinion)
Generally, most people close off the programs that are no longer using the USB before they unload it but certain programs 'link' together. For example, depsite you closing the MS Word document after saving it to USB, MS Word is also directly 'linked' to MS Outlook. If your outlook is still running, this may affect it. Try closing ALL programs (where possible) and ejecting the volume.
Alternatively, download a program called "unlocker"
http://ccollomb.free.fr/unlocker/old/unlocker1.8.6.exe
This will load a popup into the menu that shows when you right click the drive from 'computer' Just click the 'unlocker' command and the drive should eject normally.
Aug 25, 2010 | HP Pavilion dv6000z Notebook
Problem ejecting my fujitsu external drive even all programs has been closed, even if the laptop has already been restarted. how to eject safely without damaging the external hard drive?
With USB devices you can go down to the clock section of the task bar and click on the << symbol to expand it. Pass the mouse over the icons and find the one that says USB devices. Open the service and select the drive you want to remove. Then choose stop service and it should shut down the drive and give a message saying it is safe to remove the device. Good Luck
Jul 21, 2009 | Fujitsu External DVD/CD-RW Combo Drive...
No communication
Is it displaying in device manager or it is not at all detecting. In that you may try with it some other system and same problem persist, there is possiblilty for damage. send it for warranty calim. Pen drive easily does not die. Check it in other system.
Any application or data is talking each other with computer and usb drive, then it gives warning try to close all application or any virus infection is there.
Apr 12, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Aspire 4520 DVD combo problem
try uninstalling the drive in device manager then reinstalling it allso check for bad connections
Oct 14, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
SanDisk Cruzer Micro 2GB USB 2.0 Flash Drive Logo
187 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
