Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Freezer and fridge not cooling - Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
  • Brian Chambers Sep 25, 2009
    turned out to be some type of starter module that connects to the compressor, has a start , run feature.
    Thnaks for the help everyone!!!!
    President:
  • 632 Answers
Check the following:
  1. Low/No Refrigerant: If the evaporator is warm, the ampere reading is low (compare with motor specifications), pressure reading is low, and evaporator is warm, find any leak and repair, then recharge refrigerant. Use soap bubbles to find leaks.
  2. Loose compression: If pressure reading is low, ampere reading is low and low side and high side have the same pressure, replace compressor and recharge refrigerant.
  3. Oil in accumulator: If none of the above symptoms is present except that the evaporator is warm, Purge the system and remove oil then recharge the system (refrigerant).
  4. Restricted drier or capillary tube:
    If the strainer drier is cold, replace strainer/drier. If no hissing of refrigerant into the evaporator, replace capillary tube. Replace refrigerant.
  5. Thermostat; If the thermostat trips for a short period of time, reset it.
Posted on Sep 25, 2009
  • Jan McZeal
    Jan McZeal Sep 25, 2009
    N.B: Assuming compressor is running.
  • 432 Answers
Compressor not on most likely.listen for a low hum inside or low down close to the floor in front of it.If no hum its not on.depending on age you can install a hardstart for it and get more life out of it.
Posted on Sep 24, 2009
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
Fridge light on but fridge warm, freezer still working. zanussi built in fridge freezer 3 year old
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Refrigerators
Fridge freezer works but fridge element back of fridge does not defrost completely leaving lump of ice
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 16, 2011 | Electrolux Freezers
Freezer temp is wear fridge shoud be.fridge temp 55 degress.
Check the fan in back which cools the compressor . Also check the coils to make sure they are clean of dust , lint , etc...
Aug 02, 2009 | Magic Chef CTB1821AR Top Freezer...
Jenn-Air JCB2389GRS Fridge not cooling properly
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
puiodf
Mar 15, 2009 | Jenn-Air JCD2389G Side by Side...
GE Side By Side top portion of fridge and freezer not cooling
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Fridge part of fridge freezer not cooling
heatman101
Aug 16, 2008 | Hotpoint FFM90 Bottom Freezer Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
194 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
