Manaully open a disk player for a emachine
I own a EL 1300 G emachine desktop computer. It is infected and will not let me open the disk player how do I do this manually?
    Problem Solver:
  • 6 Answers
There's a small hole in the front of the disk drive close to the base of the tray and near the button used to open the drive. get a paper clip, open one end, hold carefully, and place it in the hole and push carefully till the drive opens.
to close, just push the tray back in firmly but without slaming it in. don't want to damage any of the gears inside.
Posted on Sep 24, 2009
  • 47 Answers
See the front of disk player you seem a little hole pin size inseart pin inside the hole door become open
  • 385 Answers
Hello Jroot929,
to open the disk player manually, you will need a regular size paper clip.
Straighten it out.. then look at the front of your disk player and look for a small pin size hole.. insert the paper clip into it, pushing it a bit, you may feel a small resistance but just push it..the player will open at this moment a bit.then just pull it out. Hopefully this helps.
Drivers emachnes el1352
Go to this link http://www.emachines.com/support/drivers.html
Select Product Family: Desktop
Select Product Line: EL Series
Select Product Model: EL 1352
Select the Operating System you are using.
It will automatically display the available drivers for your computer after you select the Operatiing System.
See the picture below for your guide.
Keep me posted.
Jas
Feb 18, 2011 | E-Machines eMachines Desktop PC
Can't reboot my emachine...keeps telling me insert system disk....I have no system disk...the model number is El 1200-08w
ts looking the registry error in ur system so do a registry repair scan with Intel software partner Reg In Out registry cleaner
Aug 31, 2010 | E-Machines (T2958) PC Desktop
I haved a Emachine EL 1300G-01W that has crashed
Power it down, pull the power lead out, remove the cover from the base and check that all the leads (to the hard drive and the motherboard) are seated correctly - by physically pushing them in. Then push and hold the power button on the front for 10 seconds. Then replace the cover and power lead and try starting it up.
Jun 05, 2010 | E-Machines eMachines Desktop PC
How do you open computer to insert wireless card?
There should be 2 screws on the back. The side panel will slide off and then you can insert it into a PCI slot.
If its a laptop get it done professionally
May 20, 2010 | eMachines EL1210-11 PC Desktop
Completing a recovery without a disk?
This is a common virus attack that will throw you out everytime you login, or licensing issues
For virus problem is bit tricky and needs to deal with registry settings and also need network computer
Try following
Log on to a networked computer.
Run Regedit.exe
Point your cursor to HKEY_LOCAL_MACHINE
Select File > Connect Remote Registry
Type computer name (infected computer)
Navigate to the following location in registry of destination or infected computer
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
Edit below two values in right pane:
Shell
Userinit
Change the two values to
Shell=explorer.exe
Userinit = c:\windows\system32\userinit.exe
close the Registry
Restart Infected computer.
You should be able to log on to computer. if it not work then go to back steps and just copy and overwrite the file userinit.exe from installation source.
May 17, 2010 | E-Machines eMachines Desktop PC
My emachines EL 1200 desktop stopped working during bad storm
You can try to reset the computer by removing all power sources and letting it sit for a time. Then powering it back up and see what happens. That's called a hard reset.
I am guessing that the storm surge damaged your motherboard. The power supply is working or nothing would work. Try to hit the proper F key and get into the set up on the motherboard. A message should come up when you start up the computer. This is to see if your motherboard is working enough to open the set up. You can then tell it to reset to bois to factory settings.
If none of that will work, I suspect *********** board is bad and needs to be replaced.
I am sorry I don't have more positive information for you. But I hope that this will get you on the right track to solving your problem. Remember, this is only an educated guess. If you do find this helpful, please leave positive feedback for me.
Thank You,
Brian
Jan 25, 2010 | Computers & Internet
My computer makes a loud noise in the fan
The drive door issue may indicate a virus infection. As to the fan, you would have it replaced. If not under warranty open the case and track which fan the noise is coming from
Mar 25, 2009 | E-Machines eMachines Desktop PC
Crashed hard drive on emachines T5026
Pardon me, but NO! The statement, "two things are responsible for booting up computer RAM and Hard Drive" is simply not true.
A hard drive crash COULD cause the symptoms you describe, but that is more indicative of a virus infection. When you say the XP reinstallation disk would not start it exactly how did you use that disk? Attempt to use the repair console? Boot directly from the disk? Attempt reinstallation of the whole operating system? If you attempted reinstallation, do you also have the specific drivers for all of the components E-Machines used when they built your computer (you will need at least some of them.)
Post again with some more details about how you used the reinstallation disk.
Feb 24, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
173 people viewed this question
David Payne
David Payne
