Question about RCA RCR311B Remote Control
I cannot program my remote. my husband said to hold down the tv button and the power button until tv came on. once it came on he told me to keeping pressing the power **** until the tv went back off and then to press the stop button. is this correct because i am having no luck.
  • 403 Answers
Try this:
Go to this link to download a PDF manual for your remote. Just follow the directions to download. Save to a file on your computer and you'll be able to view it.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Hope this helps, let me know if I can help you with anything else.
JimmyC
Posted on Sep 30, 2009
How to program Direct TV remote
How to program your DIRECTV remote control:
Press MENU on remote.
Select "Parental, Favs and Setup".
Select "System Setup".
Select "Remote".
Select "Program Remote".
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
Look up the control codes for your DIRECTV remote control.
Make sure your TV is turned on.
Slide the mode switch at top of remote to "TV".
Press and hold the MUTE button. This is located above the number 1 button.
While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
Enter the first TV code you have. The green light on remote should flash twice.
Aim remote at TV and press PWR button once. The TV should power off.
Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6, and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
Then enter 9911, the green light on remote should flash twice.
Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
When the TV powers off, press and release the SELECT button.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
You can find more help in the Remote Controls section of our Technical Forums at forums.directv.com. You can also use our Interactive User Guide to learn the ins and outs of your remote control.
Apr 11, 2012 | Audio Players & Recorders
Hi i have MAXENT TV 50" plasma im loking for dish network remonte code to program on it please help
We show no codes listed for Maxent televisions. The best method for programming this remote is called a Power Scan, the steps are below:
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
May 08, 2011 | Maxent MX-50X1 50 in. Plasma Television
Cant progam not understanding the instructions
The best way to program with this remote is to follow these instructions.
1. Turn the device you wish to program on by hand 2. Press and hold the key for the device you are programming. (If it's a TV hold the TV button etc.) 3. While holding the button down, press and hold the power button down until the light turns off, and then back on. Once the light is back on release both keys. 4. Now, while pointing the remote at the device, hit the power button until the device turns off. Once the device turns off, you have found the right code. 5. Hit the stop button on the remote in order to save the code, and program the remote to that device.
This should work for most universal remotes these days. It might take you a long time to find the right code as well, the code list is very long so you just have to keep chugging through them. I've reprogrammed this type of remote many times and have hit the power button for over 5-10 minutes before the device turns off. Best of luck to you.
May 04, 2011 | RCA RCR350 Remote Control
What is the code to go whith the spongebob tv on the dish network
I would suggest using a Power Scan to program the remote to this TV, if this doesn't work there is a compatibility issue.
Power Scan
Daniel Busa
DISH Network
Customer Service
Mar 27, 2011 | Emerson SpongeBob SquarePants TV
Have lost instructions to Emerson universal jumbo remote
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Retrieving the Code for your Device:
If you used the code search function to program your device and want to know the code for future reference, you can retrieve the code from the remote. To do this:
1. Press and hold the Code Search for 3 seconds until the light stays on.
2. Press the device button for the code you want to retrieve. Press TV to get the TV code, etc. The light will blink once and stay on.
3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
Programming the Sleep Setting:
1. Press and hold the "SLEEP" button until the light stays on.
2. Use the number pad to enter 2 digits for how many minutes to use for the timer (01 to 99 minutes). The light will turn off and start timing.
3. Make sure the remote is pointing at your device.
4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
Here is a list of the Emerson Universal Codes:
http://www.jumboremotecontrol.com/remote_control_code_list.html
Here is a copy of your manual: http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
Mar 08, 2011 | Televison & Video
How do you program an RCA "RCR 615 DCM1" universal remote? Any instructions out there?
I know this is an old post, however if anyone else needs to know how to program the RCA RCR 615 DCM1 universal remote here is how: Turn on the device you wish to program, dold the device button you wish to program (tv, vcr, dvd, etc.) While holding the button with one hand, press and hold the power button with the other, hold both buttons until the device button lights up and stays on then release both buttons at once. Light should remain on. Point remote toward the device and press play button every 5 seconds until device shuts off. Once the device shuts off, with remote still pointed toward the device, slowly hit the reverse button (rewind button) until the device turns on again and then hit stop button. Now your device should be programmed. Repeat for each device. Hope this helps someone, because I had this problem myself and I played around with the remote until I figured it out . This may work for other RCA RCR----- remotes as well.
Apr 29, 2010 | RCA Universal Remote Control
Cannot remember how to program remote
Turn the TV on, press and hold the CODE SEARCH or SETUP button until the light light comes on,then release, press TV button,the light will blink once and remain on, press and release the POWER button until the TV turns off, wait two seconds and keep press the POWER button until it turns off every two seconds,once it turns off press ENTER or SAVE...hope this was helpful...
Apr 21, 2010 | GE RM24970 Remote Control
Need rca crk17sa users guide for codes for Magnavox TV
Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
http://www.directv.com/DTVAPP/content/remote_codes
Here's how to program your DIRECTV remote control:
  1. Press MENU on remote.
  2. Select "Parental, Favs and Setup"
  3. Select "System Setup"
  4. Select "Remote"
  5. Select "Program Remote"
  1. Look up the control codes for your DIRECTV remote control.
  2. Make sure your TV is turned on.
  3. Slide the mode switch at top of remote to "TV".
  4. Press and hold the MUTE button. This is located above the number 1 button.
  5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
  6. Enter the first TV code you have. The green light on remote should flash twice.
  7. Aim remote at TV and press PWR button once. The TV should power off.
  8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
  1. Make sure your TV is turned on.
  2. Slide the mode switch at top of remote to "TV".
  3. Press and hold the MUTE button. This is located above the number 1 button.
  4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  5. Then enter 991, the green light on remote should flash twice.
  6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  7. When the TV powers off, press and release the SELECT button.
Mar 08, 2010 | Televison & Video
Rcr4358 have the code but how do I program it in I don,t have a :code search button: which button do I use?
Hold down the tv and power button until it turns red
Then press play once the light will blink once it stops if the t.v. has not turned on press again then continue until the tv turns on.
Press reverse until tv turns off
Hold down stop until light goes off
Apr 02, 2009 | Televison & Video
Program bell expressvu remote for new tv
The easiest way is to do device code scan. Since you want to program the TV, hold the TV button on your bell expressvu remote. When all the top buttons light up, press the power button, the TV button light should remain lit. Keep pressing up/down until your TV turns off. When your TV turns off, press the # button. Thats all. Your done.
If you want to set up the AUX button, hold the AUX button until all the buttons light up. Then press * and either
0 - second TV
1 - second VCR/DVD player
2 - audio amplifier or cable box
Then press the power button and press up/down until the device turns off. The last step is to press # and your done.
Oct 22, 2007 | Televison & Video
RCA RCR311B Remote Control Logo
96 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
