Question about Maytag Neptune MCE8000AY Electric Dryer
Maytag mcg8000aww wont get hot.
The top part of the dryer gets hot, but the bottom doesnt. Any ideas why?
  • 5 more comments
  • brentr547 Sep 24, 2009
    Lint trap is cleaned every very regularly. I removed the exhaust hose last night, and it was very clean. Also reached into exhaust coming out of the back of the dryer and found very little lint. If it is a heater element, can you supply part numbers? Also is the top part of the dryer electric, or does it have its own heater element.
    Thank you
    Also my dryer is a mcg8000aww, the email sent to me said the answer to my question was for a
    mcg8000ay. Are these different or the same?
    I have already cleaned out all of the ducts. If it is a heating element, do you supply part numbers. Also is there two elements, or is the top part of the dryer electric?
    yes the blower is working.
    Iam not sure if my replys are going through. I get fast response to my original questions, but when I choose to keep working with someone, I get no response.
    I am happy with the answers I am getting, but each time I try and ask the same expert another question, I get no replys. The only way I know how to do so is to ask a new expert. The tumbler works, and the blower works.
    Thank you
    The last expert that answered, obviously read my description wrong. He gave me instructions to fix the upper part of the dryer. The upper part works, the bottom part does not get hot.
  • 6,927 Answers
I am not sure about the maytag,but some of these types have dual heating elememts,if so,the element for the bottom has burned out.If it is vent controlled,then lint has buit up and blocked the vent from heat air flow to the bottom.
Posted on Sep 24, 2009
  • Maytag Master
  • 19,396 Answers
There is no heating element, the expert answering should have gathered more information on your model.
The first part to test, that is probably responsible for your problem is the steamer liner thermistor. Part 9 on the first diagram below.
This sensor will affect only the upper part, and if it is defective the upper steamer liner section will not work.
Here the part:
PS2031187
THERMISTOR, TEMP CONTROL Part 9 on diagram.
The thermistor is tested setting the multimeter at Rx1, cutting one of the thermistor wires, and reading Ohms. The thermistor must read near zero at room temp, and return infinite impedance at limit temperature (about 180).
If thermistor is OK, then check wiring:
PS2031151
HARNESS, UPPER HEATER Part 2 on diagram below
and
PS2031226
HARNESS, UPPER HEATER Part 5 on diag.
Check also PS2031064 DOOR LATCH ASSEMBLY (UPPER) , it is connected to control board, and can affect heating.
If you think that my solution had been helpful, please do not forget to rate the solution, or you will reward the expert that did not even bother in searching the details of your appliance model.
If you need further help , please ask. I usually get back online to answer every couple of hours.
Thanks.
G.
    President:
  • 1,129 Answers
First check the obvious check the exhaust to make sure it is not obstructed in any way it is also possible the the lint trap chamber is loaded up with residual lint that got past the screen or has been packed down inside. Call around to some local hardware stores to see if they carry a cleaner that looks like a oversized pipe cleaner brush that can be fed down into the area where the lint screen is inserted. Id this doesn't solve the problem you may have a heater element issue.
    President:
  • 1,723 Answers
Is the 'blower' working? Turn it on and go to the dryer vent and check for air flow, Is it blowing?
  • Craig Butler
    Craig Butler Sep 24, 2009
    I'm back, may I ask what you mean by the top gets hot but not the bottom? Please try and explain exactly what is happening. I will wait.....
  • Craig Butler
    Are you sure the switch is not in a 'cool down' setting? Have you tried other settings?
How to take a maytag dryer apart model mcg8000aww
Go to www.repairclinic.com and enter mcg8000aww. You will be presented with a list of common replacement parts and may be able to view a generic Maytag disassembly video.
Nov 03, 2016 | Maytag Dryers
I have a maytage neptune mcg8000aww, the machine is plugged in but there seems to be no power to it.
bad thermal shut off fuse , this burns out usually due to overheating, so just replacing it wont suffice? check ur venting and cycling thermostat also.
Aug 31, 2014 | Maytag Neptune MCG8000AW Gas Dryer
No power to maytag neptune drying center mcg8000aww
Sounds like the thermal fuse is open, which generally means the vent is clogged
Drum of Maytag dryer Model # MCG8000AWW is becoming black and dirty
I would start by taking the dryer back off and cleaning all the lint out. on mine there was lint by the burner and burning and blowing into dryer
Apr 06, 2014 | Maytag Neptune MCG8000AW Gas Dryer
Trying to take cabinet off my MAYTAG MCG8000AWW dryer. Need to replace the motor pulley. It broke off.
And you can't find that first screw that undoes the whole thing? I am not familiar with this unit, but have found that most dryers magically open the same way. If you open the dryer door and look around where the dryer door seats, you "may" find 2 screws that hold the top down. Take those screws out and the top will lift up and then you need to look inside the front panel to find a couple of other screws which hold the whole can of worms together. Be aware, once you loosen the front panel, the drum rides on that panel so you need to support the drum when you remove that panel. Hope this helps
Oct 18, 2013 | Maytag Neptune MCG8000AW Gas Dryer
Where is the ignitor located in the maytag mcg8000aww
inside the burner funnel tube at the bottom of the dryer below the drum,you need to remove the front panel to access the ignitor
Aug 26, 2012 | Maytag Neptune MCG8000AW Gas Dryer
Maytag MCG8000AWW no heat. I can see the ignitor glowing
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 16, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Maytag MCG8000AWW gas dryer no heat
The ignitor may be bad you can chek to see if there is 110volts when the dryer is allin by unplugging the wire to the ignitor and putting using a multimeter to chek for voltage at the wires. If there is power to the ignitor and the ignitor is not glowing up then the ignitor is probably bad replace the ignitor.
Jan 12, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
269 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
