Question about LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone
INTERNET CONNECTION FAILING
HYA. WHEN I COME TO SWITCH ON MY INTERNET, ON MY PHONE, IT JUST KEEPS LOADING AND THEN IT WILL KEEP LOADING FOR AGES. IT NEVER USED TO DO THIS.. AND THEN IT WILL SAY CONNECTION FAILED, EVEN WHEN I HAVE FULL SIGNAL??
Kitkat upgrade download keeps failing
Keep insisting. If your internet connection is appropiate, it should update.
If still can't update, return it on warranty becuase it should have some problem with wireless adaptor.
Jun 13, 2015 | Tablets & eReaders
I have Toshiba Satellite A100 running Windows XP and connecting via wireless to D-Link DIR-615 router. I can get a connection and access the internet but the pages take ages to load. I also have two...
You have a slow computer. To speed up page loading you might want to add an ad blocker to your browser to speed things up since the ads take up memory resources and slow down your computer.
Aug 23, 2017 | Computers & Internet
The model is a SoundPoint IP450. The problem is
are you using this ip phone as your computers internet switch?is your internet cat-5 cable going straight into the ip phone, then another from the ip phone to the computer to supply the internet? if so whoever ran the lines for the ip phone did it wrong. the tech should have run a seperate cable for the ip phone, and plugged the other end into a 4, 8, 24 port switch. he also should have run another seperate line to your computer for your internet, and had the other end plugged into the same switch. apparently he was too lazy. the ip phone is not meant to be a switch. the person who made the ip phone figured you would use ither the internet or the phone, not both at the same time. have a seperate line run to your ip phones and you will never have this problem again.
Jun 04, 2010 | Computers & Internet
I cant send any messages keeps saying hook uo to
Switch off your broadband connection for ten seconds and try to switch it back on. Go to control panel and click Internet connection as soon as wizard displays. Examine if the settings is enabled. Close the control panel and open run command and type cmd. After typing, when it prompts a command, type ipconfig and see if IP address and provider is listed with gateway and subnet. If it has all the addresses, so you can connect back to GMAIL. Thanks.
Jun 20, 2009 | Google Gmail
I have problems playing videos on my laptop off the internet just keeps stoping and loading all the time and the sound keeps cutting off
The trouble is with your metwork connection through which the Laptop connects to the Internet. There is no proven way to increase the speed of connectivity. You may check your connection speed from the two-computer icons on the bottom-right corner and determine the speed. A speed of 2 mbps or more is ideal for viewing videos on internet.
Sep 08, 2008 | Computers & Internet
Dns number failing
The DNS number is the connection you are getting from your Internet Service Provider. When you get this failure, it means nothing else is gettin internet. (should mean that.) I would call them to ask,.
May 20, 2008 | Microsoft Xbox 360 Console
Psp keeps loading
http://www.answerbag.com/c_view/2832 go to that link sir! search your problem in their!
Apr 01, 2007 | Sony PlayStation Portable (PSP) Console
LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone Logo
362 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
