I replaced bulb on pt60lc13 and did steps to reset timer, however screen won't come on so don't know if it reset. Power button flashes for about a minute then flashes red continuously. Lamp light flashes every few seconds. Please help if you can, thanks!
    Problem Solver:
  • 10 Answers
Make sure that your lamp is install correctely or that the door closed properly. After a proper lamp installation you should get a blue screen with a sign prompting you to reset lamp timer, follow up instructions and reset it.
Posted on Sep 24, 2009
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
How to reset tv lamp on mitsubishi wd-65831
RESET LAMP TIMER
    • 1 Turn on the television after replacing your television's projection lamp with a new unit. If a dialog box displays on the screen asking you to reset the lamp timer, use your remote control's "Arrow" buttons, highlight "Yes" and press "Enter." If the dialog box does not appear on your screen after turning your television on, proceed to the next steps.
    • 2 Turn on the television, then press the "Menu" button on your control. Navigate to the "Setup" menu, press "Enter" and choose "Low Powericon1.png" from the menu options displayed on the screen. Press the "Exit" button on your remote control and turn off the television.
    • 3 Repeat the first step to reset your television's lamp timer. If your television screen is unable to produce a picture after replacing the projection lamp, press the "<", ">" and "Power" buttons on your remote control at the same timeicon1.png to reset the lamp timer.
Read more: http://www.ehow.com/how_7358147_reset-lamp-timer-mitsubishi-65731.html#ixzz33n0pJu2S
Jun 05, 2014 | Panasonic Televison & Video
I returned from vacation last night and noticed all four of my coach lights were off. I thought...the timer needs to be reprogrammed due to a power outage while I was away. The red indicator light was...
1) You performed correct troubleshoot steps down the line.
Last thing would be to install defect timer on another light circuit in house, and see if problem is the timer or wire going to coach lights.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) EJ351C has 1 year limited warranty.
Buy new EJ351c and install single pole light switch until timer replacement is available.
Timer has easy 2-wire installation. Turn off power. Connect new timer just like old one was connected. Either timer black wire connects to either wire in switch box.
http://www.smarthome.com/25077/Intermatic-EJ351C-24-Hour-Mechanical-In-Wall-Timer/p.aspx
http://www.amazon.com/Intermatic-EJ351C-Programmable-Mechanical-Security/dp/B000Q9YUGU
Aug 08, 2011 | Intermatic Hardware & Accessories
WOODS 59018 TIMER WIREING CORRECT INSTALLED WITH POWER OFF NETURAL GROUND UP TO CODE LOAD /LINE PROPER.NEW OUT OF BOX WON'T RESET. STEP 1 LAMPS LOAD SIDE GOOD. RETIRED CONSTRUCTION ELECTRICIAN
I don't have answer for defective timer. Buy another timer if everything below checks out:
59018 7-day timer has limited 1 year warranty, and appears to be made by Tork
Timer is for 120Volt single-pole only.
Rated for 1000 watt tungsten, 8A ballast, 1/4 HP
Push reset button with toothpick > not necessary to press-and-hold other button to accomplish reset.
After reset, 12:00 am Monday should display.
Programs are deleted. Reprogram timer.
To check, change and delete specific programming, press PROG key until selected program displays, and then set new programming >>> or press-and-hold MODE button and press PROG button again to delete selected program.
Timer has non-replaceable 30-day carryover battery and does not lose programming after power outage, and will retain programs until battery is depleted.
Review wiring:
Hot to timer black.
Neutral to timer white.
Load to timer red.
Ground to timer green.
Lights will blink if timer red and timer white are connected to load together.
Timer will not function if timer black and red wires are reversed. Display will not show.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Aug 07, 2011 | Woods InWall 7 Day Digital Programmable...
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
Replace air filter warning light to reset?
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Sep 30, 2010 | Filter Queen Defender Air Purifier
TY-LA1001-K I replaced the lamp and didnt restet
I have searched and searched on how to reset the timer. Most solutions say you have to press and hold the volume down button on the tv while also holding down the zero button on the remote, or the pip or split button on the remote until the screen display reads that the timer has been reset to zero or the lamp and power button both flash.
I have tried every combination and cannot seem to reset my lamp timer. If you figure it out, please share it with us!! I'm frustrated and can't get it to work!!
May 07, 2010 | Panasonic PT-52LCX66 Projection Television
Reseting DLP timer?
I dont think you can. The time on there does not matter, if the bulb is going it, it is going out. It does not go out when it reaches the bulb life that i know of. If it does i have never heard of it.
Sep 20, 2008 | Samsung HLP5067W Television
Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Apr 15, 2008 | Sharp Notevision PG-B10S Multimedia...
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Electro Med Services...
