My view sonic plasma tv has a hard time turning on in the morning, i have to keep pressing the power button on and off, as well as a button in the back that shuts off power to the tv, after about 15 min of doing that it eventually turns on and i am able to turn it on and off through out the day. it just happens in the morning.
  • 6,784 Answers
HI. this is begin caused, due to a weak power board. there are several components that are damaged on this power board at this time. i recommend replacing this weak board asap. this will fix your issue.
Posted on Sep 24, 2009
PROBLEM IS VIEW SONIC MONITOR WERE OSD LOCK
osd lock is on screen configuration menu (on screen display) to clear an osd lock in your view sonic you can try this step
1.disconnect power cord
2.press and hold button 1
3.plug again your power cord
4. press your power button while still holding button 1
hope it help you
May 12, 2011 | ViewSonic E70f 17" CRT Monitor
My Visio 50" Plasma Model#
Have you removed the back and looked for Bad Capaciotrs on the power supply board?
Capaciotrs will be vented or puffed up on Top. 1000uf 16v,2200uf 10v 3300uf 10v etc....
Feb 17, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
Power light blinks 13 times
need replaced A-BOARD
Manufacturer Panasonic Part Number TNPH0716ABS Description A- BOARD
After the installation of a new A board, unit has the characters "CHK" on screen. The usual reset procedures of [VOL -] and [MENU] or [OK] or [SLEEP] will not get rid of "CHK".
1. Enter the service mode by holding down the [VOL -] button on the TV (main unit) and simultaneously pressing the [INFO] button on the remote control three times.
2. Press the number [2] key on the remote to highlight [SRV-TOOL].
3. Press the [OK] button on the remote control to select [SRV-TOOL].
4. Use the [DOWN ARROW] on the remote control to scroll down to [PCTC].
5. Use the [RIGHT ARROW] button on the remote to open the box to the right, then press and hold down the [MUTE] button on remote to display Time/Count.
6. Press and hold the [RETURN] button on the remote control until the TV turns off.
7. Immediately press and hold down the [VOL -] button on the TV (main unit) and the [MENU] button on the remote. The TV should come up in the Self Check mode.
8. Remove AC power.
Jul 06, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Tv keeps turning on and off
You probably have blown capacitors on the PSB-power supply board. Recaping with new UF caps works 90% of the time. The set turns itself of into a fault protection to keep from damaging more components internally. A few bucks a soldering iron some solder should do the trick.
Jun 29, 2010 | Sanyo DP50747 50 in. Plasma TV
How to use my external USB hard drive
IF you want to back it up
in the above list you made, click view all files in folders
then highlight all the files and to the left it should say Burn To Disk
click on the burn to disk and follow the on screen instructions
Hope this helps
if not write what other trouble it has
Thank you
Fixa fan
Oct 30, 2008 | Computers & Internet
View sonic projector
Go to menu and choose option. Then choose lamp time or filter time, depending which one you want to reset and keep pressing reset-button for 3 seconds
Jul 23, 2008 | ViewSonic PJ551 Multimedia Projector
Sentry RMC-10 "Really Big Remote"
What I did to program. Hit "tv1.gif" and then hold down "code search" until it turns the light on. Then hit the on/off button until it turns off the tv......it took at least 20 times for me. Then hold down the "tv" button until it starts blinking. Then hit "ok". Mine then worked!
Dec 25, 2007 | Zenith DBZN-311 Remote Control
DVD Player set to display settings unusable on available TV ( resulting in blank picture)
Ok folks, I've found it......turn the unit off.....press and hold the << button on the unit....should be the button closest to the power button....then power the unit on....that's all there is to it....as it turns out, before you set the unit to "progressive scan" it warns you about that and tells you how to reset it...
Mar 24, 2007 | Pioneer DV-260 DVD Player
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
