Question about Microsoft LifeCam VX-6000 Webcam
Camera will not work
Can seam to be able to connect to other cameras
  • 8,637 Answers
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
Posted on Aug 17, 2010
How to replace LCD Screen on a Nikon L18 Coolpix camera
Here is a Quick tutorial on replacing the LCD screen on a Nikon L18 Coolpix camera. You will need a few small tools and a replacement screen, of course, for this fix.
#0 Philips head screwdriver
1.4 mm Standard screwdriver
Plastic knife
1. Start by taking the batteries out of the camera and closing the battery compartment.
2. Remove 6 Philips screws, 3 from the bottom, 1 from each side, and 1 under the AV out flap.
3. Open the battery compartment and gently pry the AV out side of the camera apart. It should snap apart along the seam in the middle. Use your standard screwdriver to pry the back cover off by working it along the seam. If you are worried about scratching the finish you could use the plastic knife once you have it started.
4. Remove the back cover exposing the screen. The screen sits in a metal chassis that holds it in place. Lift the screen from the AV out side of the camera. Under the screen is a ribbon that connects it to the camera. Disconnect the ribbon and remove the old screen.
5. Install the new screen by connecting the ribbon and seating it in its chassis. You can test the camera by installing the batteries and pushing power to see if it functions.
6. Place back cover carefully back over the screen before pressing it in place.
7. Screw it back together and start taking pictures again.
Good Luck and thanks for using Fixya
on Dec 16, 2010 | Cameras
How do I get pictures from internal camera
if you have pictures into the internal memory of the camera and it doesn't seam to appear in the connection ...remove the card ..and connect the camera without i t....(I assume the driver is installed) In this moment it should appear on the my computer folder lnamed like the camera or as storage device ..if it does not sure the driver is installed and after that use a importer from device like the ACDsee program (it has an Import from device feature) or use the windows movie maker to import from device ..and copy the pictures from it ..or save them into a new location ..
Jun 16, 2010 | Kodak EasyShare CX7330 Digital Camera
I have a sony ccd trv 138 hi8
it seams that it has a usb streaming /connection all you need its a driver and a cable to connect it to a computer ..
all I found its a driver for hi8 camcorders but it seams that is for windows 2000 ...anyway some drivers work on xp just fine even if they were build for 2K ...its worth a try ...if not can get a alder cheap computer and keep it with 2000 ( if we dont find the xp driver ) ...just for downloading and operating this camcorder...
Sep 04, 2009 | Sony Handycam CCD-TRV37 Camcorder
Plug usb lead into side of camera pc does not recognise camera so cannot pictures from memory card to pcdownload
After trying different suggestions I inserted the c d that came with the camera while the transfer cable was still attached to the camera, and this seamed to solve the problem, the p c read the memory card and recognised the camera and all went well from there.
May 04, 2009 | Pentax Optio E20 Digital Camera
Memory card is stopping my camera working
Check the memore card. The write protect switch has been moved.
Jan 04, 2009 | Olympus FE-210 Digital Camera
"little tikes- my real camera" can't upload pics
The USB connection seams to be very sensitive try pushing the USB cable into the camera firmly and wiggling it. Once the mass storage device is recognized be careful not to move the plug. The connection can be very flaky.
Good luck,
Dec 10, 2008 | Little Tikes My Real Digital Camera Pink
I've just bought a new computer for video editing, I'm aware that this model DCR-HC40E does not run under vista. Question is, is there a driver that actually be able to drive this?
If so please link me the site. Or is there any other solution.
Your Help is very much appreciated.
Jun 28, 2008 | Sony Handycam DCR-HC40E Mini DV Digital...
Will not charge
1st place to try is the Kodak technical support team on the web site. If it is still under warranty then this will be dealt with. If out of warranty then a low cost replacement may be on offer. A repair does not seam feasible if it is deemed to be a hardware failure.
Jun 16, 2007 | Kodak EasyShare C340 Digital Camera
Pc having problems recognising my camera
are u looking to the display while conectting to the computer??? u need to say order to connect to the computer
Mar 14, 2007 | Olympus Camedia Brio D-230 Digital Camera
Microsoft LifeCam VX-6000 Webcam Logo
21 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
