Question about HP Scanjet 3400c Flatbed Scanner
Error: Sorry, scanner could not be initialized, scanner not found
This issue goes deeper then just a reboot or scanning from the control panel. Yesterday the scanner work fine, today, the computer tells me under the device manager that its an "unknown" USB device. Uninstalling and re-installing the software/drivers doesn't resolve the issue. I'm to the point where I am going to try to install the software/drivers on a different PC and if it has the same error, I'll write a nasty letter to HP and toss the scanner. Things break over time, but this is crazy. A scanner shouldn't work on a Tuesday and just stop being recognized on the computer on a Wednesday. Got to love Windows.
Thanks for any guidance in advance.
Chris
4 Suggested Answers
rickyostrom
  • 274 Answers
SOURCE: ScanJet 5300c didn't work
Most likely the destination folder for the scanning is a shared folder with limited rights. As the administrator, reset the permissions for that folder or redirect the software to a common folder with read/write/creation etc... access.
Also, make sure you are using the HP provided drivers and not those from Microsoft.
Posted on Nov 24, 2008
SOURCE: hp scanjet 6200c scanner recognised only as printer by pc
Where can I find p scanjet 6200c software/drivers for mac? Thank you
Posted on Nov 28, 2008
VBtoons
  • 28 Answers
SOURCE: Hp5300c scanner-can't use HP software on new PC (XP Pro SP3)
Are you using the software from HP? It sucks. If the HP software is not working correctly, then Use the one provided my your operating system works great. Go your Control Panel, Printer and other Hardwares and click Scanners, make a shortcut to your task or start menu and Scan Away. For Faxes, etc. import in outlook or other email client, etc.
Posted on Feb 26, 2010
My scanner will not scan
If you have upgraded your OS to Vista or W7 , this could be the cause of the issue , especially if your device is more than 10 years old . The manufacturers generally stop producing compatible drivers for these last operating systems .
Otherwise , delete driver in Device Manager , disconnect scanner and uninstall scan software via Control Panel \ programs .
Reboot , reinstall software .
Reboot , wait for O.S. to be settled and connect scanner .
Dec 31, 2010 | Office Equipment & Supplies
I get a error initializing scanner?
Background of issue- When 4345/M4345 boots up, amber light comes on under start button and the message "Initializing Scanner" is displayed. The unit will print but will not preform any scan functions.
Steps taken to try to resolve issue:
1. Updated firmware
2. Restored factory defaults
3. Took off cover in back of printer covering scanner controller board and reseated all cables
4. Took apart scan unit and cleaned (2)mirrors in scan head
5. Took off back cover of unit, reseated cables coming from scanner controller board
6. Ran Scanner Test, in menu (which everything functions properly)
Usually I would say scanner or controller board has failed but I had 3 M4345 come down with this issue in one week. The only resolve i've found for this issue is repetitively turning on and off the unit until it comes up without "scanner initializing" message. Once it comes up it functions 100% until the unit is turned off and issue will come back.
I'm at a loss here with so many units having same issue, open to any advice. I once took the formatter out of bad unit and put it in good one and it caused the issue in the good one but i'm double verifying this tonight. Thanks for any help.
Nov 17, 2010 | HP LaserJet 4345mfp Printer
My HP C5180 all-in-one printer/scanner used to
try to off and on the hp photosmart let scan if not work re-install driver. let me know if still not work for further trouble shooting.
Apr 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP L7650 Scanner Could Not Be Initialized in Leopard (Not Found)
If you're using Vista, this happens all too regularly with HP printers. I've had a few where I have to uninstall everything then re-install to make things work.
Two weeks later the same thing, same process.
Try downloading latest drivers from HP and see if that helps. HP don't admit there's a problem.
Don't seem to have this problem with Epson printers tho.
Oct 02, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I have escndv.exe error problem with 4490 scanner. I've reinstalled the drivers and it still comes up
The first thing to try is uninstall the Epson Scan. Via either the start
menu item if one exits or from the Control Panel Add/Remove Programs.
Reboot computer.
Install the latest driver from the epson web site -
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=50666&infoType=Overview
Latest is 2.68A for WindowsXP, etc.
You should go ahead and download a fresh copy from the web, your copy may be
corrupted.
After the install, reboot.
If that does not solve the problem.
You got to go deeper.
Remove the Epson scan. (again).
Backup your registry.
Edit the registry and remove all references to the Epson Scan.
Remove the folders and entries for Epson Scan in \Windows\Twain_32\
Reboot:
Install Epson scan.
Good Luck!!
Jul 03, 2009 | Epson Perfection 4490 Photo Scanner...
HP Solutions Center can not communicate with HP 3500c Scanner
Had exact same problem. Went to HP site and they said to check "add or remove programs" functions (in control panel) and if there are multiple copies of HP software to download their fix. I checked, had multiple copies, downloaded patch and all worked well again.
Sep 21, 2008 | HP ScanJet 3500C Flatbed Scanner
Scanner not found
Macintosh: Scanning Software Does Not Open or Stops Responding in Mac OS X V10.4
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01396146&lc=en&dlc=en&cc=us&product=1138342&rule=15414&lang=en
The link will take you to the HP page where the handle for this problem is detailed. I did every step as listed and downloaded updated driver / software for the 4315. It works!
Aug 04, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Error Message-- Error in shading position (-4431)
The issue at hand here is a sensor error. Cut the power to the machine for at least five seconds. Then reboot the scanner and the sensors should reboot. This solved the problem for us. Good luck to you.
Nov 21, 2006 | Canon DR-2580C Path-Through Scanner
HP Scanjet 3400c Flatbed Scanner Logo
774 people viewed this question
Seeker5211
Seeker5211
