Question about Grilling
Auto igniition will not operate - Grilling
  • 388 Answers
Are you talking about pushing the ignitor button and nothing happens? Depending on your make and model grill, there is either a AA or 9V battery powering the igniter. Find that battery and replace it.
Posted on Sep 24, 2009
Igniition switch battery power fuse blown 2002 buick rendezvous
You will need the electrical diagrams and then trace the wiring of the circuit fuse 19 supplies until you find the grounded wire. There are no easy answers just careful diagnosis and testing along with visual inspection.
Jan 06, 2015 | 2002 Buick Rendezvous
My Kenmore Gas Range 790 makes a puffing sound every time the oven cycles on. Sometimes it is quite loud. In addition when I set the temperature the preheated beep sounds well before the temperature
It sounds like your oven igniiter is the problem. the part that glows in the oven. they get old after a few years and you can get a miner explosion when the burner lights. Replacing the igniter should fix this.
Nov 06, 2014 | Kitchen Ranges
Rear wiper will not shut off
the motor in all wipers motors boxes.
has a switch inside, called the keep alive or auto cancel;.
its bad.
ive fixed many a switch inside, most shops throw the whole thing way.
for good reason, they dont want you back next week for same problem.
on old cars we try to fix things. direct.
to prove this. we use a voltmeter
at the 2 power pins, one goes to 0volts when you turn it off
the other stays hot. 12v. this is normal
if the motor fails to stop, the motor internal switch is bad.
the tests are here.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
under wipers chapter and wiring 8w-53-4
as you can see the rear motor has 3 wires.
pin 2 is ground
pin1 is keep alive pin, 12v.
pin 3 is demand, 12v wiper on, 0v wiper off.
if you cut the pin 3 wire, and the motor keeps going, the motor internal switch is bad.
if cutting pin 3 , kills the motor ,that means the hand switch is bad.
or shorted some way.
Mar 03, 2014 | 1994 Jeep Grand Cherokee
Car shakes very badly upon starting of engine
You also need to make sure the IDLE ROD did not fall off, Igniition Coil Fail, Misfire?
What Lights are showing?
Apr 10, 2013 | 2004 Ford Taurus
97 chevy 1/2 ton 5.7 vortec truck won't start
remove the shroud around the steering lock ,then with a meter locate the feed ,then the 12v when ignition turned on then with a suitable paperclip or piece of wire turn the igniition on and then from the 12v supply apply a supply the other connection for the starter motor and try that ,if it starts ok then renew the ignition switch ,if it doesnt start its the electronics
Dec 27, 2009 | 1997 Chevrolet K1500
Zero cub cadet dies after several minutes of use
Make sure the fuel cap vent is not blocked. Check the output of the fuel pump. (but, be very careful. Remember gasoline is very volatile and can explode very easily.)
After it stalls, immediately check to see if you have spark at the plug. (Use a neon plug tester lead.) If you no longer have spark, it is most likely the igniition module that is failing when it gets hot.
Jun 10, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Check engine light
It might but what exactly are the codes. Before you change the Mass air flow sensor, try cleaning it first with a can of mass flow cleaner.
If your running a oil K&N filter, there could be some oil residue on the sensor. Start with that and change the filter or clean it if it's a K&N.
The O2 sensor's could be bad also, you really need the code's to be sure what sensor is giving you the faulty signal.
Good luck and hope this helps.
May 05, 2009 | 2005 Ford Focus
Steering wheel locked on 1992 toyota camry
This is not a problem to worry about.
Just insert the key, when you are about to turn the igniition, simultenously turn with the key too.
That does it.
Rate fixya
Apr 04, 2009 | 1992 Toyota Camry V6
Grilling Logo
100 people viewed this question
Top Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
