Question about Nokia 6500 Classic Cellular Phone
How do i take the phone apart - Nokia 6500 Classic Cellular Phone
    President:
  • 632 Answers
You need: Torx 5 screwdriver & small flat head screwdriver or some kind of metal lever.
  1. Remove the battery cover, battery and memory card.
  2. Run your fingernail around the edge of the join of the top cover to unclip it then remove this part.
  3. Remove the camera surround. It'll be stuck down with double sided tape so just peel it away. Also remove the clear camera window, indicated by the arrow.
  4. Push the front cover up the remove it.
  5. Use a metal lever like a flat head screwdriver to pop the LCD frame out. Use the lever on both sides of the phone.
  6. Pull the LCD frame towards you. You'll now be able to access five screws which hold a metal plate in place. Unscrew these and lift away the metal plate to access the connector from the LCD. The LCD will still be attached to the phone at the bottom by a ribbon which attaches like a plug and socket. Just lift this up to unplug it.
  7. You'll now have the LCD frame (and LCD) removed.
  8. The LCD will easily pop out of the frame and allow you to replace it.
  9. Reverse the whole procedure for reassembly.
Posted on Sep 24, 2009
Pantech MATRIX C740 slide hinge has come loose. How do you take the phone apart to fix? (Pantech Matrix and Duo are not the same phone)
i suggest not taking the phone apart. 5 of my friends and myself have the matrix and after flipping it a couple of times the hinges are always going to feel loose. they have felt that way on mine for over a year. and if you take it apart, the senor bars for the keyboard will go out and you will have to get a new phone or just use the number pad
Jan 10, 2010 | Pantech Matrix Cell Phone
Dropped my cell in water
does your phone still work after being submerged?? i did the same and it was toast...
the screen is layered...glasss, lcd, and they are not meant to come apart. The phone needs to be left out, taken apart as far as you can get to air out. Leave it for a day or so, and put together. Hope this helps
May 05, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Changing the LCD screen on a Samsung A-737
I had to take my sons phone apart when it got wet. I believe the screen was held in with some type of double sided tape. But you have to take the phone completely apart to get to it. I took it apart about 6-8 months ago and it is still working.
Mar 10, 2009 | Samsung SGH-a737 Cellular Phone
Nextel i880
my phone does not display menue anymore
Jan 15, 2009 | Motorola Mobility i880 Cellular Phone
How do i take it apart?
you have to pry out the rear bottom cover with a plastic tool. that will reveal twu other screws to complete the dissasembly
Aug 11, 2008 | Motorola Mobility E815
Takin apart
do not, do not, do NOT take it apart !! :) that will void ur warranty. as it is, if u are within ur first year, take it into a store or call tech support for a replacement. if ur past a year, use ur insurance or upgrade options. charging ports really cant be fixed. but if u take it into a store with a tech, they may try to fix it, but dont get ur hopes up
Jun 30, 2008 | LG enV VX9900 Cellular Phone
Do U Know Wux Wrong. . .
special tool for taken sliders apart but sounds like the ribon for bottom end to top end might have came apart this is a dealer fix simple for them hard for the public
May 13, 2008 | Nokia N95 Cellular Phone
How do i take it apart.
using your fingernail, there are multiple plastic clips that should pop off as you run your finger around the edge, let me know if you still can't get it, you may also try a small flat headed screwdriver to pry it apart.
May 12, 2008 | Samsung SCH-u340 Cellular Phone
Cordless phone keypad problem
I too have similiar problem with Uniden phone. In my case it is only the center toggle. I indeed took the phone apart and this problem relates to the metal oxide wearing off the rubber keys that make contact with the exposed circuit lines. This same problem is common with TV remotes. Sometimes you can take apart device and find that cleaning the circuit with rubber eraser can help the problem. You can clean the rubber contacts, but be delicate as you do not want to remove the coating on the key. As far as taking phone apart? Well it helps to be a tech with experience. Usually there is at least one screw or two to remove in the battery area. Then you gently pry the phone apart. Sometimes devices like this slide apart after the screws are removed. If you pry start at position nearest where screws join parts together and work your way up. You may dent the plastic a bit in process. Once you have two halves apart be careful in next steps. There will be numerous screws holding the phone to face. Also be careful of wires to speaker. They are usually hardwired. No plug. As you take apart take careful note of how wires are routed. Also be careful of charge contacts that slide into base of phone.
I could fix my phone if I could get the part, but I suspect Uniden will not sell me the part and ask me to send phone in.
Spinman
Nov 09, 2007 | Panasonic KX-TG2336-S Phone
Cell phone disassembly
The screw is hidden underneath the plastic so you'd have to break the plastic to take apart the flipper. Not sure how you would put it back together though.
Oct 18, 2006 | Sanyo MM-7400
Nokia 6500 Classic  Cellular Phone Logo
207 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
