Frigidaire FAX054P7A Thru-Wall/Window Air Conditioner
Problem for Frigidaire FAX054P7A Thru-Wall/Window Air Conditioner
There is always a build up of water around the
By jaymecother on Sep 24, 2009
There is always a build up of water around the blower motor. When turned upside down the water will come out...but come back almost immediately!! The water noise is very loud and the air conditioner is not cooler the room as well as before.
Solution #1
posted on Sep 24, 2009
Not Rated)
jc93656
Rank: Guide
Rating: 0%, 0 votes
clean your air filter located in the front of the unit dirty filters can cause ice build up
Was this helpful?
Yes
No
Popular Solutions for Frigidaire FAX054P7A
Questions and Unsolved Problems for Frigidaire FAX054P7A
Do you recommend Frigidaire FAX054P7A Thru-Wall/Window Air Conditioner?
Answer
Answer
I have a SHARP AY-a249J system that starts cooling for about 20-30 minutes then the cooling system... (More)
Answer
Answer
My comfort Zone II has stopped displaying the third zone. What could be the problem?
Answer
This FAX054P7A2 window AC is two years old and has been working properly. The plug shows a green... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire FAX054P7A...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
