Question about Sony STR-DB930 Receiver
MY RECIEVER IS CHATTERING BADLY AND THE SOUND GOES AND COMES BACK
  • Sony Master
  • 497 Answers
1. Check the wiring of the device. If if it is connected properly.
2. Check for any Electromagnetic interference. Please ensure that any device like Cell Phone, Telephone etc is not near the Device.
3. Ensure that any Electronics device like UPS are not near the Device .
4. Check the microphone (if connected with the Device) is turn OFF.
5. Power Reset the Device by removing the power source and connection it after one minute.
6. Disconnect all the external device attached with the Device (if any) and check.
7. Directly connect the Device to a working Power outlet and check.
Good Luck!!!!!!!!!!!
Posted on Sep 24, 2009
  • Mitesh Kr Anand Sep 24, 2009
    8. Also try changing the connecting Power Cable.
Van sometimes makes a chattering sound from stopped position at light when pushing gas to accelerate then catches and goes
Sounds like an internal transmission issue. The clutches may be chattering. Check the fluid level first but if that is good, get it to a reputable trans shop for diagnosis.
Aug 17, 2013 | 2008 Chevrolet Uplander
Model: PGX2L5644-662MHz. Its causing a loud sound as if its lost or is loosing frequency even if I am standing with the mic close to the reciever. The ready light comes on and also the signal light when I...
Reset the channel/group on both the mike and the reciever. Shure reuses frequencies by groups so if the group is different, but the channel is the same then you aren't on the same actual frequency.
There should be an auto-set option on the recievers display as well as the mike. Turn them both on, and then just hold the mike up to the reciever so that the little IR window can see the reciever and the 2 with sync together.
If they are both on the same group and channel then turn the mike off, and adjust the squelch control until static is heard, then turn it back until it just goes away.
Feb 28, 2011 | Shure LX2 / Beta58 Microphone
Hi, I am getting no sound when I connect speakers to the receiver... But the receiver comes on and goes thru all of the menus...
speakers may not be good. volume might not be up high enough. settings may not be right on reciever. i advise you check the speakers first by plugging them into a different stereo. if they don't work, inspect them to make sure they're not blown (cracks in the cone of the speaker). if they do, hook 'em back up and check to make sure there's no headphones plugged in or any settings on the reciever that say speakers or external speakers or anything like that are powered off. hope this helps.
Oct 06, 2009 | Harman Kardon AVR-630 7.1 Channels...
Reciever shuts off
Hi there
May I ask how many watts can your reciever handle ? And how many watts does your speakers need in order to be powered up (input). The two speakers you have installed might be too powerful for your reciever to handle. You might have to down grade to less powered speakers. All in all you have an excellent product there good choice...
May 11, 2009 | Onkyo HTR500 Receiver
Denon AVR 3600 sound gone
this happened to me once and I found that my reciever would just shut down. make sure that you have plenty of space above the amp. it may be over heating and shutting down on you and when it cools down, it turns back on. there will most likely the "overload" light will be lit when it shuts down the audio.
hope that helps
Dec 31, 2008 | Denon AVR-3600
NO SOUND
I am also having a similar problem. I am using a classic 1985-87?? reciever. I dont want to give it up however, i blew a fuse after plugging in an input while the unit was turned on. The system light up and that was that. After replacing the required fuse correctly, everything turns back on. No sound output. no indication of sound off the needles either..
Oct 21, 2008 | Audio Players & Recorders
AC Compressor clutch problem
Hi
This could be any number of things, low system pressure, chattering relay, faulty cycling switch, failed compressor, poor cooling, the list goes on.
I'm afraid this is a job for the professionals!
Very best regards
Geordie
Jun 11, 2008 | 2005 Ford Taurus
No Sound when I play DVD's
The optical connection on the TV is most likely an input, not an output. You need to connect the Xbox to the receiver, then the TV. If the receiver does not have a HDMI input, use another audio or digital out from the Xbox to the receiver.
Sep 19, 2007 | Yamaha HTR-5940 Receiver
Kenwood Reciever VR-615 S/n: 20102759
I HAVE SAME PROBLEM,I HIT RECEIVER ON RIGHT SIDE & DISPLAY LIGHT COMES ON.WHY I DON'T KNOW
Sep 25, 2006 | Kenwood VR615 Receiver
Sony STR-DB930 Receiver Logo
77 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
