Question about Sharp MX-2300N Color Copier
Color is not accurate - Sharp MX-2300N Color Copier
  • 63 Answers
If the color quality is out of adjustment you can refer to your user manual (available form the web interface of the copier machine) and it will tell you how to adjust the color (slightly). If your colors are way out of scope then you will need a qualified copier technician to calibrate your copier back to factory specs.
Posted on Oct 12, 2009
How do I print artwork getting all the colors to render accurately, so that it looks like the original painting.
Unfortunately you screen (computer or other ) isn't calibrated.
there is software mostly pro use this, but take a picture of a flat grey placard.
using your photo program to check the gamma settings and modify them until the grey on screen matches placard ( hold placard next to monitor). Then print out grey image.
important write down the gamma settings and when you put something to print check to see if these are close.
Sep 26, 2016 | HP Designjet Z6100 InkJet Printer
Scanning is not producing accurate colors for all colors. For example, Halloween shade of orange scans as pure yellow and brown comes out quite pink. Tried shutting the machine down and restarting much...
You'll need to calibrate your printer in order for the prints to come out with the correct color. In addition to this, if you're printing from .pdfs, you can set Acrobat to "print as image", this also helps in correcting the colors as they appear on your monitor, although this is NOT as accurate in correcting color as the "calibration" part.
Hope this helps. :)
Oct 06, 2010 | Canon PIXMA MP520 InkJet Printer
Printer not printing true to color color not the same as on screen
You might need to re-calibrate your screen. Even if this is performed it's not going to be 100% accurate unless your using pms color swatch sample as a guide. I would also check and see if you're using the correct paper to your printer's settings...this also may throw off the color. Hope this helps.
Sep 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do I check the trans fluid in my torrent 2006
Their are two dipsticks under the hood one is motor oil it is brown in color. The transmission will be a little closer to the fire wall it will be red in color. Your car needs to be running to check trans fluid for an accurate reading. With motor oil your engine needs to be off for an accurate reading
Sep 06, 2009 | 2006 Pontiac Torrent
Canon I960 inkjet printer color shifts
We are experiencing something simillar with our imagepress. As far as I know, every heavily used Canon (or used for a longer period of time) tends to skew colors towards magenta a little bit. We are dealing with it by reducing magenta in color balance menu for all jobs on the printer, but the result is never perfect (especially in grey where is needed perfect balance of colors).
Mar 12, 2017 | Cannon Canon i960 Photo Printer
Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
Jan 10, 2008 | Konica Minolta bizhub C250 All-In-One...
Accurate color
Digital cameras rely on "white balance" to control total overall color accuracy as processed for the final image. Colors are greatly affected by light. For example, look at any wall in your home or office and you can easily see that shadows will make the color of the wall appear to be different shades. Sunlight has a very different effect on colors than incandescent light or florescent lights. Digital cameras start with white (the absence of color) to measure the effect of light and adjust the metering (measurement and accuracy) of all the other colors. Of course, white in a poorly lit room may appear gray or even yellow to some digital cameras. So how can you get accurate color? 1) Turn the Mode Dial to MANUAL MODE (Red camera icon with an "M") 2) Use the Arrow Down on the ENTER Button to select W/B (White Balance) 3) Press the center on the ENTER Button to select and adjust W/B (White Balance) 4) Use the Arrow Right (once), then Press and Hold the Arrow Down. Note: Continue to Press and Hold the Arrow Down. There will be a pause as you reach the bottom of the common preset conditions. Then a new "hidden" option will appear. 5) Once PRE SET appears, Press the center of the ENTER Button to select it. 6) A Special screen will appear. Point the camera direct at something WHITE, like a piece of paper, a white wall or a white shirt. Regardless of the lighting conditions, the camera will accept this "white object" as the new starting point "base of reference" or "True White". 7) Press the Shutter Button to program the new "True White" setting. 8) Press the center of the ENTER Button to accept and continue photography. These new settings will be saved as PRE SET True White conditions in Manual Photography Mode until you change the settings with another selection. This will not "go away" when the camera is turned off. These settings do not impact Auto Photography Mode.
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Accurate color
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Sharp MX-2300N Color Copier Logo
104 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
