Question about HP LaserJet 3055 All-In-One Printer
I am trying to fax papers it will ring and connect then it says comm error and won't send hte fax through.
    President:
  • 1,653 Answers
This shows that a fax communication error has occurred between the AIO and the sender or receiver. This could also indicate that there is a telephone line error although unlikely. Make sure that the telephone line cord is not damaged and thatthe telephone jack is correctly inserted in the Socket and also in the AIO.
The remedy is to allow the AIO to retry sending the fax. If this is unsuccessful then unplug the AIO telephone cord from the wall, plug in a telephone, and try making a call. If this works OK then plug the AIO telephone cord into a jack for another phone line and try the transmission again. If this fails then try using a different telephone cord on the AIO. If this fails then you will need to call a service engineer as it will most likely be a fault with the AIO internal modem and need to be replaced.
Posted on Sep 24, 2009
Hp laser jet m1536dnf MFP won't send fax comm error 388
You can start by making sure that the photocopy is working, this is to ensure that the scanner is working. Next, try to isolate the issue if this is only happening to only one fax number? If all of these have negative results, I suggest for a hardware reset. Follow the steps for reset found here, How to Reset the HP LaserJet Pro M1536dnf Multifunction Printer. Goodluck :)
Aug 14, 2012 | HP PSC 2410 All-In-One InkJet Printer
When sending fax on canon pixma MX350 i get a NG error REPORT what does this mean
Hi There!
Comm Error will show on the display if there is an issue with the phone line like an interference or it's not connected directly to the wall jack.
What you can do is check if the machine has a dial tone or try to call the fax # where you need to send the fax, just check if it's ringing. Second before loading the paper make sure that the display shows date & time. Then load the document in the tray the display should show enter fax # & start. Start dialing the # then press start.
Hope this helps.
Vikroks
Mar 29, 2011 | Brother IntelliFAX 560 Plain Paper Fax
Everytime I am sending a fax i get the common error 20 02
Comm Error will show on the display if there is an issue on phoneline that were using.
First please check if the machine has a dial tone or try to call the fax # where you need to send the fax, just check if it's ringing. Second before loading the paper make sure that the display shows date & time. Then load the document in the tray the display should show enter fax # & start. Start dialing the # then hit start.
Hope this helps.
Mar 29, 2011 | Brother IntelliFAX 770 Plain Paper Thermal...
Cant send fax
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 17, 2010 | Samsung SF-565PR/XST Printer
Panasonic Panafax UF-790 Fax did not complete logging into memory. Comm. Journal comm. 212 What do I do?
its a receiving error code means a computer was trying to fax you and it didnt connect properly
Nov 12, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Comm error on a VOIP line
Fax cannot send on a VOIP line unless the VOIP line has T.38 fax protocol service.
Sep 25, 2009 | Brother FAX-575 Plain Paper Thermal
Fax series 920, can receive but not send faxes, error code 344*
Do you have or are you sending a fax to a party that has a DIGITAL PHONE SERVICE?
Jun 04, 2009 | HP 920 Plain Paper Fax
Cannot send fax
Fax machines are ANALOG devices and will not reliably work on digital phone lines.
Jul 03, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Fax sending problem
It sounds like you have a few problems. First, the comm error usually means there was a problem communicating with the other fax. This maybe caused by a phone line issue, or a bad connection. You will have to replace you ink but that does not have anything to do with your sending issues. As far as the pages getting stuck, the separation pad under the top cover should be cleaned. If you lift up the cover where you load your pages to be sent, and look in there(on the backside of the keyboard)you will see a flat square rubber piece. Clean it thoroughly with a rag and some rubbing alcohol. Also clean the rubber rollers as well. Good luck John
Jul 03, 2007 | Brother IntelliFAX 1840C Plain Paper...
HP LaserJet 3055 All-In-One Printer Logo
18 people viewed this question
Seeker5211
Seeker5211
