Question about Electrical Supplies
I have a OK Lighting touch lamp and three of the glass planels are broken do you kow whenere I can get replacements
Go to:
http://rsilverwings.com/glasspanels.html
Posted on Dec 19, 2010
  • 3,051 Answers
Hello there:
here is several links that will definatly help you in your quest to find touch lamp glass ok? look below mainly # 3
best regards michael
  1. Lamp Shades - Glass Lampshades - Silk Replacement Lamp Shades - 2000 item catalog of glass lampshades, silk replacement. ... Finishing Touch - Finials. Tulip - Lilly - Large -Small. Oil Lamps & Fonts ...www.specialtylampshades.com
  2. Speciality Lamp Shades Add a finishing touch to your shades. Reverse Painted & Dome Glass Shades ... Replacement Glass Lamp Shades- Reproduction & Custom ...www.specialtylampshades.com/lampshades.html - Cached
  3. Touch & Glow Replacement Kit | LampsPlus.com 3-way touch lamp. Saves energy. Extend bulb life. ... Glass Shades. Light Bulbs. Night Lights. Under Cabinet. View All Categories. Bathroom Lighting ...lampsplus.com/.../Touch-and-Glow-Replacement-Kit__35098.html - 110k - Cached
  4. Elegant Touch: Brown's Lampshades ... a special accent for your special lamp and replacement lamp shades. ... Glass Small Tear Drop Lamp Finial. c3-finial $12.95. Crystal Gothic Cross Lamp Finial ...brownslampshades.com/store/ctgy/elegant-touch.html - Cached
  5. Nec Display Solutions 50016683 Replacement Lamp - Yahoo! Shopping Yahoo! Shopping has Nec Display Solutions 50016683 Replacement Lamp. Quick Links: Specifications - Description - Compare Prices shopping.yahoo.com/p:Nec Display Solutions 50016683 Replacement Lamp... - 126k
  6. Replacement Shade for 2198 Floor Lamp - Shop.com Shop for Replacement Shade for 2198 Floor Lamp and Floor Lamps at Shop.com. the 2198TA lamp was designed by fontana arte in 1954. a very dignified modern touch to an...shop.com/replacement_shade_for_2198_floor_lamp-59830151-7...
lamp
Posted on Sep 29, 2009
Hitachi replacement bulb blows after a few months .Three so far
first make sure you are ordering correct part# UX21511 Then when get you cannot touch this lamp with finger tips, also make sure lamp area is clean of glass, dust etc
Jan 05, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
I have an exterior copper lantern with broken glass panels. the lantern is completley soldered from the inside out.
Contact a glass company, but also look for a stained-glass maker.
Stained glass is set inside a soldered frame. That person will have the tools to fix it.
You will probably have to get a handy-man to remove the outdoor lamp so it can be taken to the glass shop.
Oct 30, 2010 | Cooper Lighting Lighted Switch
Replacing the hole headlight
SECTION 417-01: Exterior Lighting 2002 Lincoln LS Workshop Manual REMOVAL AND INSTALLATION Lamp Assembly —Headlamp Removal and Installation
s2x~us~en~file=ani_caut.gif~gen~ref.gif WARNING: The halogen fog lamp bulb contains gas under pressure. The bulb may shatter if the glass envelope is scratched or if the bulb is dropped. Handle the bulb only by its base. Avoid touching the glass envelope.
NOTE: The headlamp bulb should not be removed from the headlamp assembly until just before a replacement bulb is installed. Removing the bolt for an extended period of time may affect headlamp bulb performance. Contaminants may enter the headlamp assembly where they can settle on the lens and reflector. Never turn on the headlamps with the bulb removed.
  1. NOTE: Make sure that the headlamp switch and the ignition switch are in the OFF position.
    Release the ambient air temperature sensor.
  1. Remove the radiator grille opening cover at the top shelf of the bumper.
  1. Remove the radiator upper sight shield.
    1. Remove the pin-type retainers.
  1. Position the headlamp assembly for removal.
    1. Remove the three bolts.
    • Disconnect the electrical connectors and remove the headlamp assembly.
  1. To install, reverse the removal procedure.
    • If necessary, install new bulbs.
Feb 27, 2010 | 2002 Lincoln LS
Whow to replace lamp on tv sony kdf-e60a20
Follow this procedure to replace the lamp:
1. Turn off the power on the main unit. Wait several minutes, then unplug
the power cord.
(The cooling fan will continue to operate for about two minutes after
turning the power off.)
2. Wait at least 30 minutes after unplugging the power cord to allow the
lamp to cool down before replacing it. To avoid being burned, do not
touch the lamp receptacle once the lamp has been removed.
3. Take the new lamp out of the box.
Do not touch the glass portion of the new lamp.
✍ Do not shake the lamp. Vibration can damage the lamp or shorten
its life.
✍ Avoid touching the front glass of a new lamp or the glass of the
lamp receptacle. This may reduce picture quality or lamp life.
4. Loosen the screws on the rear side panel.
5. Remove the front panel.
6. Pull out the lamp.
Loosen the right screw on the cover with a coin or similar object.
Remove the screw from the lamp cover. Pull down the cover toward you.
Unscrew the lamp and pull out the lamp horizontally.
✍ The lamp is very hot immediately after use. Never touch the glass
portion of the lamp or the surrounding parts.
✍ After it has cooled, place the used lamp into the empty box of the
replacement lamp. Never put the used lamp into a plastic bag.
7. Place the new lamp into its place, then tighten the screw.
Mount the new lamp securely. Failure to mount correctly may cause a
fire or the screen to go dark.
Push the cover back on. Make sure that the hole on the cover aligns with
the hole on the unit. Reattach the lamp cover by tightening the screw.
✍ If the lamp cover screw is inserted incorrectly, the lamp may not
operate properly. In such a case, remove the screw, insert it
correctly and then tighten the screw completely
✍ If the lamp cover is not reattached securely, the self-diagnostic
function may be triggered and the POWER indicator flashes three
times
8. Reattach the front panel securely.
9. Tightly screw the side panel in its place.
That is it. Thank you.
Nov 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Need to replace a broken screen on Dell Latitude D610.
Hi there, please following this show step by step
http://www.geneseo.edu/~stratton/D610_ServManual/azedadis.htm#wp1040875
be carefull :
1) LCD cable pull out/in fromto the panel mark its match.do not force to much
2) carefull inverter cable and lamp wire do not plug in/out too hard.
3) do not touch the new planel top side and left/right side too much, there are sensitive cable inside.
hope help you fix it, send any question at any time please.
May 19, 2009 | Dell Latitude D610 Notebook
Broken inside glass door on my electric KitcherAid glass top range
sounds like you may have thermal breakage. does your oven have the self-clean option? you can have the glass replaced easily. i wouldn't use the self-clean option for now.
Aug 02, 2008 | KitchenAid KGST307 Gas Kitchen Range
Broken plasma glass
Sorry, it's totalled. The glass is part of the main display planel and cannot be replaced.
The good news is that this model was only a 480P HD resolution. Whatever you replace it with will have at least 720 or even 1080 resolution, and cost no more. That will be a huge improvement you will notice immediately.
Dec 20, 2007 | Televison & Video
Electrical Supplies Logo
1,249 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
