Question about Linksys WRT160N Wireless Router
Wireless-N connection fails between 6 and midnight
My MacBook is connected to a Linksys WRT160N via a Wireless-N connection...normally, that is. The wireless connection seems to fail between 6 PM and midnight. I've tried changing channels, forcing N-only operation, switching between Wide and Narrow channels, etc. to no avail.
I am using WPA2 Personal encryption, have MAC filtering turned on and have SSID disabled. As I live near a large university campus (no doubt full of hackers), lowering security is not an option. Also, I have another computer (a Linux box running Ubuntu 8.04) and a printer connected to this router, using wired connections.
The MacBook is located about 6 feet away from the router, in (almost) the same horizontal plane.
  • 104 Answers
SOURCE: Unable to connect to my wireless network connection (SSID still VISIBLE)
I've been looking at wireless problems for someone else, so here are a couple more possibilities.
1) could a new piece of equipment be interfering with the signal, eg a dect phone nearby, even a microwave - or even something next door? Does moving the router help at all?
2) does changing the router channel help? Eg, if you are picking up other networks, maybe it is getting busy on the channel you are using. :)
Just ideas - as obviously I don't know your exact situation - but worth looking at.
Posted on Nov 09, 2008
acdr
  • 1913 Answers
SOURCE: Problem securing my wireless router WRT54GC
ya enable advanced security.
then add mec addresse of lan card which u want to give u access internet.
u know about mec addeses.
if not then reply me at kish.khatri@yahoo.co.in
thanks
Posted on Nov 15, 2008
SOURCE: Laptops stopped connecting wireless
check if you’re computer is properly connected wirelessly to the Linksys router, you will need to perform six steps:
  1. Checking the IP Address of the PC
  2. Checking the Wireless Settings on a Linksys Router
  3. Disabling Computer's Firewall
  4. Disabling Proxy Settings
  5. Pinging the Router
  6. Pinging the Internet
The IP address of the computer is another indication that the computer is properly connected to the router.
The router’s wireless settings should match the wireless settings of the wireless adapter in order for them to communicate.
Disabling Computer Firewall
Make sure that the computer firewall and any third party firewall installed in the computer is disabled. With a firewall enabled on your computer, you may get an invalid IP address. In such cases we have to disable any firewall installed on your PC.
If you have proxy settings, you need to disable these on your computer. If a computer is accompanied by a router, the gateway for the Internet connection, it no longer needs to get any proxy settings to gain access.
NOTE: If you are using Mac to disable the computer's proxy settings.
Pinging the Router
Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection.
Ping test helps trace the communication between the computer, the router and the internet. To check the computer’s connection to the Internet you should get valid replies when you perform a ping test
Posted on Aug 02, 2009
SOURCE: Linksys wrt160N router inconsistant internet connection
I had the same problem, but it was solved by upgrading my WRT160N v2 router to the new firmware release WRT160Nv2_v2.0.03.007_US_code.bin available free from Linksys. It works great with no further "lost connection" or "unable to resolve DNS" issues.
I suspect that the model of modem makes little difference so long as you have confirmed with Comcast that they provisioned for the correct model number. Mine happens to be Linksys CM100, but a few months ago things set up for one of their "comcast provided test modems".
One last thing to check is signal strength. Twice in the last 16 years the fittings and cable from the boulevard dome to the house had to be replaced. Signal strength would be fine until we hit a day below freezing, at which point it was sporadic. The Comcast tech was able to detect this and said it was a common sign of corroded fittings.
Posted on Dec 16, 2009
SOURCE: linksys wrt160n router. wireless xbox won't connect
I made it an unsecured connection and everything worked. Not ideal solution, but it worked.
Posted on Feb 08, 2010
I have a Linksys WRT160N router that I am using with a MacBook Pro laptop running Snow Leopard. I used my computer (with some difficulty) to set up the wireless access by way of a wired connection. The...
My Friend ,
Login the router setup page .
And under router security settings uncheck the option (block anonymous internet request).
Set the wireless channel as 6 or 9.
And then use wep security key.
this will surely work.
Regards :-
Amit
Jan 07, 2011 | Linksys WRT160N Wireless Router
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
Can't get wireless connection from PC to Linksys WRT160N
To setup a wireless connection on a computer, the wireless card in the computer needs to be configured with the wireless router's settings.
For instructions click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 11, 2009 | Linksys WRT160N Wireless Router
Linksys WRT160N Connection Issues.
Sadly, this router has horrible reviews and is known for this problem:
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16833124277
Can you return it for another model?
Can you getLinksys to replace it?
the best one is the LINKSYS WRT54GL, but if you are stuck with the one you have...
If you have tried all these things and you are very brave (or don't care if you need to buy another router) why not try flashing it with an after market O/S?
1) http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
2) http://www.dd-wrt.com/phpBB2/viewtopic.php?t=32576&highlight=wrt160n
Oct 13, 2009 | Linksys WRT160N Wireless Router
I have a Bell DSL modem Speed Streem 6520,linksys Wrt160n &16port
How to Set up the Bell DSL modem: http://www.digitalhome.ca/forum/showthread.php?t=97732
Setting up a Linksys WRT160N Wireless Router: http://www.linksysbycisco.com/US/en/support/WRT160N
(Download the Manual from this site)
Setting up a Linksys 16 port switch: There are many different switch models, however if it just your basic switch, you should be able to just plug it in and plug in your computers via RJ45 cables.
If you need any further assistance let me know....
Serge
Apr 09, 2009 | Linksys WRT160N Wireless Router
PC will not connect unless Laptop is turned on?
first reset the connection, and try to connect the pc with switch and when net start working the connect the laptop
Mar 11, 2009 | Linksys WRT160N Wireless Router
Linksys WRT160N Wireless Router  Logo
280 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
