Runtime error 32
Would appreciate assistance to remove runtime error 32 and relevant link to knowledge base or similar resources. The other issues with my pc is also the popping up of blank website which I had time and again blocked using the popup block and restricted zone in IE options . . . no avail. the keyboard can't type minus, plus keys and the digits 5 and 6 which i need to use the number pad to type instead . . . underscoring too . . . how can i remedy these issues please?
  • 383 Answers
Click on the below link, Good Luck/Please dont for get to Vote.Thank You.
http://support.microsoft.com/kb/307817
Posted on Dec 16, 2007
Runtime error Miss Popularity
You may need to remove Visual C++ then re-install it to the newest version. See link below:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-remove-and-reinstall-Microsoft-Visual-C-Runtime-Libraries.html
Feb 27, 2015 | ValuSoft Miss Popularity: Your Style, Your...
Incorrect side by side configuration when i try to open my yahoo messenger
remove it from control panel add or remove programs and install it again
Sep 14, 2011 | Yahoo Messenger
Location/ 0n the xp kundali-2009 software show Run-time error '53':
"Runtime error '53': File not found (your file.dll)".
It means that one or more files expected by windows to be in place in a specific location and needed to run the application is either missing, not installed or corrupted.
To solve Runtime Error 53 to ensure that your software or hardware runs smoothly as planned.
The easiest method would uninstall of the relevant software or hardware followed by a reinstallation.
Go to the "Control Panel" menu found on your Windows "Start" menu. Click on "Control Panel" before clicking on the "Add/Remove Program" options found there.
Clean up your PC with the free cleaner ie CCleaner before reinstalling your software.
Check out the version of your installed software before going over the product's homepage to see if that particular version is the latest.
However, in the event that such a method does not work, it would be a good idea to contact the company from which you purchased our hardware or software for technical assistance.
Hope it helps.
Nov 12, 2010 | Microsoft Windows XP Professional for PC
Error R6002 floating point not loaded
Causes of Runtime Error R6002
Several causes exist behind this error. One of the most prominent ones is a broken link. This link apart from causing the run time error 06002 can also produce other errors like the computer not responding to any instruction at times. If a software has not been properly installed it can also produce such errors. Apart from that, use of internet without any anti-virus software can make your computer applications get infected with spyware and viruses. Such viruses can produce missing links inside your registry causing such errors.
Why are these errors caused? Many computer users are just not aware of the reasons resulting in these errors and what are the solutions to get rid of these errors. Remember, these errors can be solved very simply, and they are not going to cost you money. Usually many people exercise the option of getting professional technicians to resolve these problems. But this is not necessary. Through following the simple procedures suggested below you will be able to eliminate the error r6002.
If you take time and start noticing, you will find that the runtime errors are due to corrupted or damaged registry. You must know that the registry is the most importance place which is a storehouse of all the data, about both the software and hardware installed in the PC. When you uninstall software or remove a device there may be some traces of such actions left in the registry and manually it will be impossible to remove them. You should be having knowledge of computers to do this, since it is not advisable to access the registry without this knowledge and manually delete these files. A wrong move can result in damaging the PC irreversibly.
Therefore the only method to fix the runtime error r6002, along with many other errors, you should use the registry cleaner. With a registry cleaner you can repair the runtime error r6002 all by yourself, without seeking help of technician. This way you can save money and time, and you will also know the action to be taken next time when you encounter such errors.
Using the registry cleaner should be optimized with the antivirus cleaner, and if you program in such a manner that both the virus scanning and registry cleaner can take place simultaneously, for which purpose you should schedule these activities on the computer, and ensure that at that particular time the computer is switched on, without your botheration of checking them, they will do their job on their own, leaving you to attend to your work.
http://www.registryfix.com/?hop=reviewb
Jun 04, 2010 | Microsoft Windows XP Professional SP2
What is runtime error 216 at005FD748
Make sure that all your infected computers are physically disconnected from the Internet and any other networks while you work to resolve this issue. For instructions about how to recover an infected computer, visit the following Carnegie Mellon Web site: http://www.cert.org/tech_tips/win-UNIX-system_compromise.html Microsoft does not provide software that can detect or remove computer viruses. If you suspect or confirm that your computer is infected with a virus, obtain current antivirus software. For a list of antivirus software manufacturers, click the following article number to see the article in the Microsoft Knowledge Base: 49500 List of Antivirus Software Vendors Back to the top MORE INFORMATION For additional information about distributed denial-of-service attacks and Trojan viruses, visit the following Microsoft Web site: http://technet.microsoft.com/en-us/library/cc722931.aspx Microsoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information.
For additional information about the "Runtime Error 216" error message, see the following article in the Microsoft Knowledge Base: 189989 Error Message: Runtime Error 216 at 00009275
Mar 02, 2010 | Computar (TG4Z2813FCS) Lens
I am trying to install QuickBooks Pro 2007 on a new computer that has Windows Vista Business with SP1, and I had updated Windows, then installed QB but when I imported the company file, QB gave me a...
Why is this happening This issue can occur as a result of uninstalling the Google Desktop installed by Quickbooks on a computer running Microsoft Windows Vista. Launching QuickBooks after uninstalling Google will cause the error message.
Note: This issue is also known to occur with computers that have been upgraded from Windows XP to Windows Vista, where Google Desktop was uninstalled under Windows XP. Both cases would yield the same error message.
How to fix the problem This issue was resolved in the latest release for your version of QuickBooks.
Detailed Instructions Please update your program to the most current release.
just click on that link above then click on the 909ffb0.jpg(update) image on that page.
Oct 27, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Microsoft Visual C++Runtime Library
hello there
please follow this link for a explanation and a fix for this ok
  1. "Microsoft Visual C++ Runtime Library Runtime Error" error message ... Describes the error messages that you receive after you install Office XP or an ... "Microsoft Visual C++ Runtime Library Runtime Error" error message after you ...support.microsoft.com/kb/307817
Sep 19, 2009 | Microsoft Windows Vista Home Premium with...
I'm getting lots of runtime errors!
Here's a link to typical runtime errors in IE.
If you are getting errors from other applications, you can look them up in the event viewer, (link here).
It might be a good idea to do some system maintenance, clearing out temp files, etc by running disk cleaner. And it probably wouldn''t hurt to run chkdsk c: /f on your hard drive to look for corruption. (The results can be seen under winlogon properties in event viewer after you run it.) Instructions to do that here and here.
If you suspect malware could be a possibility, (and it seems possible, from the sound of it,) these are the malware removal protocols I recommend you follow.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 27, 2009 | Dell InspironTM 1501 Notebook
Computers & Internet Logo
90 people viewed this question
Alun Cox
David Payne
David Payne
