Sharp tv 13vt-r100 when i turn on power as soon as the screen start to light up the power shuts off then the power wake up timer light blinks constantly and i cannot turn the power back on. if i unplug it and plug it back in i can turn on power but then the same thing happens again.
  • 3 more comments
  • repid Sep 24, 2009
    i this did not work the user manual says the sleep timer is canceled if you turn off power. it is the power/wake timer light that keeps blinking when the power shuts off as soon as the screen starts to light up. the user manual says after the tv and or vcr is on and no operation is activated and none of its functions have been used for a two hour period the power will shut off as asafety feature.
  • repid Sep 25, 2009
    the only timer button is program timer on off on the remote there no other onnes on tv or remote. any other timer settings are all on the on screen catagories on the menu and i cannot view this because the power shuts off
    sharp tv13vt-r100 when iturn on power as soon as the screen stars to light up power shuts off. the power/wake up timer light blinks constantly.power will not turn till i unplug and plug in.then the same thing happens
  • repid Sep 26, 2009
    it helped find the problem
  • 3,741 Answers
Tv turning off automatically
for first unplug the main power cord of the tv for couple of minutes and then reconnect it.also before reconnecting the power cord of the tv again remove all the external device wires connected at its back such as dvd player/vcr etc etc.just connect only tv wire and check out.if still the same problem then its quite possible that the capacitors and ic on the circuit board are getting short in between so the circuit is not getting completed and cutting in between so the tv starts and turns off.in this case the circuit board needs to be checked with a multimeter.the faulty and burned out component part should be detected and then should be replaced with the help of soldering iron.to make it proper.to avoid further damage i suggest you that do not on the tv again and again as it will short some more tiny components and the reparing cost will increase as per that.at present its the normal circuit short problem in the tv get it repaired before using the tv again.
This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya.
Posted on Sep 24, 2009
  • charlymonty Sep 25, 2009
    keep updated.till where have you reached in solving your problem.
    the main circuit board of the tv has some faulty components.it needs to be checked by a multimeter to locate the faulty component.this will help.if not aware of using multimeter then its advisable to get it checked by a local tv technician as the cost will be negligible.
    its worth getting repaired.
    thanks.
    President:
  • 1,884 Answers
Your sleep timer is on. you must find a way to switch it off. The moment the TV is powered on, press the sleep button and try to change the timer settings.
What are the causes of the screen been dark but the power light is on
your tv can have one of two problems:
- your CHROMA-IC is bad and need to be change
- your flyback screen potentiometer is defective.
either way you need to replace them
succes and enjoy
Aug 04, 2010 | Sharp 13VT-R100 13 in. TV/VCR Combo
T.V. SHUTS OFF - SCREEN GREEN WHEN TURNED BACK ON!!!!
is it a tv or rear-projector? does it brings out the sound?
on a tv it could be the chromatisation IC that is defectiven when it goes blank. why? because of a power surge in the electrical net the tv got too much voltage to take.
try to desoldeer the EPROM IC and power on the set. does this make the set goes normal blue screen? if YES,you can order a new EPROM IC.
succes and enjoy
Jul 17, 2010 | Sharp 13VT-R100 13 in. TV/VCR Combo
Turns on but then shuts off immediately
Check the belt of the vcr sistem if they got a little loose change it
Jun 09, 2010 | Sharp 13VT-R100 13 in. TV/VCR Combo
How do you cancel the tamper proof feature, tv will not turn on, tamper light just flashs
My guess is that the television has been dropped or opened/taken apart which tripped a tamper switch. It my be as simple as finding this switch somewhere on the inside of the tv, and resetting it or shorting the wires to bypass it, or it may be a situation where once the tamper switch is tripped, the tv shuts down forever. I wouldn't recommend opening the tv yourself. They store enough power to kill you, even when it's been unplugged for a while.
Mar 11, 2010 | Sharp 13VT-R100 13 in. TV/VCR Combo
TV won't turn on
Have you tried switching inputs? On some sets if it is set to s video all you get is a dark screen. Check your connections if you have other inputs. If you can't switch you should at least get the menu on the screen proving the tv is working and it is a setting.
Sep 18, 2009 | Televison & Video
How do i switch from "air" input to cable input on a 13 in sharp tv/VCR combo unit
Hi
It will depend on your input set up but Page 13 of the user manual should help, if you do not have one try www.usermanualsguide.com/sharp/televisions/13VT-R100_R150 and download one.
Oct 23, 2008 | Sharp 13VT-R100 13 in. TV/VCR Combo
Sharp Model 27SC370
Same problem here. TV would turn off but would not turn on after a period of time (until waiting a minute or two) then able to start again. Intermittent problem too.
Jan 20, 2008 | Sharp 13VT-R100 13 in. TV/VCR Combo
Remote control for Sharp TV
Hold down the tamper proof button on your remote for up to ten seconds, until the tamper proof light will blink and light will go off. This will turn off the Tamper Proof button.
Let me know how it goes.
Nov 29, 2007 | Sharp 13VT-R100 13 in. TV/VCR Combo
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
