Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Deck tension arms not in proper alinement someone did welding and did'nt put arms right i need a view of deck
  • Chuck
    Chuck May 11, 2010
    What is your model number?
  • 123 Answers
Here ya go.
Posted on Oct 03, 2009
I need a diagram showing how to route a mower deck belt on a John Deere model 240 mower deck. My spring has fallen off and I need to know where it goes to put the tension on the belt.
Here's a link to an online John Deere parts store. When you land on the page, look at the top sub categories for the size of deck your mower has. You should be able to access a parts diagram with pictures of your belt's proper placement.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Mar 07, 2016 | John Deere Garden
My Motion Drive Belt slipped of it's pulley on a Husqvarna Riding Mower Model 917-289570. Do I have to remove the rear tire to put the belt back on?
i had a 2148. you remove the mower deck as the first step. feed the belt over the pulley on top the transmission, then put it over the engine pulley. then have someone push the clutch pedal in so the tensioner pulley moves, put the belt in the guide pulley and on the tensioner. release the clutch put the deck back on and you are good to go. notice there are little keepers welded to the frame for the front, engine, pulley and it is easy to mistakenly put the belt over them instead of under them.
a general rule is that a pulley shaped like a Vee takes the V of the belt whilst a pulley which is flat takes the flat back of the belt. if you bear that in mind you will not have a problem putting belts back on. also there is a little decal on top the deck showing how the deck belt and deck drive belt go.
Sep 09, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
How to adjust a belt on a 17.5 ryobi 42 in riding mower belt is loose just keep spining i have to **** the mower foward to move it sometime it takes but most of the time all it does is spin he polley and...
drop the deck and take a long look at the drive belt. somewhere along its path you will see a spring loaded arm with a pulley on the end. that arm is the tensioner, if it is not keeping adequate tension on the transmission end of the belt then either you are using the wrong belt, the spring has been taken off and put back on wrong, or the spring has just lost its springiness. You are going to have to figure out which problem and remedy it. Mower parts are common and are sold at small engine repair shops which you can find in the phone book or with a google search.
one other possibility is that someone has removed the drive belt and put it on incorrectly. there are generally guides close in around the front pulley to keep the belt from jumping off, and it has happened before that someone has unknowingly put a new belt on over instead of under the guide. you have to look close to see this.
Sep 08, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
There is a spring that has come loose located on the deck and it is making the belt too loose and comes off
you may not have the belt alined right , make shure you have it routed the right way with the tensioner pulling the slack and yes the tensioner has a big spring on it , you can,t miss it
Jul 24, 2011 | Garden
Replaced Mower Deck Drive Belt. Belt runs from Engine pulley to Mower deck Pulley. Purchased new belt rom JD dealer. Belt is slack, Is there suppodes to be a tensioner for this belt.
Yes, there is an idler arm with a pulley that presses either inward or outward against the belt to tension it. In some JD mowers, the arm is tensioned by pulling on a long metal rod that latches near the edge of the mower deck, but without the model number I can't be more precise about that. Just look for that extra pulley and arm it's mounted on -- you'll see a tension spring, and you should also see a way to pull the arm away from the spring to place it under tension. Good luck!
Aug 15, 2010 | Garden
How to replace drive belt on john deere model 345
- remove deck
- remove seat and rear fenders
- pry off deck adjusting knob
- remove F/R pedals
- remove floor plate
- use jackstands to prop up entire right side of tractor
- remove (2) screws holding fuel lines on side of frame
- lift out gas tank, set alongside left side of tractor
- remove plastic fan from hydrostat
- disconnect the electrical connector for the electric clutch
- from the top-side - use a 3/8" drive rachet - stick it into the tensioner slot next to the idler, rotate it to take tension off the belt, and remove belt off hydrostat pulley
- from underside - remove front idler (next to electric clutch)
- from underside - remove the "right-most" idler off the spring tensioner
- from underside - remove the "left-most" idler off the spring tensioner
- now the tensioner can rotate fully to take almost all the tension off the extension spring
- pop the spring off the tensioner arm
- the belt should now be able to be removed from the machine
- reinstall in the opposite fashion
- note: to reattach the spring, connect a nylon cord to the spring, and pull it rearward and guide it onto the tensioner arm - you need to stretch it about 1"
- for reattaching the two idler pulleys to the tensioner, get someone to hold the ratchet so the tensioner is positioned for the belt being in it's most-loose position. You may need to wrap the new belt around the hydrostat pulley first, and assemble the last idler pulley and belt at the same time to complete the procedure.
Apr 20, 2010 | Garden
I need to see/know the way to load the tape into the machine- TEAC A-4070 reel-to-reel
In short, the left and right swinging tape tension arms must be held up under tension by the tape....if these are allowed to fall this turns off the deck...
Oct 11, 2009 | Audio Players & Recorders
Noise, idler pully rubbing against middle blade
Unless there is some other means of placing tension on the deck belt, I would say that the idler pulley does. If the idler pulley is on a pivot arm, there is a spring that typically is attached to the pivot arm, near the pulley, that attaches to a post or some other part of the deck, that creates the tension on the belt. Check the belt for proper tension.
Aug 01, 2009 | John Deere Garden
Craftsman 18.5 riding mower when I engage the blades to cut the blades turn But they do not engage NO Power.Blades Turn But Not enough to cutthe grass.
Hi Jeff, If you look at the deck, one or more of those pulleys is a tensioner, It pushes against the belt to tighten it, The rest of the pulleys can be identified by the fact that they only have a bolt through the middle, whereas the tensioner is mounted on an adjustable arm with a slot to allow adjustment. It should also be the only one that the belt doesn't go around the pully it just pushes on one side.If the tensioner arm is all the way to the end of the slot, the belt is streched and will need replaced but sounds like it may have come loose. Some of these decks also have a spring on the tensioner arm and those come off from a stick or other debris. Check it out and if you have a problem let me know and I will try to come up with a diagram. If your mower is that new there should be a belt diagram on the deck. i will need a model number of the deck or mower for that. Good luck!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Threading Diagram
Send me a picture of the front of the deck and I'll mark the picture with the threading pattern, and e-mail it back. ****@rsaaa.com
Jun 12, 2008 | Teac Audio Players & Recorders
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
131 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
