Question about Fujitsu LifeBook S2020 Notebook
Password forget to turn on fujitsu s2020 - Fujitsu LifeBook S2020 Notebook
  • 822 Answers
Please remove and replace the cmos battery after 1minutes.
Posted on Sep 24, 2009
How much is the new motherboard and where to find it?
Kindly call fujitsu help line and enquire.
They may arrange to send it to you via post. But remember you will be required to make payments with your debit or credit card. Thanks
Jan 25, 2013 | Fujitsu LifeBook S2020 Notebook
I'm using fujitsu lifebook s2020 and i have a problem with the wifi..my wifi is kind of disappeared or lost..how can i get it back? thank you
Good Day
The first thing you should check is that you WiFi is on. What I mean with that is that laptops usually have a button to switch on or off WiFi to generally save battery life. If you are sure that WiFi is on (usually the WiFi button's light is on) than check if ou can see a netwok adapter.
If you dont see it, there can be two reasons. 1. Another program which got installed on the laptop has controll over the WiFi and the WiFi will not be controlled my your Operating system. 2. Check the properties of your network place. It might contain the WiFi adapter disabled. Ceck under the properties and ut the tick poxes on "Show if adapter is connected" and "Show if there is a problem".
Last resort is to check under you Device manager (Right click My computer, Manage, Device Manager) and make sure the WiFi adapter's drivers are proberly installed.
Hope this helps
Jul 23, 2011 | Fujitsu LifeBook S2020 Notebook
I need a info on opening case of Fujitsu E8010 notebook to fix power supply connector.
Hi snaq,
I found this detailed blog on how to dismantle a Fujitsu Laptop. First, make sure that your warranty is already expire. :)
Please refer to this blog http://jackrepair.blogspot.com/2006/06/repairing-fujitsu-s2020-ac-jack.html
Mar 15, 2011 | Fujitsu LifeBook E8010 Notebook
I forget the password of bios .. i have fujitsu e8110
Disconnect the battery, unplug it, then open it up. There should be a small round battery called the CMOS battery somewhere in there. Pull that out. Then plug your computer in and boot it up without the CMOS battery. It should say password disabled. Turn it off, disconnect it, put it back together, and you're good to go.
Jan 17, 2011 | Fujitsu LifeBook E8110 Notebook
Lifebook s2020 wont boot
try to replaced memory card or clean it first the pin of the memory card by using dry clothes
Aug 17, 2009 | Fujitsu LifeBook S2020 Notebook
Fujitsu s2020 runing xp pro 32 bit screen **** in and out
Connect an external monitor to your laptop and boot up the laptop. If you get a steady image on the external monitor then the problem is the backlighting. This could be a faulty inverter that supplies high voltage to the CCFL lamp or a faulty CCFL lamp, most likely thw CCFL lamp is nearly burnt out.
This problem can be repaired.
Go to www.lcdparts.net for parts, repair service and DIY information.
Mar 08, 2009 | Fujitsu LifeBook S2020 Notebook
Power button only turns laptop on when I disconnect battery, powe
The four buttons are for changing between your first four windows. Your screen dims to save power.
Your drivers sound like they are messing up your boot-up.
Use safe mode or your trick and use your fujitsu update my drivers program or use a program like Driver Detective.
I hope this fixed your problem.
Jan 20, 2009 | Fujitsu LifeBook S2020 Notebook
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
Usb web camera
do installation of your camera driver
Sep 26, 2008 | Fujitsu LifeBook S2020 Notebook
Fujitsu LifeBook S2020 Notebook Logo
121 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
