Question about HP Photosmart 945 Digital Camera
Pink pictures the other day.... I was using my camera and it started showing lines through the image, the image quality was getting worse and worse.  I figured needs new batteries.  So I put new batteries in it and now it takes pink pictures!  How strange my evergreen pictures look in fushia color!   I tried and tried for a couple of weeks, I checked all the settings, even took the batteries out and restarted, but still pink!  all shades of pink!  Here's where it really gets odd, I got my camera just now and I'm back to normal.  Is this a sign of impending doom?  Do I have something getting ready to go out?  and if so... is it something that will cost nearly as much as buying a new camera?  Thanks!
  • 3 more comments
  • Flipip Jan 10, 2008
    My PS 945 only takes dim distorted pink pictures with lines - they appear this way on the LCD and through the viewfinder. Previously taken pictures appear normally. It's not the SD card - something's gone wrong inside. Can I fix it?
  • Anonymous Mar 15, 2008
    I have the same problem with my HP 945 camera. I tried everything, but it still takes pictures with pink lines through them. Any ideas on how to fix this problem?
  • Anonymous May 25, 2008
    Pretty much the same problem - pink pictures wiyh horizontal line through them - except that I also notice that it takes a long time, relative to before, for the camera to ready itself for a shot.
    I have tried removing the batteries for at least an hour and used the Reset settings option of the Reset Menu. Neither had any effect.
  • Anonymous May 27, 2008
    YES I HAVE GREEN AND PURPLE PEOPLE ALSO, I AM NOT A HAPPY CAMPER RIGHT NOW.
    BOB, STATEN ISLAND NY
    RMATH15829@AOL.COM
  • ohvulca461 May 11, 2010
    If someone has the pictures ,would you please send them to me at ohiovulcan@yahoo.com
    Thanks Steve
Hi all -- This is a physical problem with the way the lens is seated. I didn't figure this out myself; I was told it by a camera repair shop guy who also owned a 945 and had the same problem. Basicly, you adjust the lens, relative to the body, by doing _slight_ rocking and twisting; gripping the lens in one hand and the body in the other. I know the description sounds, and the actions looks, like you are trying to break off the lens, but you do it only as much as it takes to change the image back to normal. Restart and see if it works, if not shut down and 'adjust' it again. Kinda like a chiropractor for your camera -- all it needs is a little manipulation....
Posted on Apr 04, 2009
How can i see those pitures of the Camera back eletronic board
I recently had the same problem with my camera... pink red color screen
but i cannot see the picture so if someone could send them at joel_mallais@hotmail.com
Posted on May 03, 2008
Solution to pink or rainbow image; pink pictures - icon_exclaim.gif Warning: By opening your camera there is a risk from electrical shock – be sure that your camera has had the batteries removed for at least 24 hours for the capacitor that charges the flash to discharge. While generally not capable of injury or death, it will definitely get your attention if you touch the wrong part of the camera if it has been recently operated. I’m not responsible if you electrocute yourself. YOU DO THIS ENTIRELY AT YOUR OWN RISK.
Caution: The procedure that is mentioned here WILL violate your warrantee. The HP850 & HP945 cameras are not designed for the average user to disassemble and repair. These cameras are quite fragile on the inside. If you elect to do this procedure, you do this completely AT YOUR OWN RISK. If you take proper precautions and have good eyes and a steady hand, you can reasonably expect to complete this repair with success – however, NO guarantees are made and/or implied.
Note: This procedure was not developed by me. I am not an electronics guru by any stretch of the imagination even though I am quite capable of doing this procedure having assembled several electronic kits (if anyone remembers those Heath Kit short-wave radios among other projects). A friend, who shall remain anonymous, and is very good with electronics, owns a 945 and compared it to the 850 which is very similar on the inside and was successful in fixing it.
This “rainbow” condition can affect both the 850 & 945 cameras. I personally suspect it will occur more frequently as these series of cameras get older in age and the cameras fatigue with age. The cause of the “rainbow” coloring is actually caused by a micro-fracture in a solder connection on a connector strip inside the camera.
Tools required:
1 set of micro-screwdrivers (Philips and Flat-Blade)
1 soldering pencil, with the finest point you can find with stand and cleaning sponge (unless you happen to have a microscopic soldering station then use it instead)
1 tube/can solder flux
1 small tube/jar of rubber cement
1 set of watch-maker’s magnifying glasses or a stand mounted magnifying lens
2 small trays for small parts, especially the small screws
Step 1
Remove all removable items
1. Batteries – do this 24 hrs in advance to prevent electric shock
2. Memory Card
3. Rubber Eye Piece – this falls off many cameras, it is held on by rubber cement, just peel it off.
4. Open battery door and data/power door (leave open).
5. Unscrew all Philips screws around the back of the case.
Step 2
Gently pry off the back cover using flat blade screw drivers – kind of like opening a can.
Step 3
Once the back cover is off, remove the board assembly that holds the LCD (it has several screws holding it to the main board). The problem connector is directly under the LCD board. There are two types connectors used. The connectors are relatively robust but do use care when opening and closing-lifting the little bar (brown) in the photo [one type] and sliding the brown bar up along the cable [on the other type]. Release the connector on the LCD board cable. Release the connector on the lens cable, push the cable aside and you are ready for the re-soldering.
Step 4
Once you have located the connector assembly (indicated in yellow), The easiest method to resolder and probably the only way to fix this is to flux all the connections on a side then reflow each joint by heating each lead in turn across the connector while gently pressing on each of the contacts to close any microfracture (the cause of the problem). Let it cool completely, repeat on the other side. Take your time, as you will be applying a lot of heat to this small area of the board -- allow plenty of time to cool between each lead.
Step 5
Once the board has cooled to the touch reassemble by reversing (Steps 3 through Step 1) the process of disassembly, carefully making sure that the two connectors are seated correctly, and all screws are correctly placed. One of the final steps is to glue the rubber eyepiece back on with a very small amount of cement – take care not to add too much or get any on the eye piece lens. Insert batteries and card, and hopefully you will have a working camera.
Posted on Mar 30, 2008
  • gazza425 Jan 10, 2011
    Can you send me the photos of the Circuit board so that I can effect this repair
    Regards Gazza425
  • 26 Answers
If you're lucky, it might be a memory card problem. Use another memory card, or format this one and try again. You could try to clean the memory card contacts too (with a dry fabric)
If you're unlucky, the camera has a fault and need repaid
PS.
You did mention checking the settings, but make sure, again, that you haven't changed the white balance into something that could produce the pink cast.
Posted on Dec 16, 2007
What causes a pink section at bottom of screen when turning camera on?
Hi there:
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 01, 2012 | Kodak EasyShare M530 Digital Camera
I have a sony DSC-F717, and when i take pictues, the white colors on the image come out pink and other types the picture has like a green shadow over the picture.
Symptoms shows its start-up of CCD Imager problem in DSC-F717 and in few days, CCD Imager will not give picture data to camera circuit. CCD Imager is part which converts image in electronic signal and that signal / data goes to camera circuit for further process.
Sony will repair CCD Imager problem in DSC-F717 free of cost. Check Sony CCD Imager Support for details.
Jan 06, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
My pictures and the lcd screen come out blurry and pink, with horizontal lines across I have a Sony CyberShot DSC-T1 Digital Camera with 5 megapixels and 3x optical zoom I got in 2004. When I take...
Camera symptoms shows bad CCD Imager in camera and this part needs to be replaced.
Sony has announced free of cost repair scheme for such problem in DSC-T1 models. Please click Sony Support for details.
Thank you.
Sep 20, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
I'm noticing all my pictures have a pink hue to it, and pink bar on top
Hello,,,
Your Canon A80 has problem of defective CCD Imager Sensor and this part need to be replaced.
Good news is that Canon will replace CCD Imager free of cost as per announced free of cost repair scheme.
Click on Canon CCD Advisory for details how to obtain free repair facility.
Good Luck....
Jul 14, 2008 | Canon PowerShot A80 Digital Camera
Broken
Dear schmex,
It sounds like you have a broken LCD screen this shouldn't effect the image quality, but it might get worse over time and it will probably make it more difficult to compose the picture.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 16, 2008 | Fuji FinePix Z100fd Digital Camera
Camera is taking Blurry pink pictures
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factory defect ccd imager. the company recalled those units and replaced with a stronger version of ccd imager ( they are still doing it). check it out.
Nov 09, 2007 | Canon PowerShot SD110 / IXUS IIs Digital...
Pink background
Sep 11, 2007 | Fuji FinePix S5000 Digital Camera
White screen with ghost images
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
It's need repair camera machine shutter.
more detail casio ex-z500 overexpourse
Jul 12, 2007 | Casio Exilim EX-Z500 Digital Camera
HP Photosmart 945 Digital Camera Logo
298 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
