Question about ECHO, Inc. PB-251C Handheld Blower
My echo pb2100 gas leaf blowers pull cord is loose and will not recoil
  • 62 Answers
COULD BE THE SPRING INSIDE THE RECOIL NEEDS MAY NEED A NEW ONE
Posted on Sep 25, 2009
Fuel mix for Echo PB2100 blower
40:1 is the recommended mixture. Hope this helps.
Feb 17, 2015 | Echo Garden
Where is the coil located on a echo handheld pb255 gas blower?echo
just follow the plug wire right to usally under cylinder or near recoil houseing
Aug 17, 2014 | ECHO, Inc. PB-251C Handheld Blower
What do I use to clean the exhaust intake on my Echo PB2100?
With the unit cold you can spray some carb cleaner into the intake and the exhaust screen to remove fouling deposits.
Be safe and good luck
May 30, 2014 | ECHO, Inc. PB-251C Handheld Blower
Pull cord
This is caused by a broken recoil spring. It can be replaced (or sometimes repaired) but it can be a dangerous and dirty job. The spring is cheap, so get a quote from a local shop for repairs.
Nov 19, 2013 | Echo Pb-251 Leaf Blowers
Cord is stuck. Can't pull it
is cord stuck out or in? sounds like possible fan/flywheel cam loose on you which will cause this, take recoil off and see if it rolls over by hand with spark plug out, if so then reinstall recoil and see if pull rope works then, if not check fan and/flywheel on opposite side you will have to dissasemble case to do this, lots of screws, once there check flywheel key in flywheel to see if it has spun, if so you will need new flywheel approx$ 60.00 part hope this helps you
Apr 13, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
Cord is locked, or maybe its the motor. Its an Echo PB260L Backpack
This is easy enough to check. There are 4 screws that secure the recoil starter to the engine. Remove these 4 screws and remove the starter assembly. Pull on the rope and see if the starter is operating properly. If not, go to your local Echo dealer and get a new one...they are about $30. Also try to turn the starter cup by hand to see if the engine is locked up. If the engine is locked up, remove the spark plug and try to turn the starter cup again. If it is still locked up, then the repairs would cost more than a new blower.
Dec 20, 2010 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
The cord sounds like its came loose and won't spin the engine
you need to remove the re-coil mechanism and if the cord isnt too bad retie it on the recoil and rewind the recoil spring and reassemble to the blower
Mar 19, 2010 | ECHO, Inc. PB-251C Handheld Blower
We have a featherlite gas blower model # F1 1500 LE - need part # for pull cord and assembly
Recoil starter pulley - Part # 530071792 (Rope & Handle NOT included)
Recoil starter spring - Part # 545008011
Hope this helps,
Dolf-
Oct 15, 2009 | Poulan Featherlite Gas Blower, with Low...
I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
Sep 25, 2009 | ECHO, Inc. PB-251C Handheld Blower
What type of oil do I need to mix with the gas for the Echo PB 2100?  Also, what ratio?
Misplace your Manual? Want to view a Safety Video? Look up a Part for your ECHO Equipment? Do It All Right Here
  • www.echo-usa.com/documentation.asp?Model=PB-2100&lang=E
  • Echo recommends 89 octane fuel and 50:1 mix to one gallon gas for your pb2100
  • go to this site and find fuel and read about it if you would like
  • i use 40:1 in everything i have and have had no problems
  • The oil you buy make sure it is for 2 cycle engines and not outboard motors
  • 50:1 =2.6oz to i gallon gas
  • 40:1 =3.2 oz to i gallon gas
Jun 07, 2009 | ECHO, Inc. PB-251C Handheld Blower
ECHO, Inc. PB-251C Handheld Blower Logo
460 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
