Question about Fuji FinePix A205 Digital Camera
Camera does not turn on with batteries in it - Fuji FinePix A205 Digital Camera
My nex tech binoculars will not turn turn on . Batteries are good
Was the camera dropped??
If it wasnt dropped try changing the batteries.
install a new or fully charged battery/batteries into the camera.
1. If the camera is on, turn it off.
2. If any accessories (memory card, lens, USB cable, camera or printer dock, etc.) are connected to the camera, remove/disconnect them.
3. Remove the battery/batteries from the camera.
4. Verify:
That you are using the correct battery/batteries for the camera
That the battery/batteries are correctly installed
That the battery/batteries are fresh or fully charged
Follow the battery installation and charging instructions in the camera User Guide
5. Turn on the camera.
Feb 08, 2011 | Cameras
When I switch my camera on it will not focus - my
Did he drop it while it was being used?
Also, I assume that you have fresh batteries.
Why doesn't the lens retract when I turn off my camera or extend when I turn on my camera? Question : Why doesn't the lens retract when I turn off my camera or extend when I turn on my camera? Answer : The batteries may be low or exhausted.
NOTE: If the batteries run low on power, your camera may turn off without retracting the lens. In most cases, this is normal and can be corrected by recharging the camera batteries.
In the U.S. and other countries where the Step-by-Step Solutions and Repair tool is available:
  1. Recharge the batteries or install new batteries.
    NOTE: Rechargeable batteries can be charged in the following ways depending on the camera:
    • Remove the batteries and place them in an optional battery charger.
    • Place the camera in a printer dock or a camera dock.
    • With the batteries installed, connect the camera to an AC adapter or to a computer using a USB cable.
  2. For more information, go to KODAK Product Manuals, and select the User's Guide for your camera. To see the battery charging accessories that are available for your camera, go to KODAK Accessories.
  3. If the problem persists, go to the Step-by-Step Solutions and Repair tool.
    • Select Digital camera, camera dock, or digital video camera.
    • Select Lens.
In countries where the Step-by-Step Solutions and Repair tool is not available:
  1. Remove the batteries, then wipe the battery contacts with a soft, clean cloth.
  2. Install the batteries, then turn on your camera.
  3. If this does not resolve your problem, remove the batteries.
  4. Go to Choosing the Right Battery for Your KODAK Digital Camera, then follow the instructions to verify that you are using the correct batteries.
  5. Install new or fully charged batteries into your camera.
    • With the batteries installed, connect the camera to an AC adapter or a computer using a USB cable.
    • For more information, go to KODAK Product Manuals, then scroll down to select the User's Guide for your camera. To see the battery charging accessories that are available for your camera, go to KODAK Accessories.
  6. Turn on your camera.
  7. If the problem persists, go to Eastman Kodak Company Worldwide Contacts for assistance.
Jul 23, 2010 | Kodak EasyShare C875 Digital Camera
Dosent turn on
1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 27, 2010 | Kodak EASYSHARE M1063 Digital Camera
My m863 kodak camera charging light won't turn on.
Is the camera charging? Remember when charging thought the computer NOT to switch the camera on since this will deactivate the model to charge. Try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 24, 2010 | Kodak EasyShare M863 Digital Camera
New batteries but the camera will not turn on.
New or old. They could still be faulty. Try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 24, 2010 | Kodak EASYSHARE M1063 Digital Camera
Camera wont turn on even with fresh batteries
camera wont turn on even with fresh batteries,it says:"battery low..than beep,beep and turn off"
Jan 21, 2010 | Kodak Easyshare C813 Digital Camera
Whenever I turn camera on it immediately turns off.Battery new and fully charged.
Here are the steps for M873 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 18, 2010 | Kodak EasyShare M873 Digital Camera
Camera wont turn on-batteries are OK
Here are the steps for M763 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 15, 2010 | Kodak EASYSHARE M763 Digital Camera
It won't turn on it drop from me once and now it won't turn on
In order to clearly determine the fault the model of your KODAK camera is needed However I hope this will help: If your cam use AA batteries: Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. If your camera model requires the manufactures batteries: Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 03, 2010 | Kodak EasyShare One Digital Camera
Emprex DSC5100Z camera doesnt turn on.
Here are the steps:
clean cloth.
3. Without the memory card,turn on your camera.
If issue persists camera needs to send for repair,visit www.emprex.com
Thanks.
Regards,
Neerak21
Sep 25, 2009 | Emprex DSC5100Z Digital Camera
Fuji FinePix A205 Digital Camera Logo
23 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
