Monitors
Problem for Monitors
Generic problem for all Monitors
Samsung syncmaster 730b blinking. swi...
By kttyct681 on Sep 24, 2009
samsung syncmaster 730b blinking. switches from digital to analog and back again. is there a way to fix this. not sure if it is compatable with my tower.
Best Solution
posted on Sep 24, 2009
Very Helpful)
reitann
Rank: Wiz
Rating: 82%, 50 votes
Try adjusting your screen resolution to a lower range
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 21, 2009
Somewhat Helpful)
NRage
Rank: Apprentice
Rating: 75%, 1 votes
I did this on my Samsung SyncMaster 204B, Worked like a charm!! The two caps on my board were 820mf 25V. My local electronics store didn't have them (forget radio shack, they **** now), I substituted 1000mf 25v caps. Works great !!
I have to admit I was skeptical but the monitor was worthless at that point anyway. I'm thrilled I was able to save it!!
Thanks for the outstanding advice. I owe you a beer!
Scott
Comments:
Nov 21, 2009
- I have a Samsung SyncMaster 204B about a year and a half old; it started taking a couple minutes to warm up then slowly got worse; 10 minutes to warm up and finally never coming on. The power light would just flash on and off but no picture.
I followed AMPS-N-CAPS instructions here. They worked like a charm!! The two caps on my board were 820mf 25V. My local electronics store didn't have them (forget radio shack, they **** now), I substituted 1000mf 25v caps. Worked great!!
(please excuse the double post L)
Was this helpful?
Yes
No
Solution #3
posted on Oct 24, 2009
Somewhat Helpful)
AMPS-N-CAPS
Rank: Wiz
Rating: 90%, 13 votes
Oct 23, 2009 - This is how it went for me..I have a Samsung SYNCMASTER 2053BW. I leave my monitor on and let it hybernate when I shut down PC. I'm 3 months outside of my warranty. Two weeks ago something started happening. I boot PC and video doesn't come up for 10 minutes, and when it came up it worked perfect. VC/Monitor/MB?? It became 20 minutes and ...now..I have the analog/digital box in top left screen, power light on monitor flashing, no menu available on monitor and none of the other buttons work for anything. I test the monitor on Laptop..nothing(same as above)..I break out the old(working) monitor from deep within the closet. Plug it in and I'm up and running. So...
HOW TO OPEN A SYNCMASTER 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable, two clips super close to where the sets of wires come around the housing and into the panel.Unhook the 4 plugs(pink inside/blue outside)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.
Reassemble but DO NOT re-snap the frame into place....yet... Test it! There is a reason the caps got hot in the first place, therfore it has a good chance of happening again. This is not fullproof...but.....mine has been on now for close to 6 hours with no glitches whatsoever. So I have resnapped mine back together. I hope you can too. - I must also add that this is one of the best producing monitors I have ever seen...in 60hz. The clarity is top notch. If you purchase one get the extended warranty. FYI...I paid $4.00 for those caps.
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
analog power saving mode, how to turn the screen back on from this mode?
Answer
lg flatron w2453v 24'' MONITOR: left half of the screen is clear/correct colors and the right half... (More)
Answer
when i turn it on it makes a buzzing noise then it display a redish picture the its blank but it... (More)
Answer
my screen has a box that says "proceeding" that keeps popping up and making the screen... (More)
Describe your Monitors problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
