Question about O2 Samsung SGH-E250 Cellular Phone
Limited service I can't call, or receive call. showing my mobile error limited service. can anyone help me to fix it.
When i my pc on it show me generic host problem after this msg windows stop network services?anyone tel me
You may occasionally get an error message that reads "This connection has limited or no connectivity. You might not be able to access the Internet or some network resources." It indicates that your PC is having a problem trying to access your network device to connect to the Internet. Very often, a bug that typically affects Windows XP Service Pack 2 causes this error message. This bug causes a loss of your network connectivity in workstations that use Microsoft's L2TP-based VPN (virtual private networking) client to connect to the NAT-based networks. You can fix the "Limited or No Connectivity" problem in a few steps. (If your connection works but you still get the error message, go to Section 2 to learn how to disable it.)
Review the following symptoms and determine if you experience any of them after you install the Windows XP Service Pack 2:
You get the error message "Limited or No Connectivity" when you attempt to connect to your network.
You have a problem connecting to your local area network or to the Internet.
You keep on receiving an error message: "Acquiring IP Address" message. If you experience these symptoms after installing Windows XP Service Pack 2, then this bug is causing the problem. In this case, go to Step 2; otherwise, skip to Section 3 Download the Microsoft patch (KB884020) from the Microsoft website. Run this update to install it. Create a registry fix by launching Notepad and typing: [HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Services\\IPSec] "AssumeUDPEncapsulationContextOnSendRule\"=dword:00000002 Save the file as FixReg.reg to your desktop. Double-click the saved file to install it into your registry. Restart your computer and the error message will likely be gone. If you still see the error message, follow the steps in Section 2. b> If Your Connection Works But You Still Get the Error Message b> Navigate to the "Start" button and select the "Control Panel." Double-click on the "Network Connections" icon. Right-click the "Local Area Connection" icon and select "Properties" from the popup menu. Click on the "General" tab. Uncheck the option that is labeled "Notify me when this connection has limited or no connectivity." Click "OK." b> If the Patch Doesn't Fix the " Limited or No Connectivity" Problem b> Check your DSL router for any malfunctions. Re-configure or power cycle your router. Check your computer's network card configurations and network cabling to ensure that the problem does not lie here. Check your firewall to determine whether it is blocking you from connecting to the network or to the Internet. Disable the firewall and attempt connecting to the network or Internet while with the firewall is disabled. If the firewall is causing connection problems, then reset or uninstall and re-install the firewall. Reduce your connection speed to 10 Mbps and test this to determine if it fixes the problem. To do so, navigate to the "Start" menu and select the "Control Panel," "System" and "Device Manager." Review the properties of your network card. Click the "Advanced tab." Locate the "Link Speed and Duplex" section. Change the settings from "Auto Detect" to "10Mbps/Full Duplex." Hope this helps.
Dec 24, 2012 | Computers & Internet
It shows limited connectivity.conneced but no internet.i diagnoused and it saysnot getting valid ip.once i got connected and it worked for few second and stopped and showing limited connectivty.after...
When your network shows limited connection, it could be that you system did not pick IP address from your DHCP server. so it assigned itself a public IP address. In this case make sure your system has the correct networking setting and it can reach the DHCP Server. If you are using a modem, the service from your service provider may be poor in your area.
May 18, 2010 | Computers & Internet
Samsung mobile Model SGH X620 shows ''Limited Service''!!!???
samsung mobil SHG-X620 LIMITED SERVICE SOLUTION<!-- from fixya rte -->
Oct 12, 2009 | Cell Phones
My samsung D900i is showing "limited service" for the pass five days now, I can't call and... (More) my samsung D900i is showing "limited service" for the pass five days now, I can't call and I can't...
that is because you dont have mobile signal at all or very poor in your location. try to get somewhere else to see if it improve. maybe you have to go long way.
you can see it somewhere on top corners of your display
[battery is one and signal is the other one]
Aug 07, 2009 | Samsung SGH-D900 Cellular Phone
Problem in SGH X620, NO imei, Limited service
problem in sgh x620 ,no imei ,limited service
Jul 02, 2009 | Samsung SGH-G600 Cellular Phone
Limited service proplem
Try to call your service provider to check the network configuration of your phone to refresh your account..
Jun 24, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
All airtel sim shows limited service on sgh-e250 b
my problem is i can't call and reseving calles to my sgh-e250 and showing limited service on display
Nov 09, 2008 | Lands Phones
Mobile is showing limited service,whats the problem
my mobile is showing limited service
Aug 09, 2008 | Cell Phones
Limited service
you need to change the band frequency on the phone....for it to work with the mobile provider that you are using.
Feb 08, 2008 | Samsung SGH-D900 Cellular Phone
O2 Samsung SGH-E250 Cellular Phone Logo
207 people viewed this question
Top O2 Cell Phones Experts
Computer Repairing
Computer Repairing
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Are you an O2 Cell Phone Expert? Answer questions, earn points and help others
