Question about Uniden Cordless Phone
GE 2.4 ghz card less phone
Dial tone is not coming. How to activate
  • Anonymous Dec 16, 2007
    AC/DC Power not connecting, hence not charging at all. Dial tone is also so low it cannot hear from very near.Hence the cordless handset is useless since last 3-4 month. No support available for me. My Product code is ES 27923GE2-B (GE 2.4 GHz)
  • Jeshu Mar 18, 2009
    AC/DC Power not connecting, hence not charging at all. Dial tone is also so low it cannot hear from very near.Hence the cordless handset is useless since last 3-4 month. No support available for me. My Product code is ES 27938GE6-C (GE 2.4 GHz)
Change langugeon a 27923 GE cordless phone
Posted on Mar 12, 2009
Posted on Dec 16, 2007
Can get dial tone but cant dial out
If you haven't tried it yet, reverse the two incoming line wires. Some phones have to be a particular polarity. I have had a case where things were working, then a lineman somewhere reversed the connections at a pedestal someplace and my phone would not dial.
Jul 25, 2009 | GE 5.8 GHz Cordless CID Speaker Phone X 2...
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
GE 2.4 GHz cordless telephone problem
Hi there, maybe I can help;
Is the phone base plugged into an switched outlet and is the switch off?
Let me know if I helped
Jan 06, 2009 | GE 21008GE2 Dual-Handset Cordless...
No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
Model 25922 5.8 GHZ Cordless phone with one main phone and two extras
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ge Telephone Solutions
Handset can not link.
• If any handsets become inoperable, place it on the main base cradle for 20 seconds to re-register.
No dial tone
• Check or repeat installation steps
• Make sure the base power cord is connected to a working electrical outlet.
• Make sure the telephone line cord is connected to the base unit and the modular phone jack?
• Disconnect the base from the wall phone jack and connect another phone to the same jack. If there is no dial tone on the second phone, the problem might be your wiring or local service.
• The handset might be out of range of the base. Move closer to the base.
• Make sure the battery is properly charged (for 16 hours).
• Ensure the battery pack is installed correctly.
• Did the handset beep when you pressed the TALK/CALL BACK button? Did the in use indicator come on? The battery may need to be charged.
http://www.home-electronics.net/ge/pc/IB/25922GE2_IB.pdf
Sep 02, 2008 | GE 26998GE1 Cordless Phone
GE 5.8 ghz cordless phone
the menu will take you to registering the hand sets to the base unit
by deleting incoming calls you have disconnected from the line
follow the instructions in the user manual to get reconnected
if you do not have the user manual , go google and type in --user manual for ge ( model ) cordless phone --and down load the pdf version
May 25, 2017 | GE 27957GE1 Phone
GE - 25951EE1
If it is on an additional phone base (not the main), put the phone back on the main base for less than a minute.
May 01, 2007 | Uniden Cordless Phone
No dial tone on handsets
Hey.. Did you check to see if the phone is registered correctly ???
Jan 09, 2007 | Olympia CDP 24201 Cordless Phone
Uniden Cordless Phone Logo
526 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
