Graphics Cards
Problem for Graphics Cards
Generic problem for all Graphics Cards
I have Geforce Fx5200 128mb pixel sha...
By faisal_6600 on Sep 24, 2009
I have Geforce Fx5200 128mb pixel shadder 2.0 and i cant run crysis, call of duty 4 is there any way to run these games ?
Solution #1
posted on Sep 24, 2009
Not Rated)
joecoolvette
Rank: Guru
Rating: 92%, 576 votes
Yes with a better graphics card. You need Shader 4.0 at least on that graphics card. (Plus a lot more Stream Processors)
The GeForce FX 5200 is an AGP style of graphics card, and uses 8X speed. (0.8 Volts)
It is a Budget graphics card, and does not have the graphics 'power' needed for the games you stated.
(If memory serves it has 16 Stream Processors)
There is no 'miracle' program, or tweaking of settings, that will allow you to run the above stated games at a decent capability. Even at low settings for the games.
I would suggest an ATI HD Radeon 3850 at least.
HOWEVER, other things come into play.
You need a 400 Watt power supply that has 30 Amps on the 12 volt power rail. The power supply must have a 2x4 power cable. (Example:
http://www.playtool.com/pages/psuconnectors/connectors.html#eps4plus4 )
OR, enough 4-pin Molex power cables that are unused to put in a 2x4 power cable adapter.
Your processor has have the processing power needed also, or you will have a 'bottleneck' of graphics information.
A graphics card has it's own processor. (GPU. Graphics Processing Unit)
It also has it's own Ram Memory. (Graphics ram memory)
However if the processor is too slow, the graphics information cannot be processed from the processor to the game program, and vice-versa, in a speedily fashion.
Graphics information, (Data), hangs up. Frames freeze, and frame rate slows down.
Post the computer name , model name. and model number, and we'll see if a better graphics card will help.
(Example: HP Pavilion D5200t)
Was this helpful?
Yes
No
Solution #2
Not Rated)
raklein62
Rank: Wiz
Rating: 85%, 123 votes
I have the same card and you should be getting 256mb maybe the shadder 2 takes the other 128mb. I've seen cards in the 7000's that had a hard time playing those games. The updates I don't like. I use a later version. But, No, You have to get up to 512mb and 1.5 to 2 gig RAM 2 ghz computer power to play the real neat high graphic games.
Was this helpful?
Yes
No
Popular Solutions for Graphics Cards
Questions and Unsolved Problems for Graphics Cards
Answer
So I'm trying to install a ATI Radeon X1650 Pro AGP card, I've seen where other people have tried... (More)
Answer
How do i program remote to turn on and off tv
Answer
is there a security ability on the optima pro attach'e 2G? If so, how does one enable it?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Graphics Cards:
Top Graphics Card Experts
Rank: Guru Guru
Solutions: 14935
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Graphics Card Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
