Question about Haier AHD25 Dehumidifier
Haier 32- Compressor seems to run , but the fan doesn't
4 Suggested Answers
  • 4736 Answers
SOURCE: compressor seems to be overheating
If the compressor motor is overheating, it's usually a result of low refrigerant gas in the cooling coils. Recharging is an option, if you can find a shop that will do it.
Posted on May 22, 2011
  • 794 Answers
SOURCE: Model BHD-301 dehumidifier compressor will
Hi bash123er,
If you're facing these problem that your dehumidifier is not producing water and compressor is shutting off then there are few things that needed to be checked on:
1. The very common problem with most dehumidifiers is the circuit board relay. If this has gone bad then it will require replacement.
2. The compressor has already gone bad. This is the problem if you notice a buzzing sound every now and then from the system.
3. You may also have a refrigerant leak. This happens when the compressor is running but coils are not getting cold at all.
4. There will be cause of low water production if the fan is not running and the compressor does. If fan is not running then you have to replace it. This also will result frozen coil.
5. Check to see also if your coil is blocked. This will also result into no water production.Air needs to be continually moved over the cold coil to get the water out of the air.
If you're not comfortable doing the checking and repair yourself then I would recommend that you contact a repairman.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 03, 2011
heatman101
  • 43501 Answers
SOURCE: I have Haier HD656e which
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Aug 13, 2011
Why isn't it dehumidifying?
The compressor may not be running. You could be hearing just the fan.
You may not have humidity level selected
You may not have cycle time selected
The condensate collector may not be installed correctly to operate the interlock. The fan will run but not the compressor
Sep 05, 2015 | Haier Dehumidifiers
Does the Fan on a Haier HD456E always run,
I believe the fan is designed to run all the time, and no, it costs very little to run an 18w fan. You can use a timed socket, or switch it on and off when needed. I don't believe the Haier has specific switching times.
Apr 16, 2012 | Haier HD456 Dehumidifier
I have Haier HD656e which powers up, all controls work and the fan runs, but no water runs into the bucket. The compressor doesn't appera to come on. Anything simple I can check?
heatman101
Jul 28, 2011 | Haier HD656E Dehumidifier
Compressor running very hot but almost no cooling. Fan running
make sure the coils are clean both evaporator and condenser,then if there is a capacitor in the motor circuitry,check this,finally if the coils frost,then clear up and frost and clear up time and again,this is a sign of low refrigerant R134a,and this also will make the compressor run hot
Apr 09, 2010 | Haier 45-Pint Dehumidifier
The fan is on but no water is collecting
Check to see if compressor is operating.
Apr 08, 2010 | Haier 45-Pint Dehumidifier
Dehumidifier Brand haier HD456E does not pull water and the tank is empty, after 24 hours of running with water on wood floor. Can't find manual or online info for this model.
I have 3 HD656E Haier Dehumidifier with the same problem runs but no water in bucket. How many did the Haier company make with this problem?
Apr 12, 2009 | Haier HD656E Dehumidifier
The compressor does not seem to start or kick in.
need help to set date/month/year/ and time on my polaroid i830 digital camera
Apr 05, 2009 | Haier HDN455 45 Pint Dehumidifier...
Haier HDN455 dehumidifier fan runs continuously but not compressor
First ! you are trying to use this dehum in cold weather conditions. this time of the year there is little humidity in the air. best conditions for the dehum to work will be when the temp. is 65 degrees or high, and the humidity is 60% or higher. if you don't trust what I said then take it to sears to be checked out.
Dec 22, 2007 | Haier HDN455 Dehumidifier
Haier HDN655E unit runs but compressor won't kick in
use a jumper cord and go directly to the compressor to see if it will run. if it don't run, open up the motor box and see if there is a klixon overload inside. this should be normally closed. if it isn't replace it. the klixon is a thermal overload cutout. it usually trips because of high winding temperatures and protects the motor inside. the compressor is a hermetically sealed unit. no, or little freon will cause the motor to overheat.
Aug 21, 2007 | Haier HDN655E Dehumidifier
Haier AHD25 Dehumidifier Logo
Top Haier Dehumidifiers Experts
Steve
Shawn DuRee
Michael Vincent Cruz
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
