Question about Compaq (173907001) for ProLiant DL380 / ML350 / ML370 CPU Fan
Proliant ML370T02 boot problem
What should I do when my ML370T02 is alerting on boot like this: Fan solution not sufficient
critical fan failure in Fan Zone CPU and Fan Zone I/0
I only got one procesor in Slot1 and one hotswap fan to cool it, Slot2 is empty and so is I/O slots but there are empty slots for hotswap fans and I only got one for the procesor so I'm unable to fill those slots.
The computer isn't booting at all and I'm unable to access BIOS
Need help.
  • 64 Answers
Sounds like the CPU fan has gone bad and needs to be replaced
Posted on Sep 24, 2009
Server no display when power on
Can you confirm that server fan is rotating or not when server power on. and which led glowing red when you power on server
Mar 15, 2014 | HP Compaq ProLiant ML350 G3 Server
Processor overtemp
Check the heat sink / fan ASAP. The tempature is extremely high and may cause a critical hardware failure. You may even need to replace the CPU fan.
Dec 31, 2012 | ASUS US P8H67M PRO Desktop Motherboard...
Fan failure detected
REPLACED YOUR FAN YOUR ISSUE WILL RESOLVE
Feb 08, 2012 | HP Compaq ProLiant 800 Server
Hi, My HP Proliant DL360 G3 server just doesn't bootup due to the following error"CUP Zone Fan Assembly Failure Detected". When I turn it on, it emits continuous beeps and then turns...
Check and Clean Processor FAN and all cooling Fans inside the server.
Check the cable connectivity of the CPU Fan on the M/B.
Update server with Latest BIOS firmware.
Aug 02, 2011 | HP Compaq ProLiant DL360 G3 Server
Fan failure from the start..power failure
open your cpu check whether your fan running or not, if it run mean , go to bios and disable the alert so that you can log in to your OS.
If fan not run mean
Open up the case, check the CPU heatsink fan is connected to the motherboard, if it is try booting up with the side panel still off, does the fan spin up?
Check it, good luck
Jan 11, 2011 | ASUS P4S800 Motherboard
Compaq dl380 g1 - 1611 Power Supply 1 Fan Failure Detected
it only ur fan problem which one of the four fan or two ,might be stuck or jammed which starts after of couple of restarts, so i sugest u to check the fans when in operation
good day
Jun 01, 2010 | HP Compaq Proliant DL380 G1 Server
HP proliant dl 360 g3 error code 1611 cpu fan failure
Remove all 6 fans, and then remove the fan rack itself. Then tighten the 2 pcb thumb-screws underneath. I believe this is sometimes the reason for false 'failed fan' reports.
Feb 02, 2009 | HP Compaq ProLiant DL360 G3 Server
Fan flow error 1611 I/O
The ProLiant DL380 G3 server requires that both primary and redundant fans exist in a specific configuration in order to perform optimally. Any deviation from the specified configuration will cause one of the above error messages to occur and the internal Health LED to illuminate. In a ProLiant DL380 G3 server without the redundant fan option, the server will shut down after the error message is displayed. In a server with the redundant fan option, the internal Health LED will illuminate and the appropriate error message regarding fan redundancy will be displayed. The purpose of this document is to detail the required configuration for both primary and redundant fans.
DETAILS Both primary and redundant fans in the ProLiant DL380 G3 server must be configured to meet specific requirements in order to avoid the error messages above and in some instances, subsequent shutdown of the server.
All primary fan locations (2, 4, 5, 6 and 7) must be populated with a fan before the redundant fan locations (1, 3, or 8) are populated. If a primary fan location is left unpopulated, the server will display one or more of the error messages shown above. In addition, the internal Health LED (the top LED on the front panel of the server) will display the status of the fans.
When the redundant fan option is used, all redundant fan locations must be populated. ProLiant servers do not support partial population of redundant fans. If any redundant fan location is populated without also populating all other redundant fan locations in the server, the fan system will not be fully redundant and one or more of the error messages above will be displayed.
Figure 1 below illustrates a ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy. The server airflow is divided into three zones: processor, I/O and power supply. Shared fans 4 and 7 each provide airflow for two zones. If a shared fan fails, the failure is experienced in both zones.
Figure 1: ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy
The internal Health LED (the top LED on the front panel of the server) indicates failed or missing components. The internal Health LED should be observed to determine the status of the fans as follows:
RED LED: A red LED indicates that the minimum fan requirements have not been met. Minimum fan requirements indicate that all primary fan slots must be populated with functioning fans.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan has failed.
AMBER LED: An amber LED indicates that the minimum fan requirements have been met; however, requirements for redundant fan configuration have not been met. This means that all primary fan slots are populated with functioning fans, but at least one redundant fan has either failed or is missing.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan has failed.
Note: In a redundant fan configuration, the error message fan system not fully redundant will also be displayed at POST if any redundant fan slot is left unpopulated or if a redundant fan has failed.
Nov 21, 2008 | HP Compaq ProLiant DL580 G4 (430811001)...
Compaq (173907001) for ProLiant DL380 / ML350 / ML370 CPU Fan Logo
322 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
