Question about Dryers
Defy Autodry 45: Busy re-assembling after having dismantled the drum & driveshaft to repair. Now i have a ''spring'' that i do not know where it is suppose to go? I think it helps to keep either the drum or shaft to '' float '' ?
4 Suggested Answers
  • 16 Answers
SOURCE: Defy dryer, not heating
Check that you have 220v first. Your dryer will work on 110V but will not dry. You need to check all thermostats with a ohm meter (be sure to unplug dryer), they should be 2 ohms or less. Set ohm meter to 1x. If they are good go to heating element (your ohm meter should be on 1X as wel. You need to check to make sure you have continuity (however, this does not mean that it is not bad). You need to take it out and visually inspect it to make sure it has no breaks in the coil. If it does you can buy a rewire kit for runder 30 bucks for most models.
Posted on Jan 06, 2009
  • 3074 Answers
SOURCE: DEFY AUTODRY WIRING DIAGRAM
disconnect dry and in the back of dryer in top left hand corner is your diagram, looking from back of dryer, just remove the 6 screws from the top panel at the back of the dryer Good Luck Tim
Posted on Dec 26, 2010
heatman101
  • 43501 Answers
SOURCE: Defy autodry, comes on timer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 18, 2011
Defy autodry tumble dryer
This will be bearing noise, the front of the drum uses a felt strip as a bearing and this can wear causing a metal on metal grinding sound, or it could be the rear bearing. You need to dismantle it to investigate further.
Mar 06, 2012 | Cell Phones
I'm trying to figure out how to remove a bearing from driveshaft off 2002 lincoln ls
Which bearing? The hub bearing? I can send it. I have your Ford shop manual & wiring books for $25, plus $4 shipping. Let me know.
SECTION 205-01: Driveshaft 2002 Lincoln LS Workshop Manual
DISASSEMBLY AND ASSEMBLY Driveshaft Center Bearing
Special Tool(s) s2x~us~en~file=st1260a.gif~gen~ref.gif 2-Jaw Puller
205-D026 (D80L-1002-L) or Equivalent s2x~us~en~file=st1368a.gif~gen~ref.gif Puller, Bearing
205-D064 (D84L-1123-A) or Equivalent s2x~us~en~file=st2454a.gif~gen~ref.gif Driveshaft Alignment Bushing Remover Tube
205-D073 or Equivalent
Disassembly
  1. Remove the driveshaft (4602). For additional information, refer to Driveshaft in this section.
  1. Separate the front and rear shaft assemblies.
  1. s2x~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not clamp on the driveshaft tube as a fracture can result.
    Position and clamp the driveshaft at the weld yoke.
  1. Using the special tools, remove the retaining ring and the center bearing and bracket assembly (4A499).
Assembly
  1. Position the center bearing and bracket assembly and the retaining ring on the yoke.
  1. Using the special tool, drive the retaining ring and bearing assembly until fully seated on the yoke.
  1. s2x~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Align the index marks or driveshaft imbalance can occur.
    Assemble the front and rear shaft assemblies.
  1. Install the driveshaft. For additional information, refer to Driveshaft in this section.
Sep 08, 2011 | Lincoln LS Cars & Trucks
Defy autodry, comes on timer works but will not tumble
heatman101
Aug 15, 2011 | Dryers
Where can i find a maneul on a defy 721
Check in this two links:
- Defy AutoDry
- Defy AutoMaid
Both in PDF format.
Apr 25, 2011 | Ovens
My kenmore 110.66512694 is not drying and is not turning off automatically, i have to turn it off myself or it will run forever.
Their are 2 types of dryers. Electronic dryness sensing style and Autodry style. Yours is Autodry.
Electronic dryers have a dryness board which relies on info from moisture sensing bars that the wet clothes rub against. AutoDry models like yours alternates the power between the heating element and the timer motor. This is what you heating assembly looks like:
Check all the components on the heating assembly for continuity.
I have a service manual and more HERE
Apr 01, 2011 | Kenmore Dryers
How to disassemble the rear end in a 2000 gmc yukon and how to remove axles
Removal & Installation To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section
  2. Loosen the lug nuts on the wheel and tire assemblies but do not remove the lug nuts
  3. Raise and support the vehicle
  4. Remove or disconnect the following:
    • Wheel and tire assemblies
    • Axle lubricant into a suitable container
    • Rear driveshaft
    • Parking brake cable
    • Brake calipers
    • Shock absorbers from the axle brackets
    • Vent hose from the rear axle vent fitting
    • Nuts and the washers from the U-bolts
    • U-bolts, spring plates and spacers from the axle assembly
  5. Lower the axle assembly from the vehicle
To Install:
  1. Place the rear axle assembly under the vehicle
  2. Align the rear axle assembly with the springs then connect the spacers, spring plates and the U-bolts to the rear axle
  3. Raise the rear axle assembly into position
  4. Install or connect the following:
    • Washers and nuts to the U-bolts; Torque to: 59 lb-ft. (80 Nm) then, Torque to: 89 lb-ft. (120 Nm)
    • Vent hose to the rear axle vent fitting
    • Shock absorbers to the rear axle
    • Brake calipers (See: Brake Caliper)
    • Parking brake cable (See: Parking Brake Cable)
    • Rear driveshaft (See: Rear Driveshaft)
  5. Fill the rear axle with lubricant
  6. Bleed the brake system (See: Brake Bleeding)
  7. Install the wheel and tire assemblies
  8. Lower the vehicle to the ground
  9. Torque lug nuts as follows:
    • Single Wheel: Torque to: 140 lb-ft. (190 Nm)
    • Dual Wheel: Torque to: 175 lb-ft. (240 Nm)
  10. Road test the vehicle to check performance
Aug 03, 2010 | 2000 GMC Yukon XL
Driveshafts
I reccommend that you replace that small spring after all that spring is the only thing that holds the shaft in the cv. (usually when you replace a cv boot the new kit comes with a new spring ) this means that you will have to replace it every time you dismantle it.
Good luck and I hope this answer helps.
Sep 08, 2008 | 1995 Audi A6
Maytag washer door boot
   Remove 2 screws holding door hinge to cabinet and remove door.  Then remove 2 screws opposite these. Grab front panel with thumbs at area of screws you removed and pull outward with thumbs. Panel will pivot forward.  Remove panel from lower clips.  At top of exposed area remove 2 5/16 screws.  Remove brackets under them.
  Open dispenser and remove 4 screws.  Careful not to drop in dispenser.  Remove dispenser frame assembly.
  You can now raise top of washer to a 90 degree position.
   Now back to front exposed area.  Grab boot where it contacts front and peel out of groove.  Also remove two screws holding light assembly and remove cover.  Remove all 5/16 screws holding front assembly and the ones on top area where it is on a bevel.  Remove front assembly by folding up and onto top.
  Now we are at the boot.  Remove spring and wire assembly holding boot to drum.  Make note on boot position and spring position.  Remove boot.  Install new boot onto drum.  wrap wire around drum with ends at top.  Now the fun!  Hook spring to on end of wire and using vise-grips,  pull to other end to hook into wire.  It can be done,  honest.
  Now just reverse to reassemble.  should be instructions with boot.   Good luck!
Oct 14, 2007 | Maytag Neptune MAH5500B Front Load Washer
Dryers Logo
236 people viewed this question
Top Dryers Experts
