Question about Refrigerators
Water is freezing when it runs down the water trough to my ice maker. I have the Freezer settings pretty low (my options are A the warmest, B or C the coolest and I have it between A and B). Are there there any other solutions besides just turning the down the temp control a half notch to A?
  • Refrigerators Master
  • 1,606 Answers
The refrig water valve , is seeping . This means that it isn't closing completely , letting a slow drip run down the fill tube and freezing . Replace the water valve (piece the wall water line connects to on the back of the refrig ) and I believe this will solve the problem .
Posted on Sep 25, 2009
Testimonial: "Thanks aasc - I will try that."
Tfx25ppbb. Water leaks into bottom of freezer when refilling ice tray in automatic ice maker. Ice still gets made but water leaks to the bottom of freezer. When enough freezes, it leaks out the door
It's probably not the ice-maker. It has a plugged drain. This is located in the back wall of the freezer near the bottom. remove the evaporator cover...(the back wall of the freezer). Below the coils is a trough with a hole in it where the defrost water drains. This is probably frozen over.
Pour some hot water in to trough until you see drain hole. Keep pouring until water runs thru drain. May have to shut down ref to get it to defrost.
Oct 20, 2014 | Refrigerators
Ice maker not making ice
First, ice build up may be keeping the arm from dropping. Manually push it down, but do not force it. If it comes down, turn your freezer to as low as you can.If it does not come down. Remove all the frozen food and turn the freezer to the warmest setting and let it thaw. The arm then should be able to be pulled down. Then turn the freezer to the coldest setting for ice. It that doesn't work, you probably need a new water valve.
Feb 21, 2014 | managemylife.com
Ice in the bottom of freezer ABB224WEB
If you have an ice maker, it may be overfilling. Ice makers have a trough that dispenses the incoming water to the tray. If the ice freezes in the trough the incoming water sprays all over the freezer compartment and settles in the bottom. I fixed the same problem by thawing out the trough with a hair dryer. Then I switch the cube size from "large" to "medium" to keep it from overfilling. I have not had the same problem for years.
Oct 31, 2013 | Amana ARB2217C Bottom Freezer Refrigerator
I have ice building up in the bottom of the freezer even with the ice maker off. Where is the water coming from and what is the fix? I can see a slight trail of ice down the back behind the ice maker and...
From what you described the defrost drain trough is frozen up. The drain tube or the opening in the drain trough is stopped up with some sort of debris and is frozen over.
Each time the freezer goes into a defrost cycle it melts the ice on the coils and the water has no place to go. The result is that water will leak into the freezer compartment, collect on the floor of the freezer and freeze solid.
Mar 20, 2011 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Seems the freezer door was not completely closed. Ice started ot melt and then form icicles! Well we closed the freezer the next morning. Now the ice maker and water dispensor are not working. In...
when you closed the door, the freezer froze all the condensation/melting ice,hence the icemaker freezing.
the best solution is a TOTAL defrost/clean out,then dry out.DO NOT USE HOT WATER/SCRAPERS,let it defrost naturally or use car de-icer.wipe out with bicarb to keep fresh.and then restart as new.
Sep 11, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Ice build up in bottom of freezer
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Nov 16, 2008 | Refrigerators
Water freezing on the tray section under the freezer drawer.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 15, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
WATER pooling in bottom of fridge
did you try to remove the 2 ***** in freezer floor???. if not remove the floor and check for ice build up underthere, if so:
Mar 12, 2008 | Whirlpool ET8RHMXKQ Top Freezer...
Defroster leaks
Feb 25, 2008 | Whirlpool (ET8FTEXSQ) Top Freezer...
Kenmore Model 78185891 type C21TFA95, water leakage problem
Feb 24, 2008 | Refrigerators
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
