Question about Garden
Broken starter cord on a mountfield M6 lawnmower - how do you re attach the cord
  • 389 Answers
This unit is supposed to have a Briggs & Stratton engine on it so:
Here is the instructions DIRECT FROM BRIGGS & STRATTON:
This is a relatively simple process, but you have to be VERY careful when doing this. The spring is long, under some tension and has sharp edges. Anytime you are dealing with the manual rewind starter assembly, there is risk of the spring coming out and possibly injuring yourself or others. If you do not feel comfortable performing this repair, I strongly suggest visiting one of our many authorized dealers in your area and have them do this for you.
You will have to remove the gas tank to get at the rewind and blower housing. Remove the entire blower housing and rewind assembly and turn it upside down.
NOTE:You do not have to drill out the rivets to get to the back of the rewind assembly. This is only necessary if you are removing the ENTIRE rewind assembly, (metal housing and all) and are separating it from the blower housing.
You'll need a pair of vise grips or a screw driver, some rewind rope, a long thin sharp tip flexible object (the wire from a coat hanger may work) and a lighter handy.
  1. Take the pulley and start to turn it so that the rope becomes loose.
  2. Remove the rope.
  3. Once the pulley is all the way out, with the most tension, either use the screwdriver between the spokes of the pulley, or use the vise grips to hold the pulley in place; be careful not to place too much pressure on the vise grips, the plastic pulley may break!
  4. Make sure that the hole in the pulley lines up with the hole on the rewind assembly.
  5. Using the wire from the coat hanger, push the rope through the hole of the rewind and pulley. Pull the rope through the pulley and tie it off. Now use the lighter to burn the end of the rope to prevent the not from coming off.
  6. Now, remove the screwdriver or vise grips, while holding on to the pulley.
  7. SLOWLY let go of the pulley and the rope should feed back into the pulley as you do this
Hope this helps you
Posted on Sep 24, 2009
  • bell_52 Jul 08, 2011
    brilliant comments to resolve broken string..... thankyou very much :) the green reaper
How do you replace the piece that the belt an blade are attached to on a mountfield RV 150
you talking about the self propelled model
Repairing Lawnmowers For Profit Part 55 Replace Mountfield Lawnmower Drive...
the blade is a one piece ..you take that off
take off the belt cover
if really stuck .. use a puller for the pully/blade boss
remove the back plate to get to the idler tension pully
there was a tension device or ider pully and spring
for the belt tension
Jul 03, 2016 | Garden
Pull cord won't pull on Snapper 6.75 exi
HOW TO Replace a Broken Lawnmower Pull Cord - YouTube
? 5:53
www.youtube.com/watch?v=G02OobT7fII
Oct 4, 2011 - Uploaded by donyboy73 Easy to follow video tutorial on how to repair a broken lawnmower pull cord. The procedure for this lawnmower ...
Sep 21, 2015 | Snapper Garden
Pull cord on my lawnmower is inoperative
You need to take the Starter cord assembly off and see if the Nylon gearing that 'grabs' the centrifical wings is broken OR those wings are rusted in a way that they do not make contact with the nylon piecs of the Starter.
Dec 07, 2012 | Craftsman 55 Torque 158cc 22" Push Lawn...
Start cord will not wind back
make sure your blade brake in dengaged or the spring is broken or dirty inside starter coil houseing
Jun 17, 2012 | Briggs & Stratton Briggs Stratton...
How much oil does a mountfield omega lawnmower take
If it is a small horsepower engine 4, 5, 6 HP, it will take approximately 20 ounces. If it is a larger engine8, 9 ,10, 11, 12 and on up it will take from 40 to 48 ounces
Sep 13, 2009 | Garden
Garden Logo
1,182 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
