Question about Samsung HLP4674W 46" Rear Projection HDTV
The location of the lamp for
I nee to find out the location of the lamp for tv model HL-P4674W/HL-P5674W
    President:
  • 788 Answers
The lamp is in the rear of the set and is a square shape with 4 screws. You will need a Phillips screwdriver to remove the panel and then the lamp housing.
Here is a link to a simalar manual.
http://downloadcenter.samsung.com/content/UM/200408/20040817140040687_BP68-00283A-02Eng_0506.pdf
I hope that this helps you out.
Thanks for using FixYa
asnowman
Posted on Sep 24, 2009
Samsung hl-p55063w TV MAKES A BUZZING NOISE WHEN I TURN IT ON COULD THIS BE THE COLOR WHEEL? WHERE IS IT LOCATED .
Color Wheel BP96-00674A Located right behind Lamp Pull Lamp out use a flace Light and you can see Color Wheel.
Encompass Parts Distribution has Free Service Manual that you can print out online for this Model. 1-800-638-3328
Sep 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
How do i remove lamp from samsung HL-85086W
Unplug the TV. Locate the lamp door on the back of the TV. Take out the 4 screws and remove the lamp door. Remove the screw holding in the lamp. Locate the handles on the lamp and pull it out. Clear any wires that may get in the way as you remove it. Reverse process for installation. Make sure you do not touch the bulb, skin oils will damage it. Also, some models need to have the bottom of the lamp door be installed first, the top of the door will then swing unward... as if hinged. The reason for this is to properly engage the lamp door safety switch (the little blue level on the left). This is only some models, if your door does not install in this fashion, just push it straight in. I hope this helps.
Mar 17, 2010 | Televison & Video
Where is ballast located
FOX has Lamp for $109.00 1-800-227-5369
Encompass Parts has Ballast $54.43 1-800-638-3328
Encompass wants $150.00 for lamp Your TV is a Samsung it will be on Right Hand Side of TV and I would Just Replace The Lamp First? What was your TV doing to begin with?
Dec 31, 2009 | Televison & Video
Sansung DLP HL-P4674W Is making this loud humming noise and the oicture is now in black and white
sounds like a the color wheel blown. Call a local tv repair shop. Some Samsung models carry two different color wheels for same model depending on chassis version which can be seen only when the back is removed.
Dec 08, 2009 | Samsung DLP HL-P5663W 56" TV
I need to replace the bulb on my TV model # HL-S5679W. I can not locate the replacement number for the lamp. I have been unsuccessful with contacting Samsung and need help.
This model does not use a lamp----if the LED unit is bad you may want to just forget it---
Samsung part number for the entire optical engine:
BP96-01470BIt is marked as no longer available (2006 model) and had a suggested list of 495 exchange.
Google the above part number and you will find some places selling the engine---for much more than Samsung wanted.
SORRY TO GIVE YOU BAD NEWS---no replaceable lamp in this model----the LED light unit is part of the optical light engine.
SD TECH
Oct 28, 2009 | Samsung HL-S5679W 56" HDTV
TV model HLS6188W start to shutting off all the time.
If TV lamp has not been changed in last 2 years then most probably its Lamp issue in TV and requires lamp replacement.
Apr 16, 2009 | Samsung HL-S6188W 61" HDTV
Dlp tv problem
Is the lamp light the only one thats flashing? Does the buzzing your hearing stop or is it constant? Also when you press power off does the buzzing stop instantly or continue? Respond to this post and I will try to assist you. Is HL-R677w the correct model number also?
Jun 21, 2008 | Samsung HL-R5677W 56" HDTV
Samsung DLP HL-P5674W Screen is stretched at the top and bottom...
did you ever find out the problem , mine is doing the same thing,
please email highltv3@aol.com if you can help
thank you so much
debi
Mar 05, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HLP4674W 46" Rear Projection HDTV Logo
143 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
