Question about Jabra BT250 Consumer Headset
My Bluetooth headset's microphone stopped working
My Bluetooth's microphone does not work. I have a Blackberry Flip phone. All of a sudden Bluetooth's microphone stopped working. The caller on the other end is unable to hear me. I am able to hear the caller fine.
It is definitely a problem related to the phone because I have tried two bluetooth headsets. Both of them showed the same symptom with Blackberry but worked on other phones.
I have seen scattered references to this problem on the web. However, no one has posted any possible resolutions.
I would appreciate any pointers.
Same Problem Here. Restored the 8220 flipphone to factory settings. Dint work either.
Posted on Nov 26, 2009
  • graphicfx_20 Jul 09, 2010
    I have the same problem right now! I have a Blackberry Pearl 8220 flip and Bluetooth worked fine then one day the mic suddenly stopped working. I even ordered a new bluetooth under warranty and have the same issue. Both bluetooths work with my husbands phone. I cant find a solution anywhere. Has anyone else had any luck?
Bluetooth quit connecting with Moto Razr Phone
Go to bluetooth and see what is listed click on it and remove device. Start over.
May 03, 2017 | Motorola Mobility H700 Wireless Headset
How do I connect my blackberry cel phone to my bluetooth ce0678
Hi, you can use this instruction to pair your blue tooth with your cell phone:
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Good luck to you..
Feb 01, 2011 | Cell Phones
My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
You can use the below steps to know how to pair properly:
Instructions
Tips & Warnings
Hope it helped.
Thanks for usingf ixya..
Jan 13, 2011 | Plantronics Explorer 320 Wireless Headset
Will a Bluetooth wireless headset work with a normal Blackberry phone, or does the phone have to be Bluetooth enabled?
yes, for you to use a bluetooth headset with any mobile phone, it has to be bluetooth enabled so it can have a means of connecting to the headset.
although, majority of the blackberry phones that are known should work with certain bluetooth headsets since they do not comprise of just simple mechanisms like normal mobile phones. that is just about the same way that iphones usually select special types of bluetooth headsts to work with
hope this answered your question, please rate
Dec 15, 2010 | Just Wireless Bluetooth Headset Wireless...
I have a BlueAnt Supertooth BTSLBC3 car speaker that won't pair up to my new BlackBerry curve 8530 phone. The BlackBerry won't see the BlueAnt Supertooth BTSLBC3. The BlueAnt Supertooth BTSLBC3 is paired...
Pairing Your BlueAntStep 2: Activate Pairing Mode on the Supertooth Light
  1. If the microphone arm is open, close it to turn the Supertooth Light off.
  2. Press and hold the answer button.
  3. With the answer button held down, open the microphone arm.
  4. The lights will start flashing red and blue, indicating that the Supertooth Light is in pairing mode.
You now need to activate Bluetooth
Apr 03, 2010 | Blueant Supertooth Light Bluetooth Speaker...
Iphone 3G blutooth microphone volume extremely low
go to the volume control for mirophone.
Jul 15, 2009 | Apple iPhone 3G
Using h700 as a PC headset
Rjcroller wrote and is working fine. please follow....
Steps to pair a H700 headset with any bleutooth pone:
  1. Make sure the H700 fully chared (very important)!!
  2. Make sure the microphone boom is folded closed, i.e. power is off!
  3. Hold the call button for 1-5 seconds until the light is steady lit purple
  4. Flip out the microphone boom, the light should stay lit purple!
Now you are ready to pair the headset with your phone, so follow the pairing instructions of your phone.
Note: When prompted for the Passkey; it is most likely 0000 but the correct Passkey should be on the headset accessory instructions.
I must add that indeed my headset on occation (once or twice every three months) also loses its connection with the blackberry (a 8703e) . At which time I have to remove the headset from my phone bluetooth device list, and start the above described steps to pair my headset with the phone again.
Jul 16, 2008 | Motorola Mobility H700 Wireless Headset
Can't hear headset
Here is a list of compatible bluetooth headsets taken from the Blackberry web site.
  • Flamingo™ Bluetooth Headset *
  • Jabra® BT250v
  • Jabra JX10
  • Jabra BT125
  • Logitech® Mobile Pro™ Headset
  • Motorola® Bluetooth Headset H500 **
  • Motorola Bluetooth Headset HS820
  • Motorola Bluetooth Headset HS850
  • nXZEN™ 5000
  • Plantronics M3000 Bluetooth Headset
  • Plantronics Discovery™ 640 Bluetooth Headset
  • Plantronics Explorer™ 320 Bluetooth Headset
  • Plantronics Voyager™ 510 Bluetooth Headset
  • scala-500™ ***
  • Sony® Ericsson® Akono™ Bluetooth Headset HBH-602
  • It may be a compatibility issue with the H700. You may want to make sure the volume is turned up fully on the headset as well.
    Good Luck
    Jun 28, 2008 | Motorola Mobility H700 Wireless Headset
    Microphone...
    You need to clarify whether microphone or its connection bad or system causing the problem. I suggest you to try with external bluetooth or normal headset. If sound microphone works with headset you need to have microphone connection be fixed
    Jun 19, 2008 | Nokia E90 Cell Phone (Unlocked) - Black
    Purple light wont stay lit for pairing
    Make sure the microphone is closed and the BlueTooth is off. Hold the button in until it turns purple. As soon as it does release the button and flip out the microphone. The purple light should stay lit all the time now. That is until the pairing process is done with the phone.
    Mar 18, 2008 | Motorola Mobility H700 Wireless Headset
    Jabra BT250 Consumer Headset Logo
    374 people viewed this question
    Top Jabra Radio Communications Experts
    TO Lady
    Greg Cann
    Greg Cann
    Michael Vincent Cruz
    Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
