Question about Konica Minolta bizhub 350 All-In-One Laser Printer
I get the error code C0910. What means that and what's to do now?
  • Konica Minolta Expert
  • 158 Answers
Paper tray 2 paper lift failed take the paper out and make sure it is not folde or bent in a way that would cause it to not be lifted up to the feed rollersif it looks fine then you may have a failed lift motor
Posted on Oct 23, 2009
There is a solution to fix this fault system
Posted on Jul 14, 2013
3 Suggested Answers
  • 158 Answers
SOURCE: delete error code C0910 or reset?
with the machine turned on open and close the front door
bunnydawg
  • 5158 Answers
SOURCE: error message
C0910, C0911 2nd drawer lift problem
Robert
Posted on Aug 29, 2008
How do i clear the error code c0910?
Second draw lift ensure no PAPER is in the back of the draw jammed between draw and back of copier. Also check the no paper is being stored in side the draw all paper is the right side of the draw DO STORE EXTRA PAPER IN THE DRAW NOT DESIGNED FOR it
May 21, 2014 | Minolta Di3010 Copier
Konica minolta dialta di3510
The pass code for the admin mode on the di3510 should be 00000000 (8 zerros ) OR Elevation drive motor failure for the finisher /service manual
Aug 28, 2012 | Minolta Di3010 Copier
Error code C0910
Second Draw lift open the second draw remove the paper from behind the draw, ALSO REMOVE THE PAPER BEING STORED ON LEFT HAND SIDE OF THE DRAW. IT IS NOT A STORAGE AREA!!!!!!! It is available for 11xx17 paper. Storage is for the storage draw!!!!!!, IF not these two items you have a bad motor for the second draw or worse case a bad control board!!!!$$$$$$
try this site for parts:
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Mar 21, 2012 | Minolta DI2510 Black and White Copier
Code c0910
This error code means there is a paper lifting problem in the paper trays. Most common cause is improperly loaded paper. Check the trays to be sure all paper is loaded properly then turn off then back on, the MAIN power switch Not the one up on the control panel. If the code does not come back then your fine. If it does then pull out all of the paper drawers, reset the code again and then close each drawer one at a time waiting 15 seconds between each tray closing. If you close a drawer and it pops the code after a few seconds then that is the tray that is causing the problem. Double check that tray and if you can not get it to work then you will need service on that tray as it has a paper lift problem. Either the lift motor or the sensor. You can leave that tray popped open an inch or two and still use the copier with the other trays.
Good Luck and Thank You using Fixya.
Sep 22, 2010 | NEC IT2520 Fax
ERROR C0910 KONICA MINOLTA BIZHUB DI 2010
2nd Drawer Lift-Up Motor Failure - The Lift-Up Sensor is not unblocked even after the set period of time has elapsed after the paper liftup operation for the drawer has begun.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Nov 27, 2009 | Minolta Office Equipment & Supplies
Delete error code C0910 or reset?
Sep 24, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Describe your Minolta Di3010 Grayscale CopHi I
The error code you are getting is a paper tray lift problem. Open all the paper trays and make sure that you have the correct size paper in each paper tray. Also, make sure the paper guides are tight againest the paper in the trays. Turn the copier OFF then back ON... Wait for the copier to come to ready and one tray at a time reinstall each tray at a time.... The one that cause's the error code to show up is the paper tray with the problem. Once you know what tray is the problem, remove the tray and look inside the copier for a wade of paper jammed behind the tray... If not you may have a bigger problem, then we can help with... Good Luck....
Jun 26, 2009 | Minolta Di3010 Copier
Minolta Di 3010 Error code C0910
Sorry it took so long but I found it.
C0910 indicates that the 2nd drawer on your copier isn't lifting. Open the drawer and see if there is any jammed paper in there.
Sep 04, 2008 | Minolta Di3010 Copier
Error message
Robert
Aug 29, 2008 | Minolta DiALTA DI2510F All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,243 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
