Question about LG Dryers
NEED DIRECTIONS FOR REMOVING A DRUM FROM A DRYER MODEL #DEL3777W
  • LG Master
  • 7,482 Answers
On a front load dryer you would remove the front of the dryer, it will expose the drum and belt
Posted on Sep 25, 2009
Where is the heating element in dryer
Depends on the brand of dryer. GE dryers are usually directly behind the drum assembly which requires removing the drum to replace. Whirlpool dryers have the heater in a duct work running up the back of the dryer. Some other brands have the heater in a round pipe similar to the vent pipe in the bottom of the dryer. Would need dryer model to tell you exactly.
Mar 01, 2015 | Dryers
Location of fuse model WER211ESO dryer
The fuse is probably related to the mains plug fuse and unlikely to be this as the machine switches on. Possibly the heater or heater thermostat. You may need a engineer to confirm which one.
Jan 17, 2014 | Electrolux Dryers
Hello, I have a Model 94712 Washer/Dryer stacker that won't pump water out during the spin cycle. I have cleaned out external hose, no kinks, taken out agitator and cleaned screens in drum. Machine seems...
Instructions
1. Disconnect the power to the dryer. This can be done by simply unplugging the dryer completely, or by shutting the power down to the entire outlet at the fuse box. Either way you do it, make sure you do it. You don't want to mess with anything that uses electricity while it still has power going to it.
2. Pull the dryer away from the wall. You will need to be able to work behind and in front of it, so try to maneuver it into a location you can work on both sides. If you can't, start by working in the back.
3. Remove the access panel on the back of the dryer. You will probably need to remove some screws from the panel in order to get it off. Removing this piece should give you a view of the motor and idler pulley.
4. Inspect the idler pulley and the belt attached to the motor. Often times the idler pulley will get worn out and begin to cause a high pitch squealing noise. It should be pretty obvious if it is worn out. If it is worn then head to the store to get a replacement. Ensure you get the exact same model, even slightly different models can cause the same or different problems to start immediately. If the idler pulley looks fine, continue on.
5. Replace the access panel and go around the front of the machine.
6. Remove the cabinet of the dryer and also disconnect the drum. For this you will also need your screwdriver and probably the directions for your particular model dryer, because each dryer has a different way of removing the cabinet.
7. Look at the rollers on the bottom of your machine. See if there is anything lodge inside of them or if they look worn. If they do, you will want to replace them. Again, making sure that you have the same model roller than you are using now. Many times a kit can be bought that includes the rollers, belt and idler pulley, so you may want to look into that option
Mar 07, 2011 | Kenmore Dryers
I have a maytag electric dryer (model SDE4606AYW) which is making a constant screaching sound. Researching websites, it looks like it could be the bearings and/or guide rollers that have worn out. Please...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
I agree, I think it is the drum rollers.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer by removing the screws at the top corners of the machine, the bottom should clip to each other,also remove the lint filter, and the two screws that hold the housing to the top of the dryer.
This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 12, 2010 | Maytag SDE4606A Electric Dryer
GE electric dryer (model #: DRSR483ED2WW) sounds like grinding metal when dryer starts/runs
you need to replace the rear drum bearing by removing the front panel lower screws and then remove the top cover and lean back and secure so as not to break wires to control panel,then remove drum belt,lift out drum and replace with bearing kit
Feb 01, 2010 | Dryers
Severe noise - drum is jammed and won't turn - LG DLE-5977 dryer
A piece of clothing is probably caught in the blower wheel.
Remove lint filter.
Use flashlight to look into filter housing to the lower left.
You may be able to retrive the item if you can see it.
Try rotating the drum in both directions while looking.
Jan 07, 2010 | LG DLE5977 Stainless Steel Electric Dryer
CHIRPING CLOTHES DRYER
The problem sounds like your drum rollers, you can try to lube them by pulling the front of the dryer off and removing the drum. Or you can replace them by removing the front of the dryer and removing the drum.
Sep 25, 2009 | Maytag Dryers
Need help removing the cabinet and drum
See if the diagram I am attaching will help you in your endeavor. Sure hope this helps and best wishes.
Aug 08, 2009 | Roper RES7646KQ Electric Dryer
I need Directions how to replace the belt.
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......
May 04, 2009 | Dryers
Fabric looking belt came out of dryer. when i try to dry clothes it makes a loud noise and smells like something is burning and my clothes get twisted. how do i fix it? I have a kenmore 70 series dryer
Stop using your dryer in its current condition. That fabric looking felt is probably your drum seal. They commonly wear out. I will need your dryer model number in order to confirm how your dryer is configured and give you accurate advice on part numbers and directions on how to replace. The model number should be listed on a name plate around the door opening.
Apr 22, 2009 | Kenmore 63942 Dryer
Dryers Logo
47 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
